Question about Intel Computers & Internet
Hi there, A friend has a desktop system that, although it is booting-up and reaching the desktop, it soon shuts itself down. I have carried out RAM diagnostics & all is fine there, does anybody at FixYa consider that the issue may lay within either the HDD, Video Card or CPU? The operating system is Windows7 & I have even tested the system on a different monitor, although to no avail. I truly hope that somebody could help me, as the computer is the only pleasure that my friend has, for she is virtually housebound, with suffering motor neurone disease. Thanking all at FixYa for their undying time trouble & service. Ste
  • Stephen Blaney
    Stephen Blaney Dec 29, 2010
    I do not think that this issue is temperature connected, for at one point I had the system running stabily for over 4 hours before it shut down. At other times it does not even get as far as reaching the desktop.
    The internals of the system are as dust free as possible and I was wondering, could a heating issue be intermmitent?
    Thanxalot Tech114,
    Trigga
    President:
  • 1,851 Answers
Since the computer comes to desktop, most of the hardware is (more or less) fine. Check the time that the computer stays "power on". If it shuts down after some minutes (more than 4, less than 40, depends on the CPU, cooler etc) it's a matter of temperature. Unplug the desktop from all the peripherals and power source, remove the covers and use an air blower to blow out all the dust from inside the desktop. Take special care at the cpu cooler, the vga cooler (if any) and at the power supply system. After this leave the desktop some minutes to calm down, put the covers back and check the results.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
Posted on Dec 28, 2010
Testimonial: "This solution was of great help and has finally placed me on the correct path to finally resolve the issue. Thank you ever so much. Trigga"
  • Stelios
    Stelios Dec 29, 2010
    In this case you have to locate the state that shuts down the computer. For example if the problem comes with a full screen application or playing a video file, the problem might be at the vga (either temperature or drivers). You can also check the hard disk with manual command. At the start - run field type cmd and hit enter.At the new pop up black window type chkdsk c: and hit enter. After the scan finish you will get a full detailed report.
    All these are just examples for troubleshooting you problem, not solutions. Depending on the problem, the solution is different.
    Thanks and regards
    Stelios
    direct fixya link:http://www.fixya.com/users/technical114
    Sergeant:
  • 320 Answers
Hi Trigga,
You said the system soon shuts down, I don't know if you will have enough time to try this. Many newer cpu have a failsafe built in that will shut the system down if it gets to hot (personal experience). There is a program call Speed Fan that you can install and check to see if it is indeed a heating issue. I know this does not solve your problem, but it will let you at least eliminate a heating issue being the problem if it turns out not to be one, and if it is then you'll know which direction to head and will not cost you anything but the time involved. The link below will that you to the Speed Fan website. The program will check the cpu and HDD temps. Hope this at least helps a bit, good luck.
http://www.almico.com/sfdownload.php
  • 6,771 Answers
If the operational system is fine, how long does the computer run before shutdown? if the CPU fan is not working properly the processor will shut the computer down, it probably needs cleaning and thermal grease for the heat sink and processor and that maybe enough.
My laptop has problem when I turn it on then it suddenly shut down so what is the problem? that's the big problem.
Sounds like it could be a RAM problem. If you have more than one RAM chip in your computer remove one and try the computer again. If it works then either the RAM chip that you removed has failed or the RAM slot it goes is has. Shut down the computer and take the working RAM chip and place in the empty slot to see if the computer boots up. This will tell you then if it's the chip or the slot. If the computer doesn't boot up, just to make sure it's the RAM slot, take the other piece of RAM and place in the other slot and try to boot up the computer.
Aug 19, 2010 | Computers & Internet
Booting issues...Connected to RAM?
Most likely cause is that your new RAM is not compatible with your system. Check the user manual to determine the type and size of RAM that you can use in this machine.
Mar 06, 2010 | Dell Dimension 2350 PC Desktop
Gateway 510x wont fully boot/will auto shut down
it is't a virus, it could be your powersupply is going dead or theres a bad connection with the motherboard and powersupply or memory
Jun 17, 2009 | Gateway Media Center 510X PC Desktop
The Computer shuts itself off and on it will not start windows
the problem might be in two things. either the ram or a system file might have been deleted by virus attack.the solution is try your friend's ram in your computer. if it works then go for replacing the ram. but if the problem persists, them reboot your system by using the boot cd.thanks for using fixya!. please dont forget to rate my solution!
May 30, 2009 | Computers & Internet
Dell 2400 ram upgrade problem
RAM can be finicky so first test all memory slots with a known good stick (your 512MB). Make sure you're starting from a complete power down and you get a POST beep (hopefully your system is set up to beep when it powers on) and everything loads up all the way through to your OS.
Once you do that with all your memory slots test with the new stick by itself in all memory slots. If neither of the memory slots work with the new stick but you verify that it works in another system you should then check your BIOS settings and RAM timings to ensure compatibility with your stick. If you can't find the timing on the RAM stick itself, look up the manufacturer's part number for the information.
Feb 03, 2009 | Dell Dimension 2400 PC Desktop
Computer does not boot up completely -shuts down by itself
for xp there was a update called service pack 3 witch caused alot of compaq to just boot the shut off this seems to be ur problem although i am not sure of ur pc's brand hope this helps
Here to Help
Shaun
Nov 24, 2008 | Computers & Internet
Hp xw 6000, keeps shuuting down during initial boot up.
reseat ram if not i'd say to take 1 stick of ram at a time and start the computer with such might be a ram issue or run memtest 1.7 which can be downloaded here http://www.memtest86.com/ boot to cd once downloaded and burned to test ram
Mar 19, 2008 | HP XW6000 PC Desktop
Computers & Internet Logo
76 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
