Question about Olevia LT32HVM 32 in. LCD Television
Can not get signal from cable box - Olevia LT32HVM 32 in. LCD Television
    Genius:
  • 1,126 Answers
Unplug the TV and the cable box for 40MIN, and that should reset everything back to normal.
Posted on Dec 28, 2010
My digital tv is saying no singal whats the problem and how do I fix it? we have a huge antenna on our roof
1 – Is the NO SIGNAL issue happening on just one TV?
CORRECT INPUT or SOURCE
If it is just one TV that is showing the NO SIGNAL…
-Be sure your TV is on the correct source or input as your CABLE or SAT BOX.
-Press the TV button on TV remote control to turn your TV ON.
-Press the INPUT button on your TV remote control.
-Cycle through all the inputs on your TV.
-Do this until you are on the INPUT your CABLE or SAT BOX is plugged into.
-You should then see the CABLE or SAT programming show on your TV.
HINT: Your TV will most likely list the TV INPUTS as: HDMI 1, HDMI 2, HDMI 3, VGA, Component 1, Component 2, and so on.
If you still see NO SIGNAL on your TV screen, see the next step below…
2 – If you have your TV on the correct INPUT or SOURCE and you still see NO SIGNAL…
CABLE OR SAT BOX NEEDS RESET
-Remove or unplug the power cable from the Cable TV or SAT set top box.
-Keep it unplugged for 2 to 3 minutes.
-Plug the power cable back into your Cable or SAT set top box.
-Give it some time for the Cable or SAT box to power up, get the signal, and initialize.
3 – If you have reset the Cable or SAT box and still have the NO SIGNAL…
UNPLUG THE CABLE GOING FROM THE TV TO YOUR CABLE OR SAT BOX
-Remove the HDMI cable or other cables from your Cable TV or SAT set top box.
-Keep the cable unplugged for 2 to 3 minutes.
-Plug the HDMI cable or other cables back in.
-Give it some time for the Cable or SAT box to get the signal and initialize.
HINT: Make sure all the cables that are connected to your Cable or SAT box and your TV are tight, undamaged, and secured.
4 – If all of your TVs are affected with the NO SIGNAL screen…
BE SURE THE COAX CABLES OR ETHERNET CABLES ARE SECURE or CABLE OR SAT IS DOWN TEMPORARILY
-Be sure to check the ones where the CABLE or SAT come into your home.
-Be sure ALL Ethernet and Coax cables are secure.
-Call your CABLE or SAT provider to see if there is an outage.
-Realign your Dish if you have SATELLITE.
May 10, 2017 | Televison & Video
You gave too technical an answer . I'm 80 years old & don't know what you are talking about.
Assuming you have a TV hooked up to some kind of cable box, I would venture to say the TV is telling you it is not receiving a signal from the cable box.
Two things could be the problem;
1 You are on the wrong channel to receive a signal - some boxes send the signal to you on channel 3 - if your TV somehow got changed to channel 4, for example, it would not recognize the signal from the box. Make sure you are on the correct channel setting.
2. The cable box may not be turned on or formated properly. Turn the box off and then back on after a few minutes. Follow any messages on the screen on the box for a proper start-up.
If nothing helps, call your cable company for assistance..
Feb 23, 2015 | Televison & Video
The LED vizio comes on the front of the tv...........screen is blue with floating signal saying No Signal!.
Tries unplug the tv and the cable or satalite boxes too.Replug it all back like an hour later.The tv know will reset itself back to the factory setting.The cables or satalites boxes it upgrading it softwares.The tv should have incomming broadcasting signal and work now.Not,call the cables or satalites compannies to replaced those inputs boxes first,have the same problems with those new input cables or satalites boxes.Than the tv,the Tuner signal board have problems and the cause.That the board,where the incomming broadcasting signal cable plug into it.That the tv Tuner signal board.Tries websites Shopjimmy.com,Ebay.com to buy a whloe refurbish Tuner signal board for the replacement.
Nov 07, 2010 | Vizio VX32LHDTV10A 32 in. LCD HDTV
I have a Sony Bravia KDL-40EX400. Every morning I have to reboot my cable box to get my cable signal. I get the "Unsupported Signal" message and no picture if I don't. I have seen other posts about this...
All symptoms show that cable box is cause of problem, not sure that its internale circuit problem (signal processing in cable box) or its getting distorted signal from cable company.
TV sounds good because it works fine with blu ray player that is HD signal as well.
Change cable box just to confirm it.
I hope this tv would be under warranty so ask nearest Sony service to update its firmware under warranty cover that might fix the issue.
Thanks.
Jul 05, 2010 | Televison & Video
Vizio 32 inch hdtv, Motorola DVR box...Whenever I turn the tv off, the cable connection is lost and I have to unplug/replug the DVR box when I want to watch the cable again. It's not the box, because I...
Here a way,u could test,if it the cable signal,tv Main tuner board have problem or the DVR box again.U have analog antena?Or go and a buy a digital antena.Reset ur tv to free air signal and use it for few hours,turn it off/on and see if u losing signal,require unplug,replug to get signal back.Two problems solved ur tv board or cable signal good or not?Than U know it the DVR box and have connecting problems.
Mar 19, 2010 | Vizio VW32L 32 in. LCD HDTV
Can not get the listings for the TV Guide to load. The TV is connected to cable box and tuner with HDMI cables. When I contacted LG they stated that I need to split the cable signal prior to connecting...
Hi my name is Roety,
I can help you with your issue ,
The cable box signal is received from a round cable called coaxial cable. The guide is sent to the cable box through the coax cable. The HDMI cables sends the picture to the TV.
The Tv does not download TV guide listings , just the box does. That would be a cable company/box issue not a TV issue.
Some TVs have a built in TV guide for when you recieve signals from an antenna (not cable).
If thats what you are referring to don't bother .
Use the cable box guide .
If I have helped you with your issue please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
Thanks
Dec 01, 2009 | LG 50PX4DR 50 in. Plasma TV
Signal drops out, displays "No Signal"
My best guess is the signal to the Cable box. It is not a hardeware problem if you replaced the box it has to be the cable signal. Loose connections are sometimes the problem.
Nov 08, 2009 | Daewoo DP42SM 42 in. HD-Ready Plasma...
Is it the DCT or the cable signal?
if you are getting signal of the proper strength and quality the cabling is good.the problem is the box trying to decode the signals.a lot of signals are encripted and have to be decoded by the box.if the box is not responding fast enough you will see bloches on the tv.if you see scrambled channel you are not payinfor that channel.and if you are paying for a channel and it comes up scrambled your box is not working correct.get your company to upgrade the box.
Jan 07, 2008 | Arris DCT6200 DTV Receiver
Cable box pass through
ur trying to downgrade the signal when ur running composite cords u need to either run the composite out or an hdmi out to upconvert the signal the svideo cant handle the composite
Dec 18, 2007 | Onkyo TX-SR605 Receiver
"No signal"
It could be a bad barrel at he TV and at the wall. Your cables and connector could be of poor quality. You may also have a signal issue. Has anyone fron the cable company be out to take a signal reading?
Nov 09, 2007 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Olevia LT32HVM 32 in. LCD Television Logo
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
