Question about Whirlpool RF378LXKS Electric Kitchen Range
Top burner stuck on high setting, won't turn on and off
Gas grill was washed now it won't light
Regulator. Tanks were non burped... Regulator stuck. Turn off tank slow. disconnect. Turn burners on. Tap the regulator with a piece of metal. Turn burners off. Connect tank. Since it was washed out electric starter dont work. Turn burners on. Then you will hear it. Gas. Take lighter and start. Big startup. The hair on your hand burned off wash your hands. Then get the meats! Easy as Cake
Jul 13, 2012 | Grilling
I've used you guys once before - right the first time so trying again for a different problem. I've got a Frigidaire glass-top electric range (model PLEF398CCD) and 2 of the four burners stay on...
Thanks for using Fixya once again we appriciate it!
The problem with your stove is going to be with the infinate switch(what ya are calling knob) for the burners that giving ya trouble are shorted and the contacts inside of it are welded so they permanantly are stuck on the HIGH setting. To repair that the switches for the affected burners would need to be replaced.
The part number for those switches is 316095503 they could be purchased at your local appliance partstore or online at;
searspartsdirect.com
apdepot.com
repairclinic.com
apwagner.com
partselect.com
GENE
Oct 02, 2011 | Kitchen Ranges
Large right/front burner is out of control. Regardless of the setting, the burner heats very high. In fact, recently, oliver oil in a skillet ignited. Even though the control was set to less than medium,...
The switch for the right front burner is defective and needs to be replaced,its bad as far as internally when turned on no matter what its set it the interal contact is stuck on only high so their is no setting it will work on except high. By replacing the switch it will work on the various settings and not just high.
GENE
Sep 23, 2011 | GE Cooktops
Brinkman grill 3 burner pro series 8300 won't
To restore gas to the burners, follow the instructions below.
1. Turn the gas tank valve OFF and disconnect the hose from the tank.
2. Wait 5 minutes and reconnect the hose to the tank.
3. Open the tank valve VERY, VERY SLOWLY (Slow motion, slow).
4. Once the tank valve is fully open, light the burner farthest from the tank first and set the burner
control knob on HIGH. Does the flame height look correct for being set on HIGH? If so, light
the remaining burners the same way. Do all the burner flames look correct? If so, you solved
the problem. Remember, to always open the tank valve Very, Very Slowly.
If that didn't solve the problem, you will need to replace the grill's Hose/Regulator Assembly. It runs about $30.00 at any home center or hardware store that sells grills & accessories. If you replace it, turn the tank valve ON Very, Very Slowly.
Hope this helped you to troubleshoot and solve the problem. Happy Grilling.
Jul 04, 2011 | Brinkmann Grilling
Frigidaire smooth top electric stone eye stuck on high!
Yes,the switch controlling the burner is bad and must be replaced.
Oct 31, 2009 | GE Kitchen Ranges
Cooktop burner will be dim and red automatically
when you set a cook top burner to high then it should stay on until the "thermal" limit shuts it off. then the burner will stop glowing. if you dont put a burner on the top, the burner sensor will shut of on the thermal safety.
it is normal but what you need to check is if you pans are flat on the bottom. a bow inwards or outwards will cause the thermal to shut the burner off. the pan needs to "draw" the heat out of the top and allow the burner to operate properly.
most of the time the pans a warped causing the burner to cycle on the limit and then not heat as well as it could with a "flat pan"
Jan 22, 2009 | GE JBP66 Electric Kitchen Range
Burner temp.
If set to high, burners should remain on. If set to medium high let's say, they would be on for maybe 70 percent of the time, off for 30 percent of the time. If set to warm, they might be on only 10 percent of the time, off 90 percent. There is a high temp limiter which could turn a burner off. If you have a burner on high and are cooking on that burner and it goes off, the high temp limiter may be faulty. It is an integral part of the burner, and would require replacement of the offending burner. Burners are individually replaceable after lifting up the glass cook top.
Oct 19, 2008 | GE JBP66 Electric Kitchen Range
Stove top electric burner
Switch for that burner most likely the problem
Aug 23, 2017 | GE JCP67FWW Electric Kitchen Range
Only high setting works on burner
Sounds like the Switch or the element are bad, try trouble shooting them. It's a stove top??
Eddie Rentas
Tupper LAke NY
Jul 17, 2008 | GE 30 in. JP340 Electric Cooktop
Gas range top burners too hot
Get the installation manual for your range, and find the part on adjusting the low heat for the burners. On my Whirlpool, I found there is an adjustment screw inside the control knob shaft of each burner. The manual says turn the burner on low, remove the knob, then turn this screw until the flames are 1/4" high. Super-easy, it took me 5 minutes to do. I am sure all ranges have similar adjustments, might be in different locations - check the manual.
Feb 05, 2008 | Kitchen Ranges
Whirlpool RF378LXKS Electric Kitchen Range Logo
97 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
