Question about Mercury Boating
2004 merc 4.3 tks will not start, looks like something missing from harness, purple/yellow, 2 black wires with nothing connected
    Champion:
  • 202 Answers
Black wires ground p/y accesory
Posted on Mar 16, 2011
I need a wiring or instalation diagram for 03 silverado
Download manual from the attached link: https://www.gmupfitter.com/publicat/2004_BB/2003_Beyond_LD_Electric_CK.pdf
http://alarmsellout.com/support/diagrams/vehicle/CHEVROLET%20SILVERADO%201988-2005.pdf
This may help:
http://www.automotivetroubleshootingsecrets.com/2003_Chevrolet_Silverado_1500_4.8L_No_Start_Stall.html
This may help:
2003-2006 Chevrolet Silverado Wiring Diagram:
Listed below is the vehicle specific wiring diagram for your car alarm, remote starter or keyless entry installation into your 2003-2006 Chevrolet Silverado . This information outlines the wires location, color and polarity to help you identify the proper connection spots in the vehicle. Please be sure to test all of your wires with a digital multimeter before making any connections.
PART COLOR LOCATION 12 VOLT CONSTANT RED (+) @ IGNITION SWITCH HARNESS STARTER YELLOW (+) @ IGNITION SWITCH HARNESS STARTER 2 N/A IGNITION 1 PINK (+) @ IGNITION SWITCH HARNESS IGNITION 2 WHITE (+), SEE NOTE #2 @ IGNITION SWITCH HARNESS IGNITION 3 N/A ACCESSORY/HEATER BLOWER 1 ORANGE (+) @ IGNITION SWITCH HARNESS ACCESSORY/HEATER BLOWER 2 BROWN (+) @ IGNITION SWITCH HARNESS KEYSENSE N/A PARKING LIGHTS ( - ) GRAY/BLACK (-) @ BCM, BROWN PLUG, PIN B2, SEE NOTE #3 PARKING LIGHTS ( + ) BROWN (+) IN DRIVERS KICK PANEL POWER LOCK SEE NOTE #1, (for BASE MODEL TRUCKS, SEE NOTE #4) POWER UNLOCK SEE NOTE #1, (for BASE MODEL TRUCKS SEE NOTE #4) DOOR TRIGGER GRAY/BLACK (-)(DRIVERS) and BLACK/WHITE (-)(PASSENGER), SEE NOTE #5 @ EACH DOOR MODULE, IN EACH DOOR DOMELIGHT SUPERVISION GRAY/BLACK (-) @ BCM, BLACK PLUG, PIN E, SEE NOTE #3 TRUNK RELEASE N/A SLIDING POWER DOOR N/A HORN BLACK/YELLOW to BLACK (-) @ STEERING COLUMN HARNESS TACH Any wire NOT, PINK, BLACK or BROWN (AC) @ IGNITION COILS or FUEL-INJECTORS WAIT TO START LIGHT DK. BLUE (-) @ INSTRUMENT CLUSTER, PIN A2 BRAKE WHITE (+) @ BRAKE PEDAL SWITCH FACTORY ALARM DISARM LT. GREEN (-) @ DRIVERS DOOR MODULE, IN DOOR, BLACK 26-PIN PLUG PIN 15 ANTI-THEFT GM'S PASSLOCK 2 ANTI-THEFT SYSTEM, SEE NOTE #1 @ IGNITION SWITCH EXTRA INFORMATION NOTE #1: This vehicle uses GM'S PASSLOCK 2 ANTI-THEFT SYSTEM that requires a 791 Bypass Module to Remote Start, if you are using a REMOTE STARTER ONLY, use the 791. IF you are installing a REMOTE STARTER with KEYLESS ENTRY you MUST USE the INTERFACE BYPASS MODULE, Part # DB-ALL or XK09, EITHER Bypass will do the Anti-theft and Keyless entry. If connecting a keyless entry only you can use the GMDL-BP. NOTE #2: The IGNITION #2 wire WHITE must be connected to prevent a CHECK ENGINE LIGHT from turning on and to prevent DAMAGE to the TRANSMISSION on this Vehicle. NOTE #3; The BCM is located under the Drivers Side of the dash, the BCM has 6 plugs on it, with the PURPLE plug on the back. NOTE #4: On BASE model truck the DOOR LOCK INTERFACE MODULE is not necessary, the LOCK wire is a LT BLUE (TYPE B) @ the BCM, LT BLUE PLUG, PIN B5, and the UNLOCK wire is a WHITE (TYPE B) @ the BCM, LT BLUE PLUG, PIN B10. NOTE #5: On BASE Model trucks, the Door Trigger wires are @ the BCM, LT BLUE PLUG, PINS B4 and A5. On 4-Door Trucks the LEFT REAR Door is a LT BLUE/BLACK (-) PIN A3 and the RIGHT REAR Door is a LT GREEN/BLACK (-) PIN A2, located in a PURPLE PLUG at the BCM, use all 4 wires and diode isolate when installing an alarm system.
2011-03-28_044351_brakes_lamps_circuit_2003_2500_siverado-dfydxumns33ohqc3bsmt22yf-2-8.gif
collection-fuel-2003-chevy-silverado-wiring-diagram-estimation-information-standard-work-therefore-straight-swapped-dfydxumns33ohqc3bsmt22yf-2-34.jpg
igniton-black-2003-chevy-silverado-wiring-diagram-neutral-before-position-begin-switch-know-scheme-unsure-pairs-dfydxumns33ohqc3bsmt22yf-2-53.png
sensor-primary-2003-chevy-silverado-wiring-diagram-fuel-pump-plugs-solid-conductors-important-looking-more-channels-dfydxumns33ohqc3bsmt22yf-2-76.png
igniton-black-2003-chevy-silverado-wiring-diagram-neutral-before-position-begin-switch-know-scheme-unsure-pairs-dfydxumns33ohqc3bsmt22yf-2-151.png
Apr 16, 2017 | Cars & Trucks
A/c compressor keeps blowing fuse
Disconnect The AC compressor clutch, does the fuse still blow.
