Question about Bosch SHU9915UC Dishwasher
Machine is leaving residue on everything after full wash cycle>
  • Bosch Master
  • 43,501 Answers
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
\\000\
Posted on Feb 27, 2011
How do you clean the estate heavy duty 8 cycle 2 speed washing machine
You stop using the disgusting liquid detergent that is causing the stench, first off, switch to Powdered Detergent, then leave the lid up when you aren't using the machine. 6 months from now it will be fine, otherwise, you can disassemble the washtubs and scrape the liquid detergent residue of everything with a putty knife... Option 1 is better, trust me.
May 02, 2016 | Estate Washing Machines
My Tromm washer is leaving residue on my clothes
Make sure you are using the correct soap. (Front load soap powder) Also use a bit less than suggested on the packet. If you are often using cold or low temp wash cycles, dirt and build-up in the machine will be common and come off on your clothes. Use a very hot wash at least once a month to clean it out and stop using fabric softener. It sticks to everything and any dirt in the water gets stuck on and then comes off in later wash cycles.
Sep 25, 2014 | LG WM2688HWM TROMM SteamWasher
Soap residue fisher & paykel top loader
Agitator can be removed easy,Take out the fabric dispenser cup,
Reach down inside the agitator & undo the wing nut, left to undo.
Take out agitator & clean & the bottom of the bowl,
For a more better clean fill machine with hot to high water level & leave soak over night,Do heavy duty wash in the morning to remove scrud.
Feb 10, 2013 | Fisher and Paykel Washing Machines
Producing debris when in spin cycle
2.13.1 Scrud
If fabric softener is used regularly it will eventually cause a build up within the outer bowl. This can
result in black flakes present in the wash load that can stain garments. To remove scrud follow the
procedure below.
Step1: Add a full cup of a good quality dishwashing powder such as Active or a similar product
into the machine.
Step 2: Set the machine to a Heavy Duty cycle, select a Hot Wash temperature, High Water level
and allow the machine to agitate for 10 minutes.
Step 3: Leaving the lid closed, turn the machine off and allow to soak overnight.
Step 4: The following day, turn the machine on and advance to the spin cycle to drain the water
from the machine. After the water has drained, turn the machine off then back on again, and select
a Heavy Duty cycle, Hot wash, High Water level, and allow the machine to complete a full cycle to
ensure that all of the loose scrud and residual detergent has been flushed away.
Note: If there is an extremely heavy build up the bowl will have to be removed for pressure washing
Dec 15, 2012 | Fisher and Paykel GWL11 Top Load Washer
My GE profile dishwasher is leaving soap residue on the dishes after a wash cycle. Cloudy and a sort of fim on the dishes. Seems to be getting worse. I use the same dish detergent-Cascade and regulary use...
The problem is most likely that there is still water residue at the bottom of your machine. If the machine is not fully drained it picks up some of the residue and sprays that onto the dishes during the final rinse, leaving an unhealthy and unsightly film on everything.
Remove the bottom strainers and make sure that there is nothing obstructing the outlet pipe and the pump. If possible back flush through the outlet pipe and try draining the machine again before using it again.
Mar 04, 2011 | GE Dishwashers
I've had my dishwasher (GU2455XTSB3) for almost 2 years. The first year and half were great. I always use the same cycle (with options) and it took approximately 1.5 hours to complete. Now it takes over 3...
heatman101
Oct 23, 2010 | Whirlpool GU2455XTS Built-in Dishwasher
Black type residue being left on clothes
This is a common problem on washing machines, if you predominantly do cold washes.
Over a period of time, a washing machine will accumulate a buildup of Soap Scum (excess soap & softener residue) which can stick to the inside of the drum.
This black coloured soap scum occasionally breaks away from the drum, and attaches to the clothing fabric during the wash cycle.
You can rectify this, by doing the following:
Firstly, purchase a packet of CITRIC ACID from your local grocery store (usually found in the baking isle).
Do the following procedure before going to bed:
1) Do a HOT WASH without clothes (Hi water level, with HOT water) - allow machine to fill with hot water, then add the CITRIC ACID to the water. Allow the machine to complete a FULL wash cycle (i.e. allow machine to agitate for 30 mins or so, then drain).
2) Fill the machine again with the HOT water / CITRIC ACID solution, but this time allow it to sit in the bowl overnight (no cycle).
3) Next morning, set machine to spin & drain (i.e. to empty the solution)
4) Set machine to fill with FRESH HOT WATER ONLY (no citric acid), then set machine to spin & drain. This will flush all remaining residue left in the bowl.
Note: Soap scum residue is caused by using excess detergent/fabric softener. Hot Water flushing should be done every 6 months.
Contrary to what the detergent manufacturers state, you should follow Samsung's instructions by using HALF the recommended detergent.
Samsung machines prefer LOW SUDS, and you may find by reducing the amount of detergent used, you may even eliminate the buildup of soap scum.
"If this has helped resolve your issue, please rate this solution"
Oct 31, 2009 | Samsung SW62ASP Top Load Washer
Clothes coming out spotted
Hi Residue builds up inside of washing machines for all sorts of reasons. Many detergents and fabric softeners can leave filmy layers behind. Hard water can cause spotting on both plastic and metal thus ending up with spots on your washing, how to resolve this follow the instructions, 1, use vinegar a bottle and place your machine on the hottest wash cycle and let it run through a full cycle, when finished use a paper towel with vinegar to clean the inside, set machine on a rinse cycle, this may need to be repeated but will solve it, also use gels and liquids instead of powders and descale etc.
Jul 18, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Horrible smell coming from the washing machine
Have you cleaned the filter in the washing machine?
Mar 31, 2009 | AEG 24 in. Favorit 40660i Built-in...
Put washing powder in tray ,machine doing wash but leaving large residue of powder
Don't put the powder in the tray. Select you wash cycle, let the water run into the washing machine, then add the powder.The powder should dissolve before you put your clothes inside the machine. Let the washing machine fill up to almost half way and add clothes. This should stop the clothes from getting the residue powder on it.
Mar 23, 2009 | Whirlpool Washing Machines
Bosch SHU9915UC Dishwasher Logo
91 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
