Question about Kenmore Sewing Machines
I have a Kenmore 8 sewing machine. The thread will not pick up from the shuttle. I've taken the machine apart and still no luck. The thread bunches up.
    Genius:
  • 1,788 Answers
I am hoping that it is not the timing. Try this, insert a new needle (flat side facing away from you), clean and lubricate, totally rethread. Good luck
Posted on Dec 29, 2010
Kenmore 385 sewing machine
Can you remove the bobbin? Clear any thread out - then check the tension on the bobbin case. Use Good quality thread.
Good luck
Oct 18, 2013 | Sewing Machines
I have a LS1217 ..it was working fine then I had to refill the bobbin...that went normally but when I tried to see again e the needle thread is getting caught up and not picking up the bobbin thread. I...
have you tried a new needle
try turning the bobbin the opposite direction in the bobbin case
make sure the top thread has not come off the thread take up lever
Mar 20, 2013 | Brother LS-1217 Mechanical Sewing Machine
I have a Rex-607. I have used it twice sewing canvas for a boat enclosure. Now the needle will not pick up the bobbin thread. I have taken it apart, cleaned and oiled, adjusted the needle. Still all it...
Well, start by changing the needle. It is very likely to be worn.. and causing you a problem. Also take a look to see where the shuttle point ends up in relation to the needle when the needle is at it's lowest point.
The shuttle point should be just right behind and above the eye of the needle. If it is not... call a repair guy or your dealer for timing help.
Dec 23, 2012 | Rex RX-518
Needle cannot pick up bobbin thread
Remove the needle plate and watch for the hook to come around. You want to see were the hook meets the needle. it should intersect just a bove the eye. I posted a tip on checking your sewing machine timing, check it out.
Jun 02, 2010 | Kenmore 11206 / 11306 / 11506 / 11606
I have an older kenmore sewing machine. It's been
When I have run into similar problems with my older Singer, it's because there is a bit of thread caught somewhere in the bobbin mechanism that doesn't allow the shuttle to run freely. Take the bobbin assembly apart and use a bright light to see if you see any bits of thread in there.
Good luck and let me know if this works!
Jan 14, 2010 | Kenmore Sewing Machines
Kenmore Sewing Machine: stitch not forming bobbin thread problem
sounds like it needs a service call. if you do not have a sewing repair man you use regularly to clean machine the local fabric store should know who you could call.
Jul 20, 2017 | Kenmore Sewing Machines
Tread getting hung up in the shuttle
HI!
In most cases when thread is nesting, bunching, ect..it is a result of top threading. Be sure that you have the thread through the proper threading guides,most importantly, the "take-up lever" (that is the silver hook that moves up and doen in time with the needle). This should resolve the problem regardless of the machine.
Bonnie
Sep 26, 2008 | Sewing Machines
Shuttle
The bobbin should be placed in the shuttle, with the needle at the top end travel. You can watch the shuttle move as the hand wheel is turned.
Jul 09, 2008 | Sewing Machines
Kenmore 385. 11607 needle jams into shuttle or shuttle race
I had the same problem with cleaning and jamming and this might sound silly, but when you're in the middle of trying to fix it remember to look up see that it is threaded up top. I did everything the pp's suggested and when they didn't work I realized the top thread wasn't still threaded around the tension thing anymore. After rethreading it, it worked fine. But I DID reduce the amount of thread on the bobbin at the same time as Drazil suggested.
Dec 17, 2007 | Kenmore Drop-In Bobbin 505S-21BH...
Sewing Machines Logo
32 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Douglas Plant
Douglas Plant
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
