Question about Thomson GE-28115FE1 Cordless Phone
I Turned off the base or i dont know somthing goes wrong with my cordless slim DECT PHONE and i'm unable to use it. i'm trying to register it by going to the menu and to REGISTRATION then REGISTER they asked me to put a pin Code ( Enter PIN ) !! ANY HELP? my cordless is Thomson Telecom -- MODEL CE21877GE3-A ---- S/N 80011150 Please HELP ME ASAP ..
SOURCE: Registering a new phone
I just purchase that same model and I had the same issue as you where the phone on the main station worked and the other 2 sitting on their own base station didn't work. What I did to fix the problem was to put each handsets (one at the time ;-) ) on the main base (the one with the answering machine). The Charge/In use light flashed a couple of time then the handset showed as Ready. I then put each handset on their individual base station and they all work fine now.
good luck
Martine
Posted on Nov 14, 2007
SOURCE: cant register/install a new dect 6.0 uniden 2060 phone
When you select register on the base, you need to press and hold # on the phone... the instructions below worked for me, finally, to get the stupid waterproof handset registered. whew!
Registering the Handset
If you have purchased this accessory handset separately, it must
be registered to the base before you can use it.
Notes:
• The handset must be fully charged before attempting to register.
• Only one handset can be registered at a time.
1) If the other base has an LCD display:
• With the phone in standby, press [Menu/Select] on the base. Press [down] to move the cursor to REGISTER HANDSET and then press [Menu/Select]. HANDSET
REGISTERING appears.
If the other base does not have an LCD display:
• Disconnect the base AC adapter. Then press and hold
[find hs] or [find] while you reconnect the adapter. Keep
pressing [find hs] or [find] until the charge/in use LED
starts to blink.
2) On the handset, press and hold [#] until the handset beeps and displays HANDSET REGISTERING.
3) When the handset finishes registering, it shows REGISTRATION COMPLETE in the display.
Posted on Jul 20, 2009
consultel1
  • 860 Answers
SOURCE: my cordless phone says
With the phone in standby, press MENU/SELECT on the base.
Move the cursor to select the Register Handset menu, and then press MENU/SELECT. Handset Registering will appear.
On the handset, press and hold # until the handset beeps and displays Handset Registering.
When the handset has registered to the base, the LCD will display Registration Complete then show the handset ID number.
If the display shows Registration failed, repeat the process again.
Note: If a handset has ever been registered to a base, reset the handset before you register it to a new base
Posted on Dec 21, 2009
SOURCE: Unable to register the handset
hi there i got the same problem but i fixed it .
Posted on Mar 04, 2010
KingDWS
  • 1606 Answers
SOURCE: I have a new Uniden cordless phone. The handsets
You can downlaod the manual from uniden in pdf form.
http://www.uniden.com/products/productdetail.cfm?product=DECT1580-4
the -4 or -5 refers to how many handsets you set. The 1580 is the actual model number.
To register I think all you do is place them on the master pad once then on their own charger stations. On some models they come all done so you just plug them in charge them up and use them.
Posted on Mar 23, 2010
Uniden dect 6-0 says its out of range but its by the base
Make sure the handset is registered to the base. Since you didn't specify the model of your Uniden DECT 6.0 system I can only suggest you select it from the list beginning here to download a copy of the manual.
Jan 11, 2013 | Uniden DECT 6.0 Cordless Phone ID
My gigaset c610h wont register
You can try to put the base in registering mode by using the web interface. Check your base user manual for further details.
The other plausible reason: Have you checked the DECT frequency range operation? My base was bought in Europe (1880~1900MHz) and the handset was bought in USA (1920~1930Mhz). So they are incompatible. :-(
Dec 16, 2012 | Gigaset C610h Additional Handset For C610a...
My cordless home phone showing REGISTER! on its screen and i am unable to make and receive a call.
The handset needs to be registered to work with the base. Since you didn't specify the model of your phone, I can't give you specific instructions for this. Select the model of your phone from the list beginning at
http://www.uniden.com/owners-manuals/dect-phones/scat/dectphones_mnl
to get the manual.
Jul 19, 2011 | Uniden DECT 6.0 Cordless Phone ID
How do you register a DECT 6.0 UNIDEN PHONE, LOST MANUAL?
You didn't give your phone's model number, so I can't give detailed steps. ("DECT 6.0" is a generic term for the cordless technology used, and appears on almost every cordless phone that uses it. The actual model number is on a label on the rear or bottom of the base unit.) Usually, registering a handset is just a matter of placing the handset on the base, but sometimes you need to enter a registration mode first. You can download manuals from Uniden here. Pick your model from the list, and the manual will guide you through the process.
May 15, 2011 | Uniden DECT 6.0 Cordless Phone
My phone vtech dect 6.0 has on the display not registered.
My Dear:
Yes, that is normal for all cordless phones. they are really just a radio that sends a signal from the base/charger to the cordless hand set. when the power goes off the base does not work at all. Go buy yourself a cheap corded phone, and when power goes off plug it into any wall phone jack and then you can make calls.
May 06, 2011 | Vtech DECT 6.0 Digital Cordless Phone
On one of the 3 phones I get no dial tone and the message "Unable to Call Try Again"
Re-Register a Handset to the Base
1. Remove Handset Battery.
2. Reconnect battery while holding down "*" and "#" key.
3. Then press the right upper key under the LCD.
4. Press the "End" key.
5. Wait a few seconds and then the phone will be ready to register to the base.
6. Set the phone on the desired base when the phone's display says to.
Mar 06, 2011 | AT&T DECT 6.0 Cordless Phone System with...
Handset won't connect to base unit
Try placing the handset in the base unit to register it. Then see if it is found by the base.
Mar 21, 2010 | Uniden DECT 6.0 Cordless Phone ID
My cordless phone says "to register see owners manual for help" How do I get the phone working, it is a uniden DECT 6.0 Model DECT 1588-2
Dec 21, 2009 | Uniden DECT 6.0 Cordless Telephone...
My siemens 4010 cordless phone is saying "Base Search" recently
"Base Search" will display for several reasons.
  1. The base station is turned off or not working properly.
  2. The handset is not registered.
  3. The handset may be registered somewhere else, de-register it.
  4. The units (both base and handset/s) may need to be reset to factory default.
You may have already tried this.
Jan 15, 2009 | Siemens Gigaset 4010 Cordless Phone
Thomson GE-28115FE1 Cordless Phone Logo
125 people viewed this question
Top Thomson Lands Phones Experts
george  peters
george peters
Are you a Thomson Lands Phone Expert? Answer questions, earn points and help others
