I have altec lansing speaker for my computer and there is static sound but no actual sound
    Genius:
  • 1,288 Answers
Check the speaker jack is plugged into the correct sound port... usually green if you are using 2:1 sound
Posted on Dec 28, 2010
Alot of static or interference through speakers
Check all leads are plugged in the right spots and are in good condition. Sometimes "static" is caused by plugs not connecting properly.
Nov 29, 2013 | Altec Lansing Audio Players & Recorders
One of the computer speakers I just bought doesn't work. Altec Lansing vs2620. The sound is so faint you can not hear it. How can I troubleshoot this?
try swapping the speakers around if the problem still persists either the speaker is faulty or
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
or you might have to clean the dust from your computer dust causes static which causes your computer to overheat and all sorts of problems
be sure to wear an anti static earth strap before touching anything inside your computer try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your SOUND CARD dust causes static to build up in a computer causing it to overheat any many other problems
hope this helps you
Aug 04, 2011 | Altec Lansing Audio Players & Recorders
My right speaker altec lansing vs4121 no sound only power
be sure to wear an anti static earth strap before touching anything inside your computer try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your SOUND CARD dust causes static to build up in a computer causing it to overheat any many other problems:
hope this helps
Jul 01, 2011 | Altec Lansing VS4121 Computer Speakers
My altec lansing ada885 computer speakers is making a constant buzzing sound every time I turn it on. Can anybody help me with this problem? plzzzz
hope this helps
May 20, 2011 | Altec Lansing ADA 885 Computer Speakers
Only one in the pair of altec lansing speakers is working.....the other one with volume control on it is'nt working ...what should i do ??
orbe sure to wear an anti static earth strap before touching anything inside your computer
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your sound card dust causes static to build up in a computer causing it to overheat any many other problems
hope this helps
don
Mar 07, 2011 | Altec Lansing Multimedia Computer Speakers
My speakers used to work and suddenlly stop then beganto where somtimes when i longed on they worked and other they would all i hear when i turn them up is static and now my compouter is saying the are no...
control panel sounds and audio,volume,advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make the necessary adjustments there or control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers
hope this helps
Oct 13, 2010 | Altec Lansing 2100 Computer Speakers
How do u take apart the speaker cabinet on an altec lansing ACS22 speaker?
the easy method is to drop it from Empire St Bld.
ha ha ha....
the difficult way is to check where are the screws on the speakers....mostly they are hidden behind the front perforation cloth or plastic sheet of sound out pad...that can be removed carefuly by using a small hook or a screwdriver...be careful not to hurt the actual speaker inside.
Jan 23, 2010 | Altec Lansing ACS22BW Computer Speakers
I'vebeen given an Altec Lansing Spealer system, AVS500, for a computer, but it is missing a power supply; 18 volts DC and 1 amp. Altec Lansing no longer make that series or its components Any...
lost instructions on how to hook up. Large speaker makes static. Right speakers work great.
All colors match but can not find the proper jack for the black wire coming out of large speaker
I suspect this is the problem
Oct 17, 2008 | Altec Lansing AVS 500 Computer Speakers
Vs4121 altec lansing left speaker wire ripped.
Black should be ground and red is usually the actual audio cable. If you connect them wrong the should not short. They will just sound weird until you connect them properly.
Hope this Helps
Thanks for reading!
May 02, 2008 | Altec Lansing VS4121 Computer Speakers
One drive for Altec Lansing Technologies Inc. 'ACS-295' dell
Hello there
What kind of help on specific device from altec you need?
be more specific
Nov 28, 2007 | Altec Lansing ACS 295 Computer Speakers
Computers & Internet Logo
David Payne
David Payne
