Question about Gateway M505 Notebook
I can't charge the battery . it is new and computer works
Why does system battery not charge ? new battery and new charging kit show no improvement on laptop. well charged battery works but not recharging.what is wrong ?
well this is a hardware problem.in this case your charging stage is not work.i am showing you a picture in the yellow marking fat 's are shorted if you can change these components the issue will be solved.sorry for bad english.
Jun 18, 2014 | Dell Inspiron Mini 10 N450
My new battery is not working with my Sony vaio laptop
What do you mean the new batter is not working? Does the computer turn on with the Power Cord? If not, the power cord is bad and cannot charge the battery. I have seen times when new batteries are defective. The new battery does not come charged so you have to plug in the power cord and let it charge overnight.
Apr 06, 2012 | Sony Computers & Internet
NEW Battery not properly charging
Batteries have electronics data that software has to get to properly charge it. Newer lithium batteries maybe different. But apparently, you have a work around for a lengthy use of the new battery.
Feb 16, 2012 | Gateway MD7818u Notebook
My computer no longer charges. I replaced the charger and for a little while the new charger was working. But now the new charger will be in the charger portal and the computer does not charge at all once...
this problem comes from a bad Battery.
you told:"I replaced the charger and for a little while the new charger was working"
it means that the battery is damaged and only because of a new charger, charged for a little time.
so change the battery.
Jan 17, 2011 | HP Mini 1035NR Notebook
I have a Dell XPS M1210 laptop for which I have just purchased a new 9-cell compatible battery. It worked great for a couple of hours, but now shuts off immediately when unplugged from the AC power supply....
You might want to try what I did when I had a completely discharged battery for my Dell Laptop. I attached the battery to the computer, make sure the computer is off and plug in the charger for a full twenty four hours (undisturbed). And this really worked. I had no problems with the battery. Good luck.
Feb 26, 2010 | Dell XPS M1210 Notebook
Got a new battery for Dell Inspiron 6400 but it won't charge
well if it's a new battery and you're having issues send it back, you may need to calibrate your new battery with the laptop
Nov 06, 2009 | Dell Inspiron 6400 Notebook
I replaced motherboard on nc6400 new battery new charger but still not charging what can be the reason???? the laptop work on AC power Work on the new battery i charged it on other computer????
Because of BIOS. Basic Input/Output System.
Battery has 'lost track', of what the battery state of charge is.
Try Recalibrate BIOS
http://laptopbatterynews.com/2009/04/22/bios-says-to-recalibrate-my-laptop-battery/
Aug 21, 2009 | Computers & Internet
IPOD Video 30gm
Hold down on the center button while hold down on the menu button. The apple logo will appear. Your Ipod is now rebooted.
Is the new battery fully charged? Usually it takes 6 hours on a new battery.
Jun 08, 2008 | Apple iPod MA446LL/A MP3 Player
New battery not charging
It is normal for a battery to degrade after a year since its a consumable part. It's just like any ordinary rechargeable battery. We have 2 points of failure that might be causing the problem. First the battery itself. Second the Charge board that charges and detects the battery. Given that the NON-DELL battery is working on other dell Computer, it simply tells us that it is the charge board that needs to be replaced wich is integrated to the motherboard. If your warranty is still active, call dell and tell them that you've tried a Known good battery and its still not charging. However, you might also consider that dell computers are designed for dell batteries. the charge board might have problems charging the third party battery since its not configured to do so.
hope this helps.
Demmy
Dec 10, 2007 | Dell Inspiron 6400 Notebook
Gateway M505 Notebook Logo
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
