Question about Hotpoint Ultima WF860 Front Load Washer
Re Hotpoint Ultima washing machine
Panel display indicator is fading making it difficult to read the settings
  • warmpipe Aug 24, 2008
    I have the same make and model machine and have been watching the display gradually dissapear. It has been flickering enough to bear with until tonight when the last led light finally gave up. Could anyone be more specific as to which board it is that needs replacing. Luckily there is just a faint unlit digit still visible to be able to work out what part of or cycle you are on............Aggggggghhhh..........
  • 66 Answers
This is a common fault you can get hotpoint to replace the board at a cost of £90 or buy a second hand board for about £40 sorry but this is your only option without sending your board to qer
Posted on Jul 13, 2008
Digital display fading on my hotpoint washer
The first thing is to get a replacement that is exactly the same as the one you want to change.
Then fix it, follow the instruction of the display and that of the instrument itself
May 05, 2012 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint wf840 displays h20 all the time
This is indicating a problem with the water supply to the washer.
Check inllet hose/s, make sure they are not kinked or restricted , make sure tap/s are fully turned on.
Make sure water presure is o/k.
Mar 18, 2010 | Hotpoint Ultima WF840 Front Load Washer /...
Hotpoint ultima washing machine showing fault code f-05 and door will not open.
Error code F05 indicates pressure switch jammed on full.
Remove lower rear panel of washer.
Remove large black hose on bottom of drum.
Remove and clean filter inside hose.
Remove hose onto pump, and check for blockage or obstruction here as well.
Make sure there is no water in drum before you start.
Please rate my solution.
Thankyou.
Jan 26, 2010 | Hotpoint Ultima WF860 Front Load Washer
My Hotpoint Ultima WMD 960 displays "F04" on the display panel before the programme ends. Have cleaned the filter and it worked OK in spin mode and finished normally but now have put in a washing load, it...
Error code F04 means pressure switch jammed on empty.
Do the following.
Remove and clean filter inside the hose.
Remove the hose on to the pump, and check for blockage or obstruction here as well.
Thankyou.
Jan 25, 2010 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint ultima F-05 errorr appears on machine
Error F05 indicates pressure switch jammed on full.
Remove lower rear cover of washer.
Locate and remove large black hose fastened to drum.
This should solve the problem.
Jan 10, 2010 | Hotpoint Ultima WF860 Front Load Washer
I have an e15 code on the lcd display
Are you sure it is E15 and not F15?
F15 on an lcd display washer/dryer indicates dryer element faulty. this being the case then it will probably require a new element fitting.
Hope this helps
Dec 05, 2008 | Hotpoint Ultima WD72 Front Load...
HOTPOINT ULTIMA SUPER SILENT ( WF 860 ) 1600 SPIN SPEED.
I read that someone has a problem with F-03 on the display. I have seen this for the first time on my hotpoint wf860 1600 spin. I read the manual the only thing I can think of maybe an unbalanced load in the machine. Albeit the manual is not clear about this. P21 automatic features unbalanced load warning.
Sep 04, 2006 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Ultima WF860 Front Load Washer Logo
146 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
