Question about GE PDS18LBMWW Bottom Freezer Refrigerator
Need to reset the fridge timer - GE PDS18LBMWW Bottom Freezer Refrigerator
My Maytag MTB2156DEB fridge died. Electricity is on, lights are on but nobody home, I.E., no cooling. my old fridge had a "reset" button which I found out after the repairman charged a bundle to press. ...
Your model doesn't have a reset button, this is non-electronic. First, tap on control panel to see if cold control is stuck. (tap on beat) If it starts it could be a bad control. Does to compressor click like it wants to start? Lastly, there is a defrost timer within the control housing, with a screwdriver rotate the timer slowly to see if the timer is stuck. If the unit starts running it could be that the timer needs to be replaced. Get back to me and I can help further if needed. Good Luck
Mar 07, 2015 | Maytag Refrigerators
Freezer not cooling. How do I reset
sorry never heard of a reset for freezer cooling. are u saying the fridge cools but not the freezer? that would be highly unlikely though. u may have a bad air flow or fan? low freon issue? u can reset the defrost timer and see if it restarts the fridge by inserting a flat head screw driver in the tiny slot at the center of timer and turning it till it clicks twice
Jan 14, 2015 | Refrigerators
I have a bosch fridge freezer model kgu3220 gb. It is ten years old. For the last few days, the fridge isn't cooling but the freezer works fine. The temperature on control panel is stuck on 11 degrees. I...
Once the fridge is shut OFF for few hours to defrost and then switched ON , if the fridge works with cooling , then the fault is with the AUTO DEFROST TIMER or the circuit -maybe the heater, break in the lines to the timer, heater, the fan.
The build up frost will block the flow of cool air to the fridge from the freezer evaporator.
So remove and check.
Jan 13, 2011 | Bosch Refrigerators
I have a Frigidaire FRT04GM fridge. The Fridge stopped working. I looked in the back and found what appears to be a timer with a small opening for a screwdriver. I reset the Timer and it worked for about...
I think you are thinking correctly...:-)
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 21, 2010 | Frigidaire Refrigerators
Is there a reset switch on the fridge to use after the fridge has been unplugged for a long period of time? Crosley
No, You might want to check the plug. The timer could also be stuck in defrost. Find the defrost timer and manually spin it. Rate me. Thanks
Aug 26, 2010 | Refrigerators
Compressor is not running is there a reset switch
damage was caused by electrical problems, you can check from Thermostat, whether still working or not. then check the timer on your fridge, the timer's function is to turn off and turn on the compressor, periodically. and do not forget to check the overload / thermal protector and relay (PTC) attached to the compressor.
Jul 30, 2010 | GE GSS25SGMBS Side by Side Refrigerator
Ice accumulating behind plate inside freezer......have had all components checked, all ok, aside from perhaps the timer.......found an interesting tidbit somewhere about being able to reset a digital timer...
you may need to replace the defrost timer.the more likley cause would be a faulty defrost sensor not telling the timer when to defrost.
Part # 5303918214-Defrost sensor
Part # 240375803- Adaptive defrost timer
Jun 28, 2010 | Frigidaire FRS23R4A Side by Side...
KitchenAid fridge model #EE4412201, freezer is NOT defrosting. Air tower iced up a little, freezer floor all ice. water in back of fridge. Freezer is cold, fridge isn't. I cleaned the freezer, took the...
try a new defrost timer. or new kit defros timer defrost terminator and heater. tfound the timer rotate, open the freezer. if you hear a noise like ICE BREAKING. your onli problem is the timer. really important after repair your fridge. allow at least 24 hr for defost the whole evap. REALLY IMPORTANT
Mar 31, 2010 | Refrigerators
My kenmore electronic fridge keeps building frost on the back wall i cleaned out the reservoir in the fridge part where the water drains and ran some hot water through and it worked ok for a couple of...
check defrost timmer or defrost heater if the timer is working find the timer and turn the knob tell it clicks if it defrosts in a few min then you need a new timer or turn it manualy every few days
Oct 19, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Warm Fridge
the defrost timer/ board is getting stuck in defrost and when you unplug it and plug it back in it resets the defrost timer/control board. you may need to replace the defrost timer/control board.
Jun 19, 2008 | Frigidaire PLHS237ZD Stainless Steel Side...
GE PDS18LBMWW Bottom Freezer Refrigerator Logo
15 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
