Is there suction at the end of the hose? If not, the hose is clogged. Generally the blockage is located near the handle, but sometimes at the other end. Occasionally, if something long, like a straw, is sucked up, it will get caught somewhere else in the hose that's impossible to get to.
You can try to hold the wand end of the hose directly to the CV tank and turning it on. This should clear the clog. If not, hold the handle end to the blower of a shop vac or canister and turn it on. The other end should be either in a large plastic bag, inserted in the in port of the vacuum, or directed outside.
If there is suction at the end of the hose, the most likely place for a clog is at the elbow on the power nozzle or just behind the brush. This can be cleared by using the handle of a wooden spoon or similar blunt object to push the clog back out toward the brush.
If none of these help, take the vacuum to the nearest Aerus Electrolux store for assistance.
http://www.aerushome.com/storelocator/
