Question about Whirlpool CAM2752RQ Coin Operated Commercial Washer
Bottom agitator does not seem to have any grip and does not spin on its own.
    President:
  • 3,113 Answers
The drive block and spanner nut must have come loose .11 & 8 Bottom agitator does not seem to have any grip and - tepoxeddj6.gif
Posted on Dec 28, 2010
The plastic agitator isnt spinning it sounds as though the piece it sits on is turning but just spinning insde the plastic housing on the underside of the agitator
your "agitator coupling" is worn out underneath the agitator,remove the dispenser cup on t6he agitator,then the agitator,it sits on the coupler on splines and they wear out and the agitator can,t grip them anymore and slip
May 14, 2010 | GE WBSR3140DW Top Load Washer
It leaves soap on the clothes after it goes thru the cycle and I noticed that the top part of the agitator doesn't move hardly. The washers model # is LSR8233JQO and the serial # is CK4729250, Type 111.
The agitator dogs (part # 80040) that grip and turn the top agitator to push the clothes into the bottom agitator during the wash cycle are worn and must be replaced. It costs about $5 and replacing it is an easy task to do.
Disconnect the power to the washer. Open the lid and remove the agitator cap by prying it with a flat-bladed screwdriver off the agitator top. Remove the 7/16 inch stud and seal holding the agitator to the shaft using a socket wrench with extension.
Lift the agitator off the shaft and pull the top agitator off the bottom agitator. Remove the cam that holds the agitator dogs from the top agitator.
Lay the cam upside down and install the agitator dogs on the slots. Hold the cam with the newly installed agitator dogs on one hand and the top agitator upside down on the other. Slide the cam up into the top agitator and turn the assembly in the upright position.
Align the cam and bottom agitator tabs and cut-outs and place the top agitator with the cam over the bottom agitator. Place the agitator assembly on the shaft and rotate it until the grooves match. Push the agitator down and reinstall the stud and seal. Do not over tighten the stud or the agitator will not spin properly.
Feb 10, 2010 | Dryers
Kleenmaid top-load washing m/c leaks water and then smokes!
It sounds like you are leaking from the bottom of the unit. If you are leaking at the top then you need to check the water inlet valves, and also the drain pump and all water hoses. This doesnt sound like a seal issue.
Jan 02, 2010 | Washing Machines
Agitator top to bottom rotation seperation
387091 is the part called agitator clutch or dogs,they are little yellow pieces of plastic with teeth on the ends to grip the agitator and turn in it the teeth are worn off of yours..
Sep 02, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Maytag MAV7000 AWW washing machine agitator won't spin freely.
When you grab the fabric dispenser and move the agitator "counter "clockwise you should hear the rachet noise,once you try and move it back "clockwise" the fabric dispenser should slide inside the agitator and the agitator should NOT move.
Apr 02, 2009 | Maytag Atlantis MAV7000
Agitator ''dogs'' not gripping, agitator spins freely; tub rocks
Likely a broken dog itself was making the noise. They should all be replaced.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 16, 2009 | Kenmore Washing Machines
INGLIS WASHER SUPERB AGITATOR DOES NOT WORK
sorry not real solution as I am not familiar with that design but recommend replacing machine.
Jan 31, 2009 | Whirlpool Inglis IP4400 Washer
Agitator spins in one direction
The purpose of the upper portion of the agitator is to push the clothes in a downward motion. As the agitator moves the dogs grab and on the backward srtroke the top portion rotates a quarter turn. In the spin mose the agitator only goes in one direction or your clothes would be torn to shreads.As the washer rotates back and forth, the dogs grab the inner walls of the upper agitator and that forces the clothes into a downward movement to the bottom of the tub. These dogs will wear out. To test whether or not these are bad just grab the agitator while in wash mode. The dogs should advance the top portion easily. If not then they are worn out. To replace them you must remove the agitator and sit it on the floor. Hold the base down with your feet and yank the top upwards. After seperating the 2 pieces you simply install the new dogs and line up the bottom with the top being careful not to break the little tabs on the bottom agitator that hold the top in place.
Dec 22, 2008 | Kenmore 22422 Top Load Washer
Roper washer, agitater stripped?
It sounds like you need to replace your agitator dogs (yes, there is such a thing). They are small plastic pieces that are used by the upper portion of the agitator to grip as it turns. This is a common problem when they wear out. If you go to searspartsdirect.com, there's an illustration of what I'm talking about under the "Agitator, Basket and Tub Parts" heading. Item number 10 (part number 80040) is what you need to replace. Just type in your complete model number in the "Search by Model Number" block. The following link provides you with step-by-step instructions on how to do this:
http://www.fixya.com/support/r823955-replacing_agitator_dogs
You can find these same parts at repairclinic.com and a cheaper price. Use the part number provided. I hope this helps you.
PS The item is priced for a package of 4.
Aug 06, 2008 | Roper RAX7244KQ Top Load Washer
Kenmore 90 Series
The agitator has four small teflon (I believe) plastic grips inside the upper portion called "agitator dogs". They have small teeth on them to grip the inside ring of the agitator. You can replace them for less than $10 for a pack of 4. Your local appliance repair shop should carry them, or be able to order them for you. Let me know if this helps.
Jun 26, 2007 | Kenmore 22422 Top Load Washer
Washing Machines Logo
32 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
