Question about Maytag Neptune MDE5500AY Electric Dryer
The dryer only has heat in the two sensor settings. Sensor Dry: wrinkle control and regular.
    Problem Solver:
  • 9 Answers
This is a complicated machine with computer boards and thermistors. Unless you are a Technician or plan on becoming one, you should call a qualified technician.
Posted on Dec 28, 2010
Wrinkles clothes terribly. Solutions.
Check your settings on your dryer. See if it's on a longer duration of time to dry. Dryers have different wording depending upon the make and model. If you're trying to dry smaller loads the heat settings s
does not have to be set for very long. Heavier, loads with thicker clothing will need to dry a little longer. When you take the clothes out of the washing machine, do you shake the clothes before putting them in the dryer? And do you use dryer sheets? Believe it or not, they're not only used to help make your clothe's smell fresh but they also help elevate static and a few wrinkles.
Mar 23, 2015 | Washing Machines
LG DLG2251W won't heat up
Your post is from 2008 but I am having the same problems with this dryer, same model. This is an LG problem, for crying out loud LG ---- GET IT FIXED. No more LG dryers for me. My $300 Kenmore works like a charm.
The first LG dryer they sent me I thought was a lemon. They came out and replaced the motherboard on the brand new dryer. They came out again and couldn't figure out why it wouldn't dry my clothes, and the second time they gave me another brand new dryer. Same problem with this one and all brand new perfectly clear ducts. Really?????
Google "lg dryer spins but no heat" on youtube - he explains how to get to the sensor and reset it, but still trying to figure out where to find it on my model. I can't believe I have to go through all of this with a $1000 machine!! Never ever again. Avoid LG dryers at all costs. It takes me HOURS to dry a load of laundry. Wanna throw a dry piece of clothing in the dryer for a few minutes to get the wrinkles out? hahaha think again. The heat will never come on even with the manual (non sensor) setting.
Again = AVOID LG DRYERS AT ALL COSTS. It's not worth the headache.
Nov 25, 2012 | LG DLG2251W 27" Front Load 7.1 Cu. Ft. Gas...
No heat in my gas dryer, ignitor replaced, and sensor dry level does not light? I miss my dried clothes!
It sounds like your thermal fuse blew which is very cheap and easy to replace. Unplug your dryer and gain access to the back panel. Remove the panel and locate the thermal fuse. It is usually a white piece of plastic about 1/2" wide and 1 1/2" long with two wires attached to it. (Generally located near the bottom left as your looking at it) Unplug the two wires and unscrew the screw holding it in place. Replace it with the new one and reassemble everything. Good luck!
Apr 10, 2017 | Maytag Neptune MDG5500AW Gas Dryer
I have an electric Estate Dryer made by Whirlpool TEDS840PQO. It has "Timed Dry", "No Heat Fluff" and "Auto Sense Drying" settings. On the Auto Sense Drying it has...
Verify that the wrinkle prevent switch is good. If so, the timer is likely the problem. Sometimes the switch contacts inside the timer can be cleaned to restore operation, bit it is a tricky item to disassemble and reassemble.
Mar 07, 2017 | Dryers
Hi, I have a Maytag dryer, model # mdg308daww Legacy series. It heats up just fine, dries clothes great but the problem I am having is that the Auto dry features are not shutting off as they were before....
you may need to replace the moisture sensor bars inside the dryer.also you may need to check the air flow if timed dry is nnot drying them properly
Dec 19, 2010 | Dryers
Dryer is not heating up to dry clothes
The spark ignitor maybe at fault. Listen for the clicking noise upon starting it up the first 30 seconds it runs. If not heard it is in need of a replacement
May 01, 2010 | Amana NED7200TW Electric Dryer
The Dryer heats up for a while and the stops heating after running for a while.
Without the specific model number to work with, I'm taking a guess that your dryer has a sensor at the back of the drum. That is the dryness sensor that the clothes rub against and let's the dryer determine if the clothes are dry, according to the setting you selected on the control knob.
First thing to do is use some Windex on a clean cloth to clean the senor strips as use of dryer softener sheets can leave a residue that builds up on the sensor and could be causing it to stop.
