Question about Haier HVTS18DABB Wine Cooler
It will not cool is it just out of refridgrent or could it be the thermistat
Refridgrator's compressor run for few seconds and stop. No cooling
That is called short cycling and caused by a defective start relay, overload, run capacitor, defective fan motor or defective compressor and of course it needs to be diagnosed to have the fridge cooling again
APPLIANCE 911
Dec 03, 2015 | Refrigerators
My ac system has a model#44408 hunter thermistat and a trane heat pump. The system runs but does not change the temperature to cool the home to a comfortable temperature. is the problem in the thermistat...
You have refrigerant leak or the compressor has died...not a thermostat problem...
You will need to get a tech. to take a look at it.
Here is a tip about troubleshooting your airconditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Apr 20, 2011 | Heating & Cooling
Water on the bottom floor of the refridgrator..inside.
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 04, 2010 | Refrigerators
Ice build up around fan in frezeer.makes looud noise....if not melted the refridgrator part a bottom of unit stops cooling.....if melted fan runs smthly....things cool well, but happens again over noght...
The defrost circuit has failed. Typical failures are the defrost heater has opened, the defrost timer if equiped, is not advancing or the defrost thermostat is open. To check the heater, melt the ice, and use a meter to check if the heating elements are open, if they are, then you will need to replace the heating element.
Aug 23, 2010 | Kenmore 64802 Top Freezer Refrigerator
My refridgrator does not get cold the panel says the filter needs to be changed the only thing im finding is the water filter could that stop the refrigrator side not to get cold?
It has nothing to do with the water filter...
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
Water Running in efrigerator from Freezer
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Aug 16, 2010 | KitchenAid Superba KSCS23IN Side by Side...
Hello, Can you help me? I have a 1993 Chevy Lumina that is overheating when I stop ex. long traffic lights, letting it run while I go to the mac machine etc... once I start driving again its fine. Can you...
Sounds like the cooling fan is not coming on .. could be a bad fan motor or relay .. If you can check it yourself you can try to power the fan up directly and see if that is the problem.
Jul 29, 2010 | 1993 Chevrolet Lumina
Where is the thermostat cant find a repair manual for 97 Sportage ..need to know where the thermostat is located
just follow the top radiator hose toward the engine. that metal housing that the radiator hose hooks up to has the thermistat under it take off the two bolts and change out thermistat.refill with coolant then run for about a half hour to warm up enough to open thermistat, then top off with coolant at the radiator cap.leave cap loose during this operation so that no pressure will build up in radiator.if unsure squeeze upper rad. hose it should easilly compress if stiff pressure has built up so dont open the cap. let cool then top up coolant
Apr 01, 2010 | 1997 Kia Sportage
Car runs hot after repairing, water pump, themostat, water outlet, coolant flush. What else can cause the thermostat gauge to move?
[1] plugged radiator core. replace radiator,not cleanable
[2] a bunch of dead bugs stuck on air conditioner condenser in front of radiator. open hood and look at front of it if a bunch of debris blast it off with water hose
[3] the air not properly bled from the engine cooling system. some have a bleeder screw that must be opened while engine running untill all air is let out if i dont have a screw for bleeding then you have to let engine run long enough to open thermistat i may take a while when radiator tank feels hot then thermistat is open. coolant level should have dropped top off and put cap on
[4] electric cooling fan not working
Mar 22, 2010 | 2005 Dodge Magnum
Haier HVTS18DABB Wine Cooler Logo
29 people viewed this question
Top Haier Furniture Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
jasbo
jasbo
Are you a Haier Furniture Expert? Answer questions, earn points and help others
