Question about Reddy Heater-30-55,000 BTU Variable
Act like going to start for about 60 sec and kicks off
  • 674 Answers
Check the flame sensor. It is probably dirty.Use a soft rag to wipe of the photo eye.
Posted on Dec 29, 2010
The settings for welding aluminium using a Tig200P AC/DC inverter
If you are using a remote then you would set the machine in standard for controlling output and also to AC output, HF tig, contactor and control in remote position. I don't know if this helps or not but I pulled it from an owners manual.
1/16" (.062) - pre-flow .1 sec., hot start 20, amperage 70, Hz 100, balance 20%, post-flow 6.0 sec.
For pulse settings - set pulse width 60%, peak current 100, background current 30, Hz 1.0
1/8" (.125) - pre-flow .1 sec., hot start 20, amperage 150, Hz 80, balance 20%, post-flow 6.0 sec.
For pulse settings - set pulse width 60%, peak current 150, background current 50, Hz 1.0
3/16"-1/4" - pre-flow .1 sec., hot start 20, amperage 185, Hz 60, balance 20%, post-flow 8.0 sec.
For pulse settings - set pulse width 60%, peak current 185, Background current 125, Hz 1.0
Mar 14, 2014 | ARC Thermadyne Inverter Stick/TIG Welder...
AFTER SETTING TIME COOK TO 1 MIN 60 SEC AND PUSHING START BUTTON 4O SECS MORE IS ADDED, I.E. TOTAL 2 MINS SHOW ON DISPLAY. CAN I RESET THE THE COMPUTER.
There are sixty seconds in a minute, so 1 min 60 sec is the same as 2 min. If you want 40 seconds less than 2 minutes then set it for 1 min 20 sec or for 80 sec.
Oct 03, 2013 | Danby DMW139 Microwave Oven
Evaluate 88ft/sec*1mile/5,280ft*3,600sec/hr
Take it in two steps.
Multiply 88 ft / sec by 1 mi / 5280 ft to get 88 ft*mi / 5280 ft*sec. 88 / 5280 is 1 / 60 and ft*mi / ft*sec is mi / sec so it simplifies to 1 mi / 60 sec.
Multiply 1 mi / 60 sec by 3600 sec / 1 hr to get 3600 mi*sec / 60 sec*hr. 3600 / 60 is 60 and mi*sec / sec*hr is mi / hr so it simplifies to 60 mi / hr or 60 mph.
Mar 04, 2013 | Cars & Trucks
Dryer won't spin...motor "kicks in" and acts like
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
Dec 16, 2010 | GE Profile Harmony DPGT750EC Electric...
1996 jeed grand sputers
this sounds like the infamous throtle position sensor. its the two wire conector on your throttle body that has two torx bolts holding it in. its a very easy and quick process. the part is about $50 and i wouldn't pay mor than $60 to have it done
Dec 27, 2008 | 1999 Jeep Grand Cherokee
Black screen
It sounds like your “Suspend Switch” is acting up. The Inspiron 1501 uses a mechanical switch to detect if the lid of the system is open or closed. A camber is built into the hinge of the system that activates the suspend switch plunger as the LCD is lowered to the closed position. If the switch is broken or nonfunctional, then it can be replaced separately. It is located under the hinge cover next to the right hinge on the system.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Oct 28, 2008 | Dell InspironTM 1501 Notebook
1997 pickup wont start. fuel filter is ok and getting fuel up to just before carbrator
IT sounds like the fuel pump to me.You will have to put a fuel pressure gauge on it and see that it has more than 50 psi.The engine needs between 50 to 60 psi to even run.I think you should just change the fuel pump.
Aug 30, 2008 | Chevrolet Silverado 1500 Cars & Trucks
My AC
One might think so, YES the compressor is running till it gets hot and tripps on hi-temperature, and after it cools down awhile, the switch willcautomatically reset itself and back- & forth......Thank-you-very much!
Jul 25, 2008 | GE Zoneline AZ38H12DAD Split System Air...
2001 accent code P1703
P1709 referrs to KICK DOWN SERVO SWITCH >- Open, short circuit DESCRIPTION Detects the point of time when K/D band starts operation to control fluid pressure when K/D band operates. Detection condition 1st or 3rd gear signal is present for more than 5 sec. Transfer shaft speed is greater than 900 rpm Fluid temperature is above 60°C PCM receives an "OFF" signal from K/D servo s/w Check item Harness & connnector K/D servo s/w K/D servo assembly
Jun 11, 2008 | 2000 Hyundai Accent
Reddy Heater-30-55,000 BTU Variable Logo
23 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
