My whirlpool awm 5145/4 is not allowing water to enter the machine i have taken off both ends of the pipes and found nothing,after closing the door a click is heard and then a sound which sounds like the any access water being pumped out then nothing!
  • 183 Answers
SOURCE: whirlpool awm 5145-2
The filter area permanantly holds water, this is correct,suggest that you have a faulty inlet valve. Regards Engineer
Posted on Jul 30, 2007
  • 249 Answers
SOURCE: whirlpool awm 5145/4
FILTER MAY BE BLOCKED IRE CLOSE BYE
Posted on Nov 28, 2007
TheMobilian
  • 8220 Answers
SOURCE: how do i open the filter cover for my whirlpool
Tip is back a hair and remove the screws and bottom panel then grab the cap045bec0.jpg7d5c207.jpg
Posted on Mar 13, 2010
  • 41 Answers
SOURCE: My Whirlpool AWM 5145/5 no longer takes the powder
you'll need a new dipenser unit
Posted on Jun 12, 2010
  • 41 Answers
SOURCE: Whirlpool AWM 5145 washer the drum bearing has
It's not a DIY fix mate you'll need a new rear tub half which are around £110
HI I have a whirpool AWM 5145/5 washing machine. The fabric softner is not being taken from the draw. We have removed the draw and flushed with hot water but has made no difference ( it does take the...
I hope you don't mind me saying so but often the softener tray's dispensing siphon tube gets missed when cleaning the dispenser 'cos it's difficult to see!----------->
It will normally have some sort of cover over it which you must remove to expose the little stuck up pipe/tube. On some models there is just a small individual cap over the tube. The tube is down which the conditioner and water should siphon. It is likely to be blocked by 'gunge'- a mix of powder and conditioner. The whole of the tray, particularly this pipe and the bit which fits over it, must be completely clean and clear for it to operate correctly. It is worthwhile checking fairly regularly.
If this isn't the problem it could be that the water dispensing is not working correctly. It is easy to check by selecting (final?) rinse, pulling the drawer slightly out and seeing and hearing whether water is being fed into the softener tray. If is isn't then it is a call-out ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
May 28, 2011 | Whirlpool AWM5145/2 Front Load Washer
I have a Whirlpool 1200 Spin AWM 1201 Washing Machine. There is a funny smell coming from it like suage. Also sometimes there is water on the floor after its use. We have checked the pipe going outside and...
The smell is a build up of bacteria which can be flushed out to help/ The leakage could be a few things a hose , pump or door boot seal ,a small rip in this you need to check further....
Feb 22, 2011 | Whirlpool Washing Machines
Whirlpool AWM 1203 Leaks water onto floor about 20 sec into wash cycle. Any solutions ?
It's either a perished door seal/bellow or perished pipe work most likey. Could even be a leak from the dispenser drawer
Mar 24, 2010 | Whirlpool AWM6100 Front Load Washer
How do i open the filter cover for my whirlpool awm 5145/3 washing machine?
Mar 13, 2010 | Whirlpool Washing Machines
Whirlpool washer AWM 5145/5 water wont drain/stops on B
I had same problem twice, the first time there was a sock in the filter at the front adjoining the pump, the second time a sock had got in the pipe under the drum which is more awkward to get to but is possible if you have the tools to remove the back plate and are ok at diy, there is a spring tension clip on the pipe which comes off quite easily with a pair of pliers.
Jan 14, 2009 | Whirlpool AWM5145/2 Front Load Washer
I have whirlpool awm 5145 the counter turnsbut nothing happens
Check the lid switch. There should be a small pin on the lid that will push the lid switch down when it is closed. There are two wires going to the lid switch, jump these two wires together and if it works then replace the switch.
Unplug the washer before doing any work.
Dec 16, 2008 | Whirlpool Washing Machines
Whirlpool awm 5145/4
Nov 27, 2007 | Whirlpool AWM5145/2 Front Load Washer
Whirlpool awm 5145-2
Jul 26, 2007 | Whirlpool AWM5145/2 Front Load Washer
Washing Machines Logo
29 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
