Question about Bose 3 2 1 GSX System
I have a samsung 46 inch lcd television that is 2 years old,,, i barely have 36 inches clearance between it and the acustimas module and it is causing interference with the television,(a blurred and darkened picture) because of the layout i cant move it any further.. Is there something i can use to shield the television?
    Brigadier General:
  • 8,546 Answers
ONLY CRT-TV's are prone to magnetic interference so you may want to rethink the cause. Are you sure the acoustimass module is the culprit? Routing all signal cables away from or as non-parallel as possible relatiev to power cables and sources of magnetic fields might help prevent leakage through the cables.
Posted on Dec 29, 2010
My 46 inch samsung has a picture distortion, it's like it has a mirror image , how can i fix this?
Anthony, you did not list a model #. If you would it makes it eassier to determine what may have happened with your Samsung TV. An LCD would start with LN46----.
I have had screen issues with some samsung product. As well as other makes of televisions that use Samsung 46 inch dislay lcd.
Mar 02, 2013 | Samsung LN-T4661F 46 in. LCD HDTV
Samsung 46 inch lcd
Send your email address to me by Fixya, and get back a copy of it by return mail.
Sep 04, 2012 | Samsung UN46D6400 46 Inch 3D 1080p Smart...
Samsung ln-t4661f 46 inch lcd tv top 25 percent has faint lines going across please give answer to this problem
as i knew from my friend there is part called C1 OR C2
it is scan board connected from screen module from one side and then other side ether direct to power supply or to main analog board that got signal from main digital video board, that is what i knew.good luck search this on eBay or get other opinion.
Apr 28, 2010 | Samsung LN-T4661F 46 in. LCD HDTV
Have a Samsung 32 inch lcd tv 720p only a year old tv will not come on but power button is lit up
Most likely defective capacitors on the power supply module. Every model of LCD has this issue so don't feel Samsung is a inferior product. It is an excellent product.
Nov 27, 2009 | Televison & Video
I have a 42 inch samsung and the sound is fine
Is it still covered under warranty?
If not - you have a bad processing board and will need to be replaced.
Blessings,
A/V Guy
Nov 19, 2009 | Samsung LN-T4665F 46 in. LCD Television
My 46-inch Samsung LCD TV screen went black. Audio works.
If you are seeing light then the back light is working. Can you get a menu?Do any of the other video inputs work? If no video but has backlight and no men or any on screen display replace main board.
Sep 13, 2009 | Televison & Video
I have a 46 inch Samsung LCD model number LN-T4665F and I have been having issues w/ the power/ clicking sound! It used to turn on and clicked a few times now just clicks all the time and doesn't turn on...
1. It is not a two years old TV, but a 9 years old one.
2. The common problem of the symptoms is a defective main power supply, you may check to see that are there anny "Pup-Up" electrolytic capacitor on the power supply, if there is any, replace them, you may fix up the TV
Jul 02, 2017 | Samsung LN-S4692D 46 in. LCD HDTV
Thin Vertical Line top to bottom about 2 inches from the right.
Probable panel is bad. contact mitsubishi maybe they will do somthing for you.
Jun 26, 2009 | Mitsubishi WD62527 62 in. LCD HDTV
Complete black screen on samsung 46 inches
Thats Samsung for you. They are designed to last just right outside the warranty then fail. Typically the LCD panels are bad, and they are the most expensive part on that Korean unit.
Sep 07, 2008 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Your Samsung Answer
Its a must that we return the unit!! There is no excuse for defective product... I dont know how old your unit is bought from the store, but mine is just 2 days old, bought the 52 inch Samsung Series 5 from Fred Meyer (Krogers) on sale for 2 grand - regular 3 grand - but it was on closeout I presume... ( I want to watch the olympics in HD and now look! This is so depressing! What happend to your first Samsung Unit? What was the:
Screen Size
Image Resolution
Make Year
Regaurds
Jun 09, 2008 | Samsung LN-S4692D 46 in. LCD HDTV
Bose 3 2 1 GSX System Logo
101 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
