www.do-it-yourself-washing-machine-and-dryer-repair-help.com/belts-... To check and replace the belts in your Maytag washer do the following ... With RepairClinic's 365 Days return policy you could try any parts, if the new part ... Belt Kit - Part # 402507 Mfg Part # 12112425 · Motor Mount Spring Kit - Part ... Copyrighted 2011 Do-it-yourself-washing-machine-and-dryer-repair-help.com All rights ...
https://www.maytag.com/manuals/ MaytagSearch Manuals & Use and Care Guides. Enter your appliance model number to access your Use and Care Guide and any related appliance literature. Use the
Actually, it sounds like you have two problems. The belt and the bearing. The squelling is probably the belt but the screeching is probably the bearing and was the original problem that caused the belt problem.
Nearly every appliance store and appliance repair shop sells replacement belts. Your area Sears / kMart retail store will have them, too. Many hardware stores sell them as well.
if you don't mind waiting, you can find them online, too. Here's a list of places that Google found for Maytag Belts. You should use a combination of Maytag dryer model number and the number that appears on the belt to obtain a replacement.
Check the drive belt and belt tensioner. From the way you describe it, the belt is loose and with a load in the drum, it will not rotate due to belt slipping.
i lifted up the top and unscrewed the front of my maytag dyer pye4500ayw a very thin belt was at the bottom. who do i replace this belt and where does it go?
Go to repairclinic.com and click on the "Repair Help" link at the top of the page. On the following page, locate the "Dryer Belt Diagrams" link under the "Special Features" section. Scroll down to Maytag. The dryer belt diagram for Maytag should be listed as diagram E. I hope this helps you.
