Question about Uniden 5.8GHz Cordless Phone
I have Uniden 5.8 GHz dual phones. One phone will not register at the main base. The other phone registers, but has static on the line instead of dial tone. Dial tone is good to the phone.
  • 61 Answers
I would call uniden. :)
Posted on Dec 28, 2010
CAN NOT CLEAR WATER PROOF DECT 6.0 PHONE TO REGISTER IT SAYS TO PUT ON BASE BUT I WANT TO REGISTER ON MY OTHER UNIDEN BASE BUT PHONE WON'T FIT ON BASE
Not stating the model number of your phone makes it a bit difficult because the process is not the same on all models. I am going to deal with the cordless main base only Remove any handset from the main base cradle. Then
On the waterproof handset Press and Hold the # sign until the Registering handset option shows then release it.Then on the main base, Press and Hold the FIND hs or Find or locator button for 5 seconds ( if there is no IN USE light on the base) or until the IN USE light come on, then release it. Hold the handset near the base and it will register.
Please note the Uniden waterproof handset could be a bit tricky to register and not knowing the model makes it more difficult. and you may have to apply other methods.
May 03, 2017 | Uniden Lands Phones
I have three handset cordless phone only the main base phone work the other two says connecting when you turn it on but it wont connect it have loss its connection with the base phone
Often the handsets must be re-registered when they won't work. Sometimes they have to be de-registered, then re-registered before getting them to work. Uniden has many different model number 5.8 GHz cordless phones, send a comment with the model number and I will give specific help on your cordless. I have included a link where Uniden cordless manuals can be downloaded if you need it.
http://www.uniden.com/index/manuals_results.cfm?cat=1
Mar 27, 2011 | Uniden 5.8GHz Cordless Phone
Uniden TCX905 cCordess phone Handsets # 3 and 4
If the handsets are not currently registered to any base, the SYSTEM RESET menu won't appear.
If the TCX905 handsets in question are actually expansion handsets from another Uniden Phone System, they are not true TCX905 handsets. To verify, remove the battery cover and battery, then look at the inside label. If it lists the model of a TRU9xxx phone system, your handsets are NOT TCX905.
Uniden unfortunately has programmed the expansion handsets from SINGLE LINE TRU9xxx phone systems to NOT REGISTER against the TRU9466. (Those same handsets register fine against predecessor model TRU8866 though).
Jun 14, 2009 | Uniden 5.8GHz Dual Cordless Phone
Uniden 2.4 GHz cordless phone won't register to base
Same happened to me. Unplug the base from power and the phone line for 30 minutes. Same for the handsets - all. Take out the batteries. Retry. After it says 'registration failed'. Leave it in the cradle. Several minutes later it found itself.
Mar 10, 2009 | Uniden 2.4 GHz Cordless Phone System
Uniden 2.4 ghz model- dxi7286-2 wont register.
Did you pay the phone bill? Plug in the phone cord? Ive seen people do it and say" But It's cordless I shouldn't have to plug it in ...Right?""
Jan 20, 2009 | Uniden DXI-7286/2 Cordless Phone
PHONES DON'T WORK
Switch the phone off at the Mains 5 mins,
Re-register the phones to the base unit.
Your manual will show you how.
Should be good then.
Regards
Richard.
Jan 06, 2009 | Uniden TRU9585-2 5.8 GHz Twin 1-Line...
No dial tone on handset
It may not be registed with the main unit. You may need to register the handset. With my uniden all i have to do is put it in the main base until it says what handset it is (it should be a number).
If you have any questions please dont hesitate to ask
Sep 25, 2008 | Uniden 2.4 GHz Cordless Phone System
Tru9466 base and tru9465-2 handset
Same manual as lethean provided on a similar post but Page 24 if the previously used Base is Unavailable and your phone shows "Deregistration" in the Menu.
Base Unavailable (Handset Only)
To clear the base registration data in the handset, please follow these steps:
Press and hold [] and [#] for more than 5 seconds. Select the BASE UNAVAILABLE submenu.
BASE UNAVAILABLE appears. Move the cursor to select YES, and then press the OK soft key.
ARE YOU SURE? appears. Move the cursor to select YES. Press the OK soft key.
Mar 10, 2008 | Uniden TCX905 Cordless Accessory Handset...
Constant static and interference
FIRST YOU MUST DETERMINE IF THERE IS STATIC ON YOUR PHONE LINE. EVEN WITH DSL THERE CAN BE STATIC EVEN IF THE INTERNET IS WORKING. IF YOU HAVE A CORDED PHONE TAKE IT OUT TO THE PHONE INTERFACE BOX AND OPEN THE BOX / THERE SHOULD BE A PLACE YOU CAN UNPLUG YOUR WIRING FROM THE PHONE COMPANY. PLUG YOUR PHONE INTO WHERE YOU UNPLUGGED THE WIRING AND SEE IF YOU HAVE STATIC THERE. IF YOU STILL HEAR STATIC IT IS THE PHONE COMPANY'S PROBLEM.
SOMETIMES UNPLUGGING FROM BOTH THE PHONE LINE AND THE POWER SOURCE AND REMOVING THE BATTERIES WILL CORRECT SOME PROBLEMS. FOR SECOND PHONES ON A SYSTEM THEY MUST BE REGISTERED TO THE BASE. ONCE IT IS REGISTERED IT SHOULD SHOW A NUMBER IN CORNER OF SCREEN (2)
THE MANUAL SHOULD TELL YOU HOW TO REGISTER SETS. IF YOU HAVE LOST YOUR MANUAL SEE IF YOU CAN DOWNLOAD ONE FROM THE WEB SITE OR CALL VTECH 1-800-595-9511
Dec 05, 2007 | Vtech 5.8GHz Analog Cordless Phone
Uniden 5.8GHz Cordless Phone Logo
237 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
