I have a whirllpool LXR7244JT3 Washer.Stops and end of wash spins but can not force it to renise. Can force it to go to do the final spin at the end Replaced timer assembly which had been making a lot of noise. that did not fix the problem does this on all three cycles
  • 4 more comments
  • Atanta1951 Dec 29, 2010
    The water is pumped out and has spinned to the point to add rinse water Not a problem in the dran or pump
    Before I go futher I want to make sure that you understand that the washher pumps the water oot good The spins good at the end of the wash cycle I can force it to spin at the final spin cycle. I cna check the lid switch by opening the lid in a spin cycle. which I will do where is the pressure switch. Note that this problem occurs on all three wash cycles and two water levels water temp warm wash cold rinse maybe its really washing hot and trying to resine cold but getiing no presuure reading it does not run???
    Tested lid switch tride to run a cocl cold cycle get no water checked coldwater shut of valve and some one had shut of cold water line whene I did a warm warm cycle it would go into the renise cycle ok I have to button it all back up to do a final check that ,that is the problem
  • Atanta1951 Dec 30, 2010
    In the process of invesigating the problem I found that some one had shut off the cold water valve.The reson someone did this was the valve was leaking bad and going out side the wash room which is outside the house. have a plumber coming today to replace shut off valves.in the wash cycle it seems to work ok without cold water but waht is different for the rense cycle?
  • Atanta1951 Dec 31, 2010
    The problem was the cold water was shut off, When I turned it on the washer goes through all the cycles with no problem. So I am happy
    Thanks
    Always check that water is on before you start troubleshooting a problem Thanks for you help
    Top Expert:
  • Washing Mach... Master
  • 9,472 Answers
Sounds like a problem with the water inlet valve. Try replacing it with this part. Here is a video to show you how to replace the valve.
Posted on Dec 31, 2010
  • Richard Roth
    Richard Roth Dec 31, 2010
    The machine uses the cold water for the rinse cycle. If it's not on, then there is your problem.
  • 1,998 Answers
What is it doing is it stopping when its supposed to be spinning or is ir not spinning enough to get the water out of your clothes please message me back your first statement Im having problems desifering also if you have any further questions or could describe the problem your machine is giving you it would be much appreciated Thanks again
Rick
Posted on Dec 30, 2010
  • 19,396 Answers
Hi.
If the pump is working, then it is unlikely the pump. The pump hose must be accessed and eventually checked for blockage. This is part of ordinary troubleshooting.
If the drain system is OK, check the lid switch and the pressure switch. Those are the parts that determine the advancement of cycle to rinse. The lid switch is tested by jumping its contacts and runnning a cycle, or by Ohming it. The fact that the lock is snapping does not tell the lid switch is good.
Regarding the pressure switch, clean and blow into the pipe attached to the switch. If that does not fix the problem, then replace the pressure switch. The part is not expensive. The switch is also called Switch WL, search this in part list.
Here parts and diagrams.
Here a service manual available for $10.
Posted on Dec 29, 2010
  • Ginko
    Ginko Dec 30, 2010
    RE:Before I go futher I want to make sure that you understand that the
    A: I Know, I read this in your first comment.
    RE I cna check the
    A: No you cant. That is no good test. If the lid cycle had no contact at all, then the machine would not run. If the contact is bad, then the machine may stop in final part of the cycle, when PSU 'checks' signal from lid switch all the time.
    RE: pressure switch:
    THe switch is located behind control panel trim. part is nr 12 in this diagram. THe switch is attached to a long Water Pressure Hose that you need to check.
    Here the pressure switch: SWITCH-WL
    Regards.
    Ginko
  • Ginko
    Ginko Dec 30, 2010
    If cold water valve is off the cycle usually does not start, as the pressure switch does not sense that the required water level is reached.
    If machine was cycling with no cold inlet, then there is an additional problem. Either hot and cold inlet are inverted, or the pressure (water level) switch is malfunctioning.
  • 4,323 Answers
Hi
When the washer stops at the end of cycle it means that it is unable to drain. To resolve this issue check the drain hose and the drain pump filter for any clogs and try to clear it of any debris/gunk. After it has been cleaned then check the drain pump operation, if the pump won't work then the water won't drain and so cause these kind of issues, if it is not working then the pump should be replaced. Hope this helps...please post back for further assistance.
