Question about HP Pavilion 520N PC Desktop
Regarding turning on my HP pavilion 520n, I have noticed that there are no obviously blown capacitors, and that the green led on the back which is lit when I plug it in, shuts off when I push the power button. It will come back on if I hold the power button on for about 8 seconds. Does this further confirm either the power supply or motherboard is suspect? thanks
    Genius:
  • 1,288 Answers
Difficult to say at this stage. If the fans on the PSU spin when the power button is pressed in and held, it would indicate that there is power to the PSU, but that does not rule out a faulty PSU
I'm suspicious about the fact you need to hold in the power button, which is normally a way of switching OFF the computer.
Might I suggest you try the following:
1.) As suggested before, remove the power switch connector to the Fpanel header on the board (should be labelled PW or pW switch). using two single pin connectors on the end of a piece of wire, connect them to the pins (does not matter in which order). Plug the computer in and touch the ends of the wires from the pins together briefly, if the computer boots, then the issue lies with the switch aseembly. If you are unhappy about doing this, you can use a multimeter set to the ohms scale and place one probe in each of the wires that go to the switch. Press the switch and hold it and see if you get a reading.You should get a reading and this will drop as soon as you let go the switch
2.) Replace the power supply and see if that works. This is the second cheapest option.
3.) If a new PSU does not work, then the issue must lie with the motherboard. I'm assuming you have already checked that the main multi cable is FIRMLY in the socket and the subsidiary 4 pin Black and Yellow cable is in the seperate socket
Posted on Dec 28, 2010
Green light on my power supply stays lit after unplugging
Usually the light will time out after the capacitor has drained. Your machine is getting a bit old , your PSU may be the problem. If you plug it in and push the on/off button and it blinks, fans spin and shuts down, it's most likely the PSU. Look for a in-line fuse on the Motherboard, if blown, replace. Look at the motherboard closely for damaged components, capacitors, etc.
Jan 27, 2013 | HP Pavilion A820n (PP165AA) PC Desktop
HP Pavilion F1523 monitor. On powering up, green LED flashes. Screen goes grey briefly, then blank. Green LED continues to flash.
This is very old monitor, 3+ years, so more likely that it has bad set of DC filter capacitors in the power supply.
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed HP monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Please leave rating if it helps.
Jan 22, 2011 | HP Pavilion F1523 15" LCD Monitor
The light on the back of the hp pavilion 520n is lit when it is plugged in, but the unit will not start up, nor do the fans run. Does this mean the power supply?
Possibly, you can subsitute a known good one and test it, however, there was an issue with some hP boards the "sunshine" mobo had a tendency to blow capacitors for example after some time. If the new PSU does not work it is likely that it may be a fault on the mobo.
Before replaing the PSU, check the mobo for bulging/ blown/ leaking capacitors (the small cylinder shaped components with a X on the top). If any are leaking or blowing ( bulging) the mobo is on its last legs
Dec 28, 2010 | HP Pavilion 520N PC Desktop
My "hp pavilion a220n" won't power on. ... I was
Pull the power cord out and press the power button on the PC to drain the power for 10 seconds. Then plug the power cord back in and turn the computer on. If still does not work, then the power supply may be blown out and needs replacement.
Dec 23, 2010 | HP Pavilion a220n (DK218A#ABA) PC Desktop
My hp pavilion a430n is not turning on. even though i pressed the power button the light wont even turn on. it is truly annoying and the screen says something about the power supply and green, red, blue...
I suggest to open your computer and unplug your power supply and look for the color green and black cord which plugged from your motherboard. Then find a piece of wire and short the color green and black wire to test if your power supply is working and plug to your power socket. And check your electronic parts (capacitor) near at your processor, it might your capacitor blown out.
Nov 15, 2010 | HP Pavilion a430n PC Desktop
I plugged in my tower and i heard a loud high pitch beeping sound the green led light in the back was on but the power button turns green and the green led light in the back turned off there is no signal...
the green led light is it beside the network cable connector. if it is so, then it is always meant to be like that when you power up your computer. it is not something serious and it is normal.
Aug 18, 2010 | HP Pavilion 533w (P9859AR#ABA) PC Desktop
I have a Hp laptop Pavilion (pav 9000 series) with a blown fuse
Unfortunately I think HP warranty policies state that you can only change by yourself  the components covered by dedicated doors on the chassis bottom, such as the hard disk drive and RAM(obviously your upgrade parts are not covered by hp warranty and not supported by hp support).
So regaldess of how complicated the damage is to fix(most of the led indicators are soldered on the motherboard) you need to call  the HP support and they will fix it, they are usually fast and you will have your laptop back in a week or so...otherwise you will probably lose your warranty if you try to locate and replace the fuse,replace the LEDs, replace the connectors...
it might be a connector plugged backwards but you should not directly try to fix it.
Feb 13, 2009 | HP Pavilion dv9000z Notebook
HP a 520n clock battery
On the mb... silver disk. Is Ur clock resetting after power down?
Jun 13, 2008 | HP Pavilion A520n (DW233A#ABA) PC Desktop
Intermittent power on problem, monitor now completely dead
See other post regarding IC901 Please feel free to RATE me if it helps
Aug 27, 2006 | Dell UltraSharp 1800FP 18.1" LCD Flat...
HP Pavilion 520N  PC Desktop Logo
59 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
