I don't see one for the B1800. The closest I've been able to find are the B1620, the B1650, and the B2300. Hopefully one of these will be close enough to get you started.
U mean the Lamp door cover?Yes?Tv might work,might not.Don't know never tries to turn the tv on before without a Lamp door cover close before.There is a blue safety switch though must be press down when the Lamp door cover is close.Test it out.Why don't u just take a piece of tape and tape that blue safety switch down tightly,than turn on the tv.If the tv message that said close lamp cover correctly disappear.Than yes the tv will work,without the lamp cover closed.Now u just needed to do a replacement of the tv projection lamp only that all.
the BTR cover is also called " Bias Transfer Roller " cover it should be that roller that seen when open the front cover most likely the Bias transfer roller door sensor in NOT detecting the dorr closed. make sure the tab isn't broken this will produce this error if it is.
The BTR cover is covered the fuser. If you open the rear door, it is located at the upper part, behind the metallic rod. The problem is the cover is installed unproperly: Its metal piece is not touched against the metal piece of the machine, so the machine does not "smell" the BTR cover.
