Question about Ricoh Office Equipment & Supplies
Paper tone when exit - Ricoh Office Equipment & Supplies
    Guru:
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 183 Answers
Please dear more details
Posted on Jan 01, 2011
I have 5200 hp laserjet printer is a problem 13.05.00 jam inside top cover tell me this problem
A jam has occurred in the registration
assembly area.
1. Press the 'down arrow' to see step-by-step
information.
2. Open the top cover and remove the print
cartridge.
3. Remove all media inside.
4. Lift the metal flap and remove any
remaining media.
5. Verify that the media size matches the
tray settings and the dial on the tray.
6. Reinstall the print cartridge and close
the top cover.
7. To exit, press ? .
Oct 27, 2011 | HP LaserJet 5200 Printer
Fax is not going through. says there is an error. If making copy, it is very dark on right and left sides of the paper. Any sugggestions?
What you are probably experiencing is the fax machine is not getting a dial tone from your line, thus giving you a error.
Many times things get moved, paper runs out, ink runs low or the line gets unplugged. We suggest you check the line making sure it has a dial tone, checking your ink would be another great step.
Many times these machines get dirty with would cause the black ink run on the sides of the paper. You could clean that out with a can of compressed air. You would do this by opening the machine as you where to change the ink in it. You would give it a couple blast of air at the exit paper trail.
The other thing is this is thermal meaning the ink is super heated onto the paper, if there is any residue of ink this would cause this issue.
Now the error message you did not give us, I would be interested it knowing the error code before I can make further comment on how to proceed with the sending issue. Many reasons are:
1. No dial tone
2. Paper jammed inside the machine
3. OCR scanner errors
Please let us know what the error code is so we can give you a great solution on what to do from there. We do Thank You for using Fixya.com
Jun 01, 2011 | Sharp UX 108 Roll paper Thermal Fax
Cyan and majenta tone is not good
Solution : Perform an Automatic Gradation Adjustment (Color Calibration) Automatic Gradation Adjustment compensates for tones when the color tones shift in color copies / prints. Compensating for color tones maintains the quality of color copies / prints made by the machine at a fixed level.
NOTE: Output of the Automatic Gradation Adjustment chart is added to the metered copy count.
NOTE: When Gradation Adjustment is selected, the following changes will be made to default copy settings set in System Settings mode:
  • Copy Density = Normal or Auto
  • Color Shift =Normal
  • Saturation = Normal
  • Color Balance = 0
  • Sharpness = 0
  1. Press the [Access] button (key symbol) on the Control Panel. The Access button is located above the number "3" on the numeric keypad.
  2. Using the numeric keypad, enter your administrator password and select [Confirm] on the Touch Screen. The System Administration Menu screen will be displayed.
    NOTE: If you do not know the password, contact your administrator. The initial password at machine install is 11111. If the administrator encounters a problem with changing the password, or forgets the password, a service call must be placed.
  3. Select [System Settings]. The System Settings screen will be displayed.
  4. Select [System Settings] again.
  5. Select [Common Settings].
  6. Select [Image Quality]. The Image Quality Adjustment screen displays.
  7. Select [Automatic Gradation Adjustment].
  8. Load 8.5 x 11 inch (216 mm x 279 mm) or A4 (210 mm x 297 mm / 8.3 x 11.7 inch) paper in Tray 5 (Bypass Tray). Adjust the paper tray edge guide so that the guide gently touches the edge of the paper stack.
  9. Select the desired gradation adjustment screen.
  10. Press [Start]. The Adjustment Chart is output.
    NOTE: When printing the color chart for Auto Gradation and you get the message,'Auto Graduation Procedure has completed with an error' make sure that 8.5 x 11 inch (216 mm x 279 mm) paper is loaded into Tray 5 Long Edge Feed (LEF).
  11. Place the Adjustment Chart face-down on the Document Glass with both the Magenta color patches against the left side of the glass.
  12. Place 5 sheets of white paper on top of the Adjustment Chart and close the Document Glass Cover.
  13. Press [Start].
  14. To continue Automatic Gradation Adjustment with other screens, repeat steps 6 to 10. When you are finished, select [Close] until the System Settings screen is displayed.
  15. Select [Exit] to exit the System Settings mode.
Hope it helps!
May 01, 2011 | Xerox WorkCentre M-24 Color Copier
How can I adjust the screen so I can see the score of the football game it is cut off on my Panasonic TH-50PX75U
Hello
To do this you have to enter into the service mode, ie, factory setting modes, which oly will allow you to do the screen adjustments. Your TV needs vertical S-Correction, to avoid lower side stretch. Four methods to enter into the service mode are given here . Just try OK.
