Question about Dell XPS M2010 Wireless Bluetooth Keyboard
Dell xps m 1020 HD failed. New HD substituted. Works fine. Computer works, mouse works. [External UBS connected KB works.] The detachable KB that came with the computer, it does not work. On the KB: the three right lights flas blue. The 4th light (to the left of the three flashing lights, does not light up. John
  • Dell Master
  • 19,396 Answers
Hi.
After reinstalling the system on the new hard drive, ensure that all drivers are correctly installed and working. Go to device manager in control panel and ensure that no device has the yellow sign indicating device malfunction. Ensure that the Bluetooth installed in the computer is working. This is used to communicate with the keyboard.
Once you are sure that the bluetooth module is woriking follow the indications in the Dell document below. The indications are for XPS M2010. If you have a different model, contact DELL.
Here the service bulletin regarding your problem (for XPS M2010)
Posted on Dec 28, 2010
Alert. previous attempts at booting this systemhave failed at checkpoint [0032]
XPS 8500 Desktop booting fails - General Hardware - Desktop - Dell ...
en.community.dell.com/support-forums/desktop/f/3514/.../19452875
Dell
Jun 13, 2012 - 16 posts - ‎9 authors
I am sorry to know the concern with the computer. As you .... I have the identical problem on a 3 week old XPS 8500 desktop machine. It seems ... Dell XPS 8500 - Will Not Boot At All - Motherboard ...
Aug 13, 2014
Dell XPS 8500 Unable To Boot
Jun 25, 2013
New Dell XPS 8500 won't boot
Dec 5, 2012
XPS 8500 UEFI boot
Oct 29, 2012
More results from en.community.dell.com
How to Use and Troubleshoot the XPS 8500 ' Dell US
Dec 15, 2015 | Dell XPS 8500 Desktop Computer; Intel Core...
I put my Dell Dimension 9200 XPS 410 into sleep mode after connecting a wireless keyboard and mouse and the only way to wake it is to hold the power button in until it shuts off and then switch the power...
I would say it is in the Hibernation Mode To get it out of this mode you need to go to your Control Panel, open "POWER OPTION'S" and deselect the Hibernation mode then reboot.
Sep 26, 2013 | Dell Dimension 9200 PC Desktop
Charging and monitor issues
If your AC Adapter and Power Cord is working fine, then your new battery has a problem if it will not charge. Just because it is new does not mean it will work.
As for your Monitor, try the steps below. Because it works with an external monitor, we know your Video Card is working fine, so the problem is either the LCD Inverter or the Lcd Screen itself is bad.
Shine a flashlight on the dark screen to see if you barely see the icons on the desktop. If so, then the LCD Inverter is bad.
If you see no icons by shinning a flash light and the external monitor works, then your screen is bad. If you see no icons by shinning the flash light and nothing shows on the external monitor, then most likely your video card is bad.
May 16, 2012 | Dell XPS 1530-146P (X1530-146P) PC...
I have a dell xps M1210, and It has problems with the screen. I already probe and it work fine with an external monitor. You can not see the images well but there is not problem with text. I think there is...
hello, if works fine whit external monitor so is no problem whit motherboard, problem must be in display or the connector that connect motherboard to display
its not dificult to change display but i recomand that u go to a specialist
Sep 23, 2011 | Dell XPS M1210 Notebook
I have a dell xps M1330. Its mouse pad is behaving weird. If I try using it, it doesnt work but if I keep holding a shortcut key(play/stop/volume keys) while using the mouse pad it works fine. Any help?
hi,
your mouse pad dose not connect to the ground of device so when you keep and hold any
shortcut of keyboard , this connection done , and mouse pad work.
for this you (if you can) or a technician must remove the keyboard and change the flat cable
between mouse pad and devise .
good luck
gorbesia
Jun 19, 2011 | Dell XPS M1330 Laptop
Display problems with dell xps m1530 laptop
These models have known video card problems, so first thing connect an external monitor before booting - boot and see if the image on the external monitor stays on, if it's fine on the external monitor then the LCD panel might be defective, otherwise if you see blurred / distorted image on the external display it's the VGA card. which means you should contact warranty (if you still have) because the mainboard needs servicing / replacement.
May 25, 2010 | Dell XPS M1530 Laptop
Dell xps 400 keyboard and mouse not working, but the keyboard does work in when in service mode
If it works in service mode, then it is not a hardware problem. Boot Windows in "Safe Mode" using the F5 Key as it is Booting to Windows. That should make it re-discover the KB and Mouse. Make sure the KB and Mouse are pluged into the right ports. Mouse Green and KB Purple
Dec 30, 2009 | Dell Computers & Internet
Dell wireless mouse and keyboard-no instructions
Most Bluetooth keyboards and mice are just Plug-n-Play and does not require any driver installation. You need to isolate the problem, please follow the steps below:
1. Make sure that the wireless adapter of your wireless KB and mouse is properly connected to the USB port of the computer.
2. Make sure that the USB ports of your computer are working.
3. Use fresh batteries for the KB and mouse.
4. After connecting the wireless dongle to the computer, turn on your KB and mouse (there should be an ON/OFF switch underneath).
5. Briefly press the connect button on the wireless dongle and then hold down the connect button underneath the mouse for five seconds and then release it.
6. Do the same steps for the KB.
Have a good day!
Jun 27, 2009 | Dell Wireless Keyboard Optical Mouse w0147
Connect HD Plasma to Laptop using HDMI cable
so what you ****, this a problem telling website not a website of telling your happiness of your succession
Jan 21, 2009 | Dell XPS M1530 Notebook
Dead pc
try to remove all external device connected to your computer. just leave the keyboad, mouse and monitor connected.
restart computer.
if still a blank screen
remove everything connected to your computer (mouse kyeboard and monitor) restart if nothing happens
open your computer and remove all devices (hard drive, optical drives, memory... restart,,, you should be hearing beeping sounds indicating motherboard is looking for memory. try putting back 1 memory at a time and checking all mem slot. to identify if one of the memory could be causing the blank screen. if both memory will not work try to use known good working memory. if you dont get to hear the beeping sound using a known good working memory. your memory is the problem.
give me more info
Jun 19, 2008 | Dell XPS 200 PC Desktop
Dell XPS M2010 Wireless Bluetooth Keyboard Logo
88 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