The other thing you can do is use the timed dry cycle to see if the dryer works correctly. If the dryer works OK in the regular timed cycle, then it is possible you have a defective sensor.
Without more information about your dryer, It is difficult to provide more possible diagnostic steps and provide you with a possible solution.
Jul 28, 2009 | Whirlpool Dryers
Maytag Neptune gas dryer sense dry time at 99, little or no heat
If this is a gas dryer, I'd suggest an inspection by the gas company or qualified technician. If the jets aren't firing correctly, you are wasting gas and possibly creating a hazard.
Mar 21, 2009 | Maytag Neptune MDG5500AW Gas Dryer
My LG dryer shuts itself off during the normal cycle and a dotted
OK, here's what it sounds like to me: The line going around the display should only be seen if you selected "Wrinkel Care" function for that cycle (and with the freshen up cycle, I beleive). With that option in use, after the dryer shuts off, if you do not open the door or turn off power to the dryer the dryer will display the moving rectangular segments and every 6 minutes the dryer will turn itself on and tumble for 10 seconds with no heat (to keep clothes fluffed up and prevent wrinkles from setting in) and will continue this cycle for up to three hours. The "Freshen Up" is the steam cycle used to remove wrinkles from 1 to 5 garments, like things that were all wrinkled up in your suitcase. Try drying with a normal or permanent press cycle, or a timed cycle. If you have additional questions or concerns, let me know.
Dec 06, 2008 | LG WM2077CW Laundry XL Front Load...
Moisture Sensor Location
It could be the sensor. However, check the exhaust vent for restrictions first. you can test the moisture sensor Damp Dry Test 1. Set the following Timer- DAMP DRY Fabric Care/Temperature switch- COTTON HIGH Wrinkle Guard switch- OFF Signal switch- LOUD Door- must be closed 2. Press the PUSH TO START switch. After approximately 16 seconds, the Timer will start to advance to the OFF position, and the ?End of Cycle? signal will sound. If one or more of these functions do not occur, proceed to the Factory Test. Factory Test The Factory Test allows factory/service personnel to test and verify all inputs to the Even Heat control. The basic operation of this test is to notify the operator with an audible beep every time the status of an input to the control changes state. Activating the Test Mode 1. Set the following configuration: Door- must be open Fabric Care/Temperature switch- AIR FLUFF Signal switch- LOUD Timer- TIMED DRY OR AUTO MOISTURE SESING PLUS selection 2. Turn the Wrinkle Guard switch from OFF to ON three times within a five second period. A single beep will sound to indicate that the factory test mode is activated. NOTE: If any of these initial conditions are not satisfied, the control will not enter the test mode. Test Mode Functionality When the control is in the Factory Test mode, every input change of state will result in a beep (with the exception of the Signal switch). This includes: Door switch Moisture Sensor (short/open Sensor will result in a beep) NOTE: A moistened finger or damp cloth may also be used. Fabric Care/ Temperature switch Wrinkle Guard switch Push to Start (PTS) switch (with the door switch closed) Timer (any cam input change will result in a beep) NOTE: Timer will advance during test. If any of the inputs do not result in a beep, proceed to the following component tests If the dryer shuts off too soon when set to the AUTO MOISTURE SENSING PLUS cycle, check the following: -HARNESS/CONNECTION -MOISTURE SENSOR -THERMISTOR -EVEN HEAT CONTROL Procedure: 1. Test the Moisture Sensor by following the procedure outlined in ?Factory Test?, beginning on page 3. If the Moisture sensor fails the ?Factory Test? (does not produce a beep sound), check the Moisture Sensor. a. If there is continuity to Ground for Yellow/Red (Y/R) wire with no load, look for a short in the Sensor or Y/R wire. Verify harness connections both at the Sensor and the Even Heat control. b. If the Sensor and Y/R wire are good, replace the Even Heat control. 2. If Factory Test passed, verify thermistor by performing test procedures outlined in ?Thermistor Test? 3. If problem persists after replacing Moisture Sensor and thermistor
Aug 27, 2007 | Kenmore 62972 Electric Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
