Question about Craftsman Camping, Backpacking & Hiking
I have an Eveready fluorescent lantern #9209. I can't figure out how to put the batteries in. I get the back compartment opened but am completely flummoxed after that. Does anyone have the instructions? Thanks
On the bottom is an indention where the lamp attachs to the handle portion. The latch opens when you push the button toward the front of the lamp. Once it is opened, then slide the lamp off, revealing the battery compartment - remove the batteries and replace with new ones
Posted on Oct 10, 2012
2 Suggested Answers
SOURCE: How do I change the
If it is the yellow floating lantern you have to remove the black plastic stub on the underside of the reflector using needlenose pliers to wiggle and slightly pull until it releases and the bulb will come out.
Posted on Jan 09, 2011
How do I get to the bulb?
Unscrew the head assembly. In the back of the assembly is a small plastic nut. Unscrew this and the bulb should fall out into your hand.
Nov 01, 2014 | Energizer Eveready Utility Lantern Uses 6V...
How do I change the bulb of the 6V Eveready Lantern if bulb won't come out
Drop a couple of drops of WD 40 on the bulb retaining ring. Let site overnight and in the morning it will easily unscrew. Note: be sure you use only a couple of drops as you don't want to get it on the reflective lense
Sep 27, 2014 | Energizer Eveready Utility Lantern Uses 6V...
How to fix the switch on eveready lantern flashlight
The switch in the lantern is a press fit switch so you will destroy it when you remove it. Remove the lense and retainer ring. Remove the battery. With a pair of pliers, preferably channel lock water pump pliers crush the switch into small piece and discard. Trail Tech makes the exact water resistant switch model 040-ls-b and you can get it at Amazon or on eBay . The switch runs around $6.25 + $4.00 shipping
Jul 11, 2014 | Energizer Eveready Utility Lantern Uses 6V...
How to test a flashlight bulb
To test a flashlight bulb you use an Ohm meter which will detect a broken filament or an open circuit within the bulb. If the bulb is bad it will read "OL" if it's good it will read "00.0"
Jun 14, 2014 | Energizer Eveready Utility Lantern Uses 6V...
I can't figure how to change the battery on this hardcase lantern took off the rubber surrounding the lantern face, but nothing else seems to come off without unscrewing, But seems like those sre rivits...
I've owned this flashlight for years. In the comment above, ignore the instruction to remove the rubber casing around the lamp area. Simply grasp the whole front of the lamp piece (including the rubber cover), and twist in a counter-clockwise direction to remove. Then squeeze together the two black tabs and pull the battery compartment out to replace the batteries.
Apr 05, 2011 | Energizer Eveready TUF4D1E 4D Cell Lantern
Don't know how to replace the batteries.
I've owned this flashlight for years.Grasp the whole front of the lamp piece (including the rubber cover), and twist in a counter-clockwise direction to remove. Then squeeze together the two black tabs and pull the battery compartment out to replace the batteries.
Jan 11, 2011 | Energizer Eveready TUF4D1E 4D Cell Lantern
How do I change the bulb of the 6V Eveready Lantern?
Jan 06, 2011 | Energizer Eveready Utility Lantern Uses 6V...
Replacing batteries on Energizer Hard Case Lantern
If you have the Energizer Hard Case Lantern TUF4D1, simply grasp the whole front of the lamp piece (including the rubber cover), and twist in a counter-clockwise direction to remove. Then squeeze together the two black tabs and pull the battery compartment out to replace the batteries.
Jul 05, 2010 | Energizer Eveready TUF4D1E 4D Cell Lantern
Cant open new eveready hard case lantern to put batteries in.
I waited until the next day and called the eveready battery cmpany and they said I didn't need to take the screws out - just turn the ring around the bulb and the whole front came off and we reached in and toook out the thing that held the batteres and place them in the holder! simple - when you know how! ha
Dec 26, 2008 | Computers & Internet
Camping, Backpacking & Hiking Logo
460 people viewed this question
Top Craftsman Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you a Craftsman Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