Daniel
Posted on Dec 28, 2010
  • Daniel Scott
    Daniel Scott Dec 29, 2010
    Seems to be an issue with the lid switch assembly that should be replaced.
  • Daniel Scott
    Try swapping the water line cold to hot and hot to cold, seems like it is the water inlet valve or pressure switch causing this issue.
Brand new Bravos. Why doesn't it do the final spin?
NO ITS NOT UR DOOR SWITCH IF IT WAS IT WOULDNT SPIN ON ANY CYCLE. I SUSPECT U HAVE A TIMER THAT IS STICKING AND THE POINTS HAVE BURNED OR SEIZED
May 26, 2015 | Maytag Washing Machines
Kenmore washer model #417.42042100 is not spinning the clothes all the way.
First you need to open the cabinet and remove the boot from the tub to the pump and clear the filter. Try that then run a cycle and post back the results.
Dec 05, 2012 | Washing Machines
Hot water stops filling too soon.
Fill setting has to be adjusted and the belt is slipping on the spin cycle and not generating enough centrifugal force to get the water out.
Aug 25, 2017 | Kenmore 22422 Top Load Washer
Washer is not completing the spin/drain cycle. Stops spinning and draining.
does it drain out all the water? after it stops or is there still water sitting in the tub?
Mar 22, 2011 | Kenmore Elite 45986 Front Load Washer
My indesit front loading wg1432 model washing machine wont do final spin at the end of each programe, the rest of the programe is fine, just when it comes to final spin the dial stops at this point
hello it might not be draining enough water out it has to pump water out before it spins check the pump also the filter if it has 1 hope it helps
regards
shaun
Mar 14, 2011 | Indesit W 123 Front Load Washer
My washer works until the final spin. I have tried every final spin cycle, balanced the load, removed things to make it lighter, let it rest over night, and it still stops at final spin.
The PCB (electronic board) could have failed, but there could be other problems which would have to be rectified by a technician.
Hope this helps you?
Oct 12, 2009 | Frigidaire ATF6000ES Front Load Washer
Machine will not discharge water
Any error codes? Pumps out OK?
Sounds to me as if the cold water inlet screen is plugged up, preventing rinse water from entering machine. Turn off the cold water to the machine and remove the cold water supply hose. Check the screen inside where the hose came off the machine. Run some water out the hose into the drain or a bucket before reconnecting to machine. Let me know if you still have problems.
Apr 19, 2009 | LG WM-1832C Front Load Washer
Whirllpool ultimate care II
Since I haven't heard back on this in over a week, I will assume it's been resolved with the clarification questions.
Jul 12, 2008 | Washing Machines
70 series Kenmore washer
POWERUP, YOUR WASHER COULD BE THE LID SWITCH OR THE COLD WATER VALVE. AT THE END OF THE WASH CYCLE, THE MOTOR WILL SPIN OUT THE WATER, BUT ONLY IF THE LID SWITCH IS ACTUATED. IF THE SWITCH IS BAD, IT WILL NOT SPIN OUT THE WATER AND THE TIMER WILL NOT ADVANCE FROM THAT POINT.
IF THE WASHER SPINS, THE NEXT STEP IS TO FILL WITH WATER FOR THE RINSE CYCLE. MOST WASHERS USE COLD WATER FOR RINSES. IF THE COLD WATER VALVE IS RESTRICTED OR FAULTY, THE WASHER WON'T FILL. IF THE WASHER WON'T FILL, THE WATER LEVEL SWITCH WON'T ACTIVATE AND THE TIMER WON'T ADVANCE TO THE NEXT STEP.
Mar 31, 2008 | Kenmore 22422 Top Load Washer
After spin cycle washer stops abrubtly causing it to shift.
You have dragging brake shoes. This will cause the motor to draw excessive current. Nedd to take apart and pull down spin tube to access the brake shoes
May 31, 2007 | Whirlpool LSQ9600L Top Load Washer
Washing Machines Logo
97 people viewed this question
Top Washing Machines Experts
