Question about Intertherm Heating & Cooling
I have a single wide mobile home Intertherm heating / cooling sys. Yesterday it stoped heating . The blower comes on and thermostat seames to be functioning normal , with the exception of no heat . Can you please advise .... Thanks Tim C. taclickner@yahoo.com
    Master:
  • 381 Answers
What is your heating medium?-
Natural Gas, or LP gas--- or Fuel Oil-- Or electric? (Like a Heat Pump-- a compressor as in an Air Conditioning system-- the 'waste heat' is the source of heat-- They are a bit more economical that Electric heat.
Tell us about how it sounds different now, than it did yesterday (or when it stopped heating..)
Are you in the Freezing South right now?
Mack B
Posted on Dec 28, 2010
I have an intertherm furnace model number 901282 and it will not heat my house when i turn on the thermostat it starts but just blows out cold air pleases help
The blower should come on after ignition occurs. When the blower comes on first ignition will not be activated as the thermostat signal shows the heat is on. This happens when the blower relay is stuck in the on condition
Nov 21, 2014 | Intertherm Heating & Cooling
Why doesy intertherm air conditioner run most of the time
First off it may be undersized or too small for the area being cooled. the thermostat maybe un level if it has a mercury bulb. The cooling contactor could be stuck, or you may have wires shorted together.
Jun 22, 2014 | Intertherm Heating Cooling System 15kw...
Intertherm furnace burner comes on, but blower does not. If I turn thermostat off then back on until it clicks the fan will then come on. It does not do this all of the time, just now and then.
Furnace burner and heat element are not the same. I think the fan time delay, a sensor that turns the fan on when this sensor senses heat, is shot and needs replacing, for a furnace type heat ( gas heat)
Aug 08, 2017 | Intertherm E3EB010H Electric Furnac
Heating eleament keeps kicking on and off.
The thermostat contacts are sticking...replace the thermostat!
Jan 14, 2013 | Intertherm Heating Cooling System 15kw...
Have an Intertherm thermostate in mobile home controlling gas hearing and elec ac. Blue wire to thermostat connects to the "A" terminal on the thermostat...Blue wire goes to a terminal on the...
If there are only two wires going to the thermostat? Then you will not be able to use a Digital Programable stat. Intertherm and Coleman furnaces do the switching different than regular furnaces. They use the switching from heat to AC at the furnace with the rocker switch. They use the thermostat to either break the connection or make the connection. They use a heating only thermostat.... Hope this helps
Jan 02, 2011 | Intertherm P3RA-048K Air Conditioner
What's the deal? Wont shut off or respond to thermostat. . .
Red= power........White=heat.............Green=fan.................(grey)-(yellow)=cool .....these are the connectons. Disconnect these wires from the thermostat and know that red/power is the only wire that send power to the thermostat, and the rest sends it back to the unit to call for whatever,, red--to . white for heat... red to green for fan .... &red to grey for cool! OK! Turn all your power on, and use a jumper wire from red / green for fan and see if the fan comes on! Then move the jumper wire from red to green , to red / to white for heat and the fan , wait for 3 minutes before removing and going to the next step. Then red /to grey for cool and check if the outside comes on. Either you have a wire touching past the insulations and making a connection, a bad thermostat ,oe excessive wire lead touching the next connection.Thank you very much!
Nov 05, 2008 | Intertherm Heating & Cooling
Intertherm heating
My heating unit is blowing cool air. The thermostat will start the blower when the unit is turned on at the thermostat, but the air isn't hot. But,when I turn the unit on at the furnace/blower using the "Fan On" button, I can see the heating element heat up. After the blower starts the heating element does out. What could be the problem?
Oct 29, 2008 | Intertherm P3RA-048K Air Conditioner
Intertherm E1EH-015HA FURNACE no heat
Sounds like a downflow electric furnace? If so it sounds like you have 15kw worth of electric heat, you might have a defective heating sequencer, witch is what they call a dual on one plate.
Nov 26, 2007 | Heating & Cooling
Heating & Cooling Logo
145 people viewed this question
Top Intertherm Heating & Cooling Experts
Donni Steen
Dennis Boxerman
Dan Webster
Dan Webster
Are you an Intertherm Heating and Cooling Expert? Answer questions, earn points and help others
