Question about Royal Orca ASF5000X Shredder
Plastic thing that makes machine work when inserting the paper waste box is broken. how can i get it replaced and what do you all call it? it screws in to the top(inside) with 2 small screws.
    Genius:
  • 1,218 Answers
Give Royal a call at 1-800-524-0799 for parts pricing and info.
Posted on Dec 31, 2010
Reset Waste Toner
If your machine is displaying "replace waste toner container" then you can empty the waste toner box & reset the machine.
If you open the front door you will see a large black box & above this a small rectangular green button. Pressing this button will release the black box. The box will then lift upwards from the machine. At the bottom of the box you will see a round, clear plastic bung, remove the bung & empty the waste toner into a suitable bag or container. Once emptied, the bung can be re-fitted, the waste box can be inserted back into the machine. Locate the waste box into the 2 slots then push the waste box firmly back in place until it latches. Turn the machine off & on using the switch located to the left of the waste box in the bottom left corner of the inside of the front door. This should reset the machine. Be careful when disposing of the waste toner, it is flammable so do not dispose of in a fire. Hope this helps.
Dave.
Feb 19, 2016 | Sharp MX-3501N All-In-One Printer
How do I fix the rollers that won't turn when paper is inserted in shredder?
That shredder is as weak as they come - it is probably a broken plastic part inside the mechanism. Recommend you throw it away and get the Amazon Basics shredder, your experience will be much better. Sorry.
Jan 16, 2015 | Royal Office Equipment & Supplies
I have a SPL-TXC122a shredder and I need the plastic drive gear Know where to get one?
I tried to get one for my machine but to no avail. So I fixed my gear myself. Go to your local hardware and buy a "Devcon" plastic welder. Not inexpensive.
You have a broken tooth on the plastic gear. Use a very small
drill bit the size of a big paper clip. drill three holes where the tooth broke off ( if part of the gear tooth is still there, file it down smooth.) Cut three pieces off a paper clip and insert them into the holes. Make them extend to below the gear and not to extend above the original tooth. Now you will make a tooth with the plastic
weld. Fill where the broken tooth was and let it set. Also fill where the paper clip extends below the tooth. This will give it more strength. Let it dry and harden. Now with a small file, file it to make it fit to the next tooth so it doesn't make a bump. " if you can before the mix dries, replace the gear and turn by hand the steel gears to make a smooth fit. Wipe any excess mix away. Good luck....
PS. mine is still working after three years....Hint do not try to shred
to many papers at one time. And once in a while put some 3 in one oil on a piece of paper in a sig sag motion and run it thru the machine. This will help to quiet the noise and oil the cutting blade.
Nov 04, 2014 | Office Equipment & Supplies
Our kyocera printer says WASTE TONER BOX FULL. what does it mean?
there is a waste toner collector, it is a clear plastic container that collects any toner that is not transferred to the paper. after a certain amount of time it needs to be replaced (or taken out and dump the toner) depending on the copier it uses weight of the container or a sensor to block the light if full. if dumping into a plastic garbage bag make sure it is not dark so the sensor can reset, otherwise it thinks it's still full. You will have to Google where your waste toner box is.
Apr 08, 2014 | Kyocera Office Equipment & Supplies
I can't seem to get my HP P2015 to work. When I turn it on, it just comes on with a solid orange light designating a Paper Jam, but there is no paper in the machine.
couple things that it could be are your pick-upn roller is not picking up paper and needs replaceing because they break occasionally, another thing is that the shutter link assy., the black and white plastic piece that is in the upper right when you open the printer could be defective or the plastic arm that goes in there is possibly broken off.