In Sound-Menu Low-tone-regel to MAX and
High-tone-regel to MIN. Press 'F' button on TV.
Then press VOL- on TV and REVEAL on RC in
some time. Select: red and green buttons.
Adjust: yellow and blue buttons. Store:
'STR'. Exit: 'N' on RC.
High-tone-regel to MIN. Press VOL- on TV
and RESET on RC in some time. Select: red
and green buttons. Adjust: yellow and blue
buttons. Store: 'STORE'. Exit: switch off.
ON: Press simultaneously 'OFF TIMER' on RC
and 'CH.UP' local.
OFF: Press simultaneously 'OFF TIMER' on RC
and 'VOL-' local.
Simultaneously press 'RECALL' on RC and
'VOL-' local. Exit: 'NORMAL' on RC.
After entering into this mode, be careful not to spoil the set. Mark all the initial values on a paper for refernce, and begin to chage the values. You may only have to chage the value of "SC".
Nov 22, 2010 | Samsung TXJ3678 36" TV
As paper is exiting the printer going into the upper delivery area, the paper gets crinkled. Is it something with a roller?
yes i guess so, try cleaning the roller throughly also check if you have any bits of paper all the way through the module
pls rate it it was any help
Jun 30, 2009 | HP LaserJet 1300 Printer
Frequent paper jams with my Konica 2223 photocopier
I wish I could help you, You need to call for service for your copier. An authorized dealer or Konica minolta branch service in your area. You might need a fuser unit that the upper separating claws disloge or broken, exit paper detect actuator is broken or disloged, or you need a new developer.
Feb 05, 2009 | Konica Minolta DiALTA Di200 Copier
How do I get a louder ring on my blackberry 8700
From profile on desktop choose Loud and activate - The megaoohone logo at the top of the homepage should now have a red outline.
Jan 23, 2009 | RIM BlackBerry 8700g Smartphone
No pink tone in skin tone
are you using genuine or compatible cartriges?
never use compatables for photos - keep them for documents etc
Nov 18, 2008 | Canon I900D InkJet Photo Printer
Oh, it's the colors you are having a problem with. Then you probably want to perform an Auto Gradation Adjustment. It's on pages 162-163 of the manual found here: http://download.support.xerox.com/pub/docs/DocuColor_3535/userdocs/any-os/en/3535_User_Guide.pdf
Here is what it says:
Auto Gradation Adjustment is a color calibration for the copier and printer. An Auto Gradation Adjustment compensates for differences between the actual and the expected toner densities for each color. An Auto Gradation Adjustment should be performed whenever there is a noticeable change in the appearance (quality) of the output, particularly changes in color
tones or densities. Performing an Auto Gradation Adjustment on a regular basis will help to maintain consistent color quality over time.
NOTE: Since an Auto Gradation Adjustment can affect all jobs for all users, it is recommended that this procedure be performed only by the Machine Administrator.
Copy Job - Text Compensates tones when a text original is copied.
Copy Job - Photo Compensates tones when a photo original is copied.
Print Job Compensates tones when printing with controller line screen.
Network Controller - 1 Compensates tones when printing with Network Controller screen type 1.
Network Controller - 2 Compensates tones when printing with Network Controller screen type 2.
NOTE: Printing the chart for Auto Gradation does not increase the meter count.
NOTE: When gradation adjustment is executed, the following
changes will be made to default copy settings set in System Settings mode: Copy density = Normal or Auto, Color Shift = Normal, Saturation = Normal, Color Balance = 0, Sharpness = 0.
NOTE: When Print or Network Controller gradation adjustment is executed, the printer’s output profiles for the available screen types are compensated.
1 On the Image Quality Adjustment screen, select Auto Gradation Adjustment.
2 Load 8.5x11 inch or A4 paper into Tray 5 (Bypass). Move the paper guide to gently touch the edge of the paper.
3 Select the desired gradation adjustment screen:
• Copy Job - Text
• Copy Job - Photo
• Print Job
• Network Controller - 1
• Network Controller - 2
Press Start. The Adjustment Chart is output.
4 Place the Adjustment Chart face down on the Document Glass with both Magenta color patches against the left side of the glass.
5 Place 5 sheets of white paper on top of the Adjustment Chart and close the DADF. Select Start.
6 To continue Auto Gradation Adjustment with other screens, repeat steps 2 to 5. When you are finished, select Close until the System Settings screen is displayed.
7 Select Exit to exit the System Settings mode.
Jun 24, 2008 | Xerox DocuColor 3535 Copier
13 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
CheckitRight
CheckitRight
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
