Hello I bought the Toshiba 40Sl500U TV, it has a USB port, I did insert the usb stick with some movie`s on it, but I can`t play the movie`s , it always showing photo`s. What can I do watch movies on a memorie stick on my tv
aberry9036
  • 49 Answers
SOURCE: I have the philips 120hz and some movies are smooth, others jump
I would advise knocking down the resolution. Try and use software, like red kawa, to convert a few of your movies to different formats till you find a decent one. A widely accepted codec setup is Divx/XVid (both are the same) and MP3 sound.
Posted on Aug 04, 2009
xptareq2000
  • 1447 Answers
SOURCE: 32LG80FR LCD TV, Arabic subtitle problem
you follow your user giude and setup language
Posted on Sep 12, 2009
abilenetech
  • 65 Answers
SOURCE: how do i watch movies on a philips 42pfl5603d/f7 from flash drive
the flash drive connection is usually for viewing pictures, but in most cases its used to upgrade the tv
Posted on Nov 18, 2009
SOURCE: can i play movies off a USB in the tv's USB port
OK, well I have used this many many times. You simply need to copy the Movie in any of the Formats that the set can use, and copy the Movie to the USB stick. When the stick is inserted, using the remote you simply "Select" that "USB Input" and select the Movie, and select "Play", IF the right Format, has been used, the Movie will "Play" as if it was a DVD.
Consult your manual. link below.
http://www.tacp.toshiba.com/dvd/product.asp?model=47HL167
Posted on Jul 21, 2010
  • 906 Answers
SOURCE: dvd with usb port can not play avi
good day,
hope this link below will solve your problem.
nokia
Posted on Aug 02, 2010
Can I insert a Memory Stick to the USB Port &extract , say a movie ive downloaded, then put the M/S into a TV USB PORTAL, & show that Movie on the screen?
Depends entirely on your TV. If it is a smart TV with a USB socket on the back, then probably. You may need to change the format that the movie is recorded in. you can use a free converter for this - 'Handbrake' is very good for this.
Apr 08, 2016 | Tablets & eReaders
How do I use a USB to watch a movie on Toshiba TV? Or hook computer up to TV to watch it?
Hi
Most recent laptops come with a port to connect to a TV, depending upon the input ports the TV has. The two most common are VGA and HDMI, and you will need to check which of these each item has. It is then simply a case of getting the appropriate cable to connect the two together, and then on the TV select the input from the menu, and on the laptop, make sure that the external video port is active (usually a Fnct and "F" key - eg Fnct + F5 for a Toshiba Satellite Pro U200).
Hope this is helpful, if so would you please register that with Fixya
Cheers
Feb 08, 2015 | Toshiba Televison & Video
MY LC60LE745U BIG SCREEN WONT RECOGNIZE MY FLASH STIK
I believe your TV has 2 USB ports on it. If you have equipment connected to the other USB port, that port will get priority and the TV will ignore your flash stick. Turn off your tv, disconnect everything on your USB ports then insert the flash stick. Power on the TV and hopefully you can see the flash stick.
Mar 22, 2014 | Televison & Video
I have a RCA RLDED3258A-B 32" TV with an usb port "for service" How can I activate this port to play videos from an usb drive
Oh well... my Samsung TV reads directly from a USB stick -- great for watching downloaded movies, no need to burn DVDs, etc.
Dec 03, 2012 | RCA Televison & Video
How to record on lg smart tv to usb
The USB device port is play only the TV does not have to capability to record to the USB stick.
Aug 21, 2012 | LG 42LC2D 42 in. LCD HDTV
My usb stick wont work with my portable dvd player?
check first in the user manual what kind of file format available in the dvd player that you bought. so you will know what kind of format that you can download to make compatible in the player using the usb stick.
Jun 25, 2012 | Bush Televison & Video
Toshiba SD2010 DVD player
It can't read the files on the USB, wrong format.
Jul 14, 2017 | Televison & Video
I'm trying to play movie files through my toshiba lcd tv via a usb and it won't work. i've tried converting mvi and wmv files to mpeg or avi and still won't play. can you tell me which type of file works...
You have not mentioned the TV model #.. If your TV does not play avi. files I am sorry to tell you it does not support moving pictures -- it only supports MP3 music files and JPEG picture files !!. Try these two to confirm.
Mar 12, 2011 | Toshiba Televison & Video
Can i play movies off a USB in the tv's USB port, if so, how ??
Jul 21, 2010 | Toshiba REGZA 47HL167 TV
Video playback for toshiba 52xv645u
You can get some external HD Players that have TV out, but quality is not good. Can't you use a laptop with a Video out, or a USB Video Out? Or some DVD players have a USB port, I picked one up the other day for NZ25.00, It plays ALL DVD's and has a USB, so I can play movies from there. Solution or what?
Feb 09, 2010 | Toshiba Regza 52XV645U LCD TV
Open Questions:
I'm hoping to get some clarification as to whether the below is correct or whether I have been taken for a ride. My LG was picked up by a repair service because it started displaying horizonal lines with the picture hazily in the background. I undertook some research and learned that in most cases of the boards needed replacing and it wasn't a panel issue (usually panel issues are associated with vertical lines). After having my TV for 5 days the repair service advised that it required a new power board and a small repair required on another board. They repaired the small repair and I was going to purchase a new power board however the TV has been returned to me dead. It now doesn't even turn on. The power/channel/indicator lights at the bottom flash on then switch off automatically. After getting consumer affairs involved, I finally received a call from the sub contractor and aside from a number of different excuses given based on my questioning of each explanation, all were contrary to the initial diagnosis discussed with me in early June. I documented the conversation which I summarise as follows: - he contacted numerous times however I never received any voicemail. I asked why - after "numerous phone calls" he didn't send a txt msg to which he replied that he's not allowed to send messages. - he initially alleged that the power board was repaired and video board needed replacing which I was quoted for. I corrected him advising that I was told and quoted for a new power board ($530) and the video board was to be repaired. He then changed his story agreeing with me and alleged that found and apparently quoted me $445 for a generic power board but I declined....Just to clarify, I never received this 2nd quote which is evidenced within the emails and messages I sent after receiving no response over a number of weeks. - he continued to claim that the TV now has panel problems and is now not repairable. - I recited the discussion the owner had with me which was consistent with the information when he provided me with the original quote of $530. He then altered his story replying that "this is a rare case... The owner doesn't know what he's saying". - When I challenged why I was quoted for a power board when he is now claiming there are panel issues, his response was that a new power board was to test if the panel was cracked!! - I replied saying that the TV was delivered to them with horizontal lines and even after testing should've been returned with horizonal lines however is now dead. - his excuse changed again advising that during testing he short circuited the TV and replacing the power board would continue to short circuit the video board..When I again questioned WHY then was i quoted for a new power board (as per the owners conversation with me) he returned back to stating that it was a rare case! - I told him about the screws missing in the back panel to which he commented that "they" wouldn't have put them back in because "they" assumed I would just dispose of the TV. What I find interesting is that this was his understanding whilst I was led to believe the TV was repaired (pending a new power board). It now makes sense as to why the driver who delivered the TV literally dropped it off and ran advising that he didn't know anything. I never received a service report and asked for it again however am yet to see it. Based on this information, can anybody shed light on what they've done to the TV? Prior to them taking the TV the horizontal lines were consistent with had a faint picture in the background and didn't alter at all. They're claiming that they did nothing and the TV - claiming that the reason why the panel doesn't turn on is because it was kept on while they were testing.
Sep 25, 2017 | LG Televison & Video
Televison & Video Logo
138 people viewed this question
Top Televison & Video Experts
Electro Med Services...