Jan 28, 2011 | HP LaserJet P2015 Printer
DEAR SIR I HAVE PURCHASED IR 3300 RC MACHINE . I HAVE 2 PROBLEMS. 1. IT ALWAYS DISPLAYS REPLACE THE WASTE TONER . BUT THE WATER TONER CONTAINER IS EMPTY. THE REP SAYS THER IS A PROBLEM IN SENSOR ....
regarding your first problem:
The waste toner container box neck must be always clean, because on the neck are two round dents, where optical sensor reads status. The permanent solution is to disconnect the sensor, his wires are above waste box ( white connector ).After disconnecting the sensor be sure to empty box every 60 000 to 100 000 copies.
Now the second problem:
Do you mean that paper cant be picked up? Does other paper sizes comes trough?
For start clean the pick up roller wich is locate inside the right door ( on top of the door ) in some cases covered with plastic cover.
Note: when you putt the paper in bypass, be sure to select correct paper size, paper type and from where to pull paper( bypass ).
If you want service manual write on emma.servis@gmail.com
Hope that helps!
Aug 30, 2010 | Canon imageRUNNER 2200
Replaced the waste toner box.
re check for the toner inserted, be sure that protected plastic remove. shake and insert again.
Apr 15, 2010 | Samsung CLP 315 Laser Printer
Broken plastic part within which thread spool pin is inserted
You can search for:
Make Model parts diagram
to see what replacement parts are available.
If not, you can probably devise something to improvise. I've used plastic drinking straws as spool pins, or plastic chop sticks.
Jun 27, 2017 | Janome Sewing Machines
NoviTech Paper Shredder will not feed paper forward.
I had the same problem with my Novitech Model: PS-026/B2 only working in reverse but not forward. So I decided to take it apart and see if I could find any loose wires, broken parts etc. Keep in mind I am not a paper shredder mechanic, but I was able to fix it, at least for the time being, and here is how:
1. Unplug the machine, and I mean it. Make sure you unplug the machine before you start any fixin'. Unplug the machine!
2. I unscrewed the 7 screws located at the bottom of the case
3. I carefully separated the cases and made sure I did not allow any tension on the few wires that span the case halves
4. With the can of electronics duster I use for my computer keyboard, I sprayed all of the electric contacts, making sure I did not spray any of the grease at the gears. I poked the straw in all of the switch housings and the motor.
5. If you feel a little adventurous, you can remove the 6 screws that hold the cover and safety switch in place. At this point pay attention to how the safety switch arm is positioned ( take a picture if you have to) so it will be in the correct position during assembly. Remove the cover and look for anything that could be caught in the shredders. Remove any foreign matter with tweezers or needle nose pliers. Replace the safety switch and cover, make sure the switch arm is in the same position before you took it apart.
6. Put the two case halves together making sure there are no wires pinched inbetween. Put the seven screws back where they belong and tighten snugly ( do not over tighten cause you will break the plastic, guaranteed!)
7. Place the machine on the waste bucket and plug it in. And voila the motor should start buzzing and humming like it was brand new.
Aug 27, 2008 | Fellowes DM15C Shredder
No paper error
There's a little plastice lever type thing that hangs down above where the paper tray is inserted. When the paper tray pops up after being inserted, the paper moves this lever up. This is how the printer knows if there is paper or not. With the tray out, push the little white lever up and see if the "No Paper" message goes away. If it does go away, the lever/sensor is working OK, if not the lever sensor is bad. If that was not the problem, check that the paper tray is popping up after being inserted (look from the back of the device while you insert the tray). If it does not pop up, there is a little white plastic button type thingy on the side of the tray that releases the paper tray to pop up after you insert it into the printer. Make sure that is working correctly. If you flip the pritner upside down, you can see this little white plastic button type thing that should release the paper tray to pop up during the insertion process.
Oct 09, 2007 | Dell 1600n All-In-One Laser Printer
Royal Orca ASF5000X Shredder Logo
87 people viewed this question
Top Royal Office Equipment & Supplies Experts
James Cagle
James Cagle
Michael Vincent Cruz
Are you a Royal Office Equipment and Supply Expert? Answer questions, earn points and help others
