Question about kawasaki Full Suspension Mountain Bike Men
I have a 2000 kawasaki mule 2510 trying to do a tune up . I don"t have manual and I am not sure of propper spark plug size.
  • 10 Answers
SOURCE: battery life
the part is called a stattor or statter but it should be a black box with raised lovers on it attached to out side of bike usually in the front with 2 or 3 wires coming from it to a plug then the wires going into the engine.Check the plug for fit and cleaness or Change that box if that doesn't work it's internal. take it to a dealer or independent and have repaired
Posted on Jan 31, 2009
  • 14 Answers
SOURCE: need repair manual for 2002
Go to "Repair Manual".com and they have a very good service manual for the Mule. It's about 50 bucks but it's well worth the money. John
Posted on Aug 30, 2010
  • 8909 Answers
SOURCE: I'm looking for the spark
Normally 25thou or 0.9mm.
Hope this helps.
Posted on Nov 05, 2010
SOURCE: kawasaki mule turns over but wont start, plenty of
kaf1000 mule has spark fuel compression wont start
Posted on Sep 02, 2011
duane_wong
  • 6826 Answers
SOURCE: kawasaki mule 2510 is hard to keep running or start
OK, probably the carburetor needs to be cleaned out or rebuilt.
Posted on Dec 12, 2011
I have a 2003 kawasaki mule model 3000 it wont say running at idle what to do
Full tune up and carb clean .get new plug,air filter.oil Chang ,carb clean and adjustment.that should do it.,., try fuel filters and test fuel pump see if it's functioning properly.,.
Dec 10, 2016 | kawasaki 2005 Mule 3010 4x4
What spark plug gap size on 2001 kawasaki mule
http://www.globaldenso.com/cgi-bin/global/plug/usa/terrain/terrain-plug.cgi?filename=terrain-23.txt&name=&engine=&FF=50
Oct 25, 2016 | Cars & Trucks
What spark plug is right
Ngk BPR5ES or the equivalent
Apr 11, 2016 | Motorcycles
Lopes at very low speed
well it sounds like a cam shaft thing. like its designed to go very fast. like when you watch tv and see dragsters they lope that same way, sound like a piece of junk, but we all know that is the cam lobes. But I think I would look more toward a cracked spark wire or bad plug, could be again the fuel, in the Midwest here there is the blended ethanol fuel which is horrible for smaller engines. find non ethanol fuel and try that first.
Jun 20, 2015 | All Years Kawasaki Kaf620 Mule 2500 2510...
How to adjust valves on a kawasaki mule 4010 trans
You must have a mark on the main crank shaft, and take the spark plug out, slowly and manually turn the crank shaft, put screw driver inside the spark plug hole and screw driver will raise and when stop and then go low turn back that your tdc
Aug 21, 2014 | Kawasaki Mule 4010 Trans Full Cab...
#1cylinder not firing on 2003 3010 Kawasaki mule
if its firing ok on other cylinders, unlikely to be pump or fuel filter, focus on electrics, plug, ht lead etc
Dec 08, 2013 | 2003-2007 Kawasaki Kaf620 Mule 3010 4x4...
Changed the batt in a 2510 mule now it will not turn over the relay is working
hi if you changed the batt and relay is working check startermotor is turning and check the wires are tight if this is ok then check you coils and ht /plug caps are ok because if weak spark also check sparkplug is fitting ok or check for short circuit on the electrics hope you find out why this has happend
Oct 17, 2013 | kawasaki Motorcycles
Kawasaki mule 2510 is hard to keep running or start
Dec 12, 2011 | kawasaki Motorcycles
Need repair manual for 2002 Kawasaki mule 2510 4x4 with 620cc motor
Aug 30, 2010 | kawasaki Z 650 Motorcycles
Battery life
Jan 31, 2009 | 1999 kawasaki VN 1500 Vulcan Classic
kawasaki Full Suspension Mountain Bike Men Logo
216 people viewed this question
Top kawasaki Sport & Outdoor - Others Experts
Wayne McNeil
Phillip Edwin
Level 1 Expert
Are you a kawasaki Sport and Outdoor - Other Expert? Answer questions, earn points and help others