Oct 21, 2012 | Cars & Trucks
I just bought Alpine car stereo CDE-100EUB but I'm having trouble connecting it to my old car toyota Rav 4 2004 model because the wire harness are different. also the alpine wires are more in numbers than...
Please let me know if you have any questions, and thanks for using FixYa.
2004 Toyota RAV4 Car Stereo Radio Wiring Diagram Alpine wire color
Radio Constant 12V+ Wire: Blue/Yellow yellow
Radio Ignition Switched 12V+ Wire: Gray red
Radio Ground Wire: Brown black
Radio Illumination Dimmer Wire: Green none
Radio Antenna Trigger Wire: N/A blue
Radio Amplifier Trigger Wire: N/A blue/white
Front Speakers Size: N/A
Front Speakers Location: N/A
Left Front Speaker Wire (+): Pink white
Left Front Speaker Wire (-): Purple white/black
Right Front Speaker Wire (+): Light Green gray
Right Front Speaker Wire (-): Blue gray/black
Rear Speakers Size: N/A
Rear Speakers Location: N/A
Left Rear Speaker Wire (+): Black green
Left Rear Speaker Wire (-): Yellow green/black
Right Rear Speaker Wire (+): Red violet
Right Rear Speaker Wire (-): White violet/black
Jan 02, 2011 | Alpine Car Audio & Video
How to disarm or reset an alarm system for a 1996 Jeep Cherokee?
Hope this helps:- Factory Disarm Purple/Yellow (-) Driver's Kick Panel Black Connector at ECM -slice into this wire, & wire it to ground, this disables the alarm.
Cavity/Fuse Diagram (1996 Grand Cherokee, passenger side kick plate to find, Owner's Manual pgs 205-206): 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22
Row 1: 1-6 (left to right) Row 2: 7-12 Row 3: 13-18 Row 4: 19-22
1996 Jeep Grand Cherokee Fuse Panel (Passenger Side kick panel) Reply
CAVITY FUSE DESCRIPTION 1 -10 amp (RED) Radio 2 -15 amp (Lt Blue) Cigarette Lighter 3 -10 amp (RED) Rear Washer Switch, Body Controller 4 -10 amp (RED) Airbag 5 -10 amp (RED) Lamp Out Module, Overdrive Switch, OBD II 6 -15 amp (Lt Blue) Vehicle Information Center/Graphic Display Module Park & Side Lamps, Overhead Console Lighted Visor, Automatic Dimming Mirror 7 -20 amp (Yellow) Body Amp, Cluster, Body Controller 8 -20 amp (Yellow) Rear Wiper Motor, Flipper Glass Solenoid, Cargo Lamp, Trailer Tow 9 -15 amp (Lt Blue) Brake Switch 10- 10 amp (RED) Rear Window Defroster 11 -10 amp (RED) ABS Module 12 -10 amp (RED) Heater-Ventilation-A/C Control & Recirculation Motor 13 -15 amp (Lt Blue) Hazard Switch, Turn Signal Switch 14 -15 amp (Lt Blue) Spare 15 -15 amp (Lt Blue) Spare 16 -10 amp (RED) Right & Left Courtesy Lamp, Glove Box Lamp, Halo Lamp Cargo Lamp, Underhood Lamp, Dome/Read Lamp Right & Left Visor, Automatic Dimming Mirror 17 -15 amp (Lt Blue) Radio Illumination, Tail Lamp, Graphic Display Module, Park & Side Lamps, Headlamp Switch, Body Controller 18 -20 amp (Yellow) Spare 19 -15 amp (Lt Blue) Passing Light 20 -15 amp (Lt Blue) Radio, Heater-Ventilation-A/C, Vehicle Information Center 21 -15 amp (Lt Blue) Power Outlet 22 -10 amp (Blue) Airbag Module -------------------------------------------------------------------------------------
1996 Jeep Grand Cherokee Alarm, Remote Starter, Keyless Entry Wiring Information Constant 12V+ Pink/Black Ignition Switch Harness Starter Yellow Ignition Switch Harness Ignition Dark Blue/Gray Ignition Switch Harness Ignition 2 Red/Black Ignition Switch Harness (for AC) Accessory Black/Orange Ignition Switch Harness Tach Gray/White Coil Brake Switch White/Tan Brake Switch Trunk Pin n/a Works with Dome Light Parking Lights Blue/Red (+) Left of Steering Column or Light Switch Head Lamp Tan/Black Light Switch Factory Disarm Purple/Yellow (-) Driver's Kick Panel Black Connector at ECM -slice into this wire, & wire it to ground, this disables the alarm. Door Trigger Yellow (-) Driver's Kick Panel see notes Door Lock 5/Wire in Driver's Inside Driver's Door Orange/Purple Lock Pink/Black Unlock Door Unlock and Passenger's Doors Inside Passenger's Door Black/White L Pink/Black Unlock Horn Wire Gray/Orange (-) Steering Column Windows Up LF=Light Blue, RF=Brown/White, LR=Blue/White, RR=Gray/Black Doors Windows Down LF=White, RF=Purple/White, LR=Red/Black, RR=Green/White
• Cruise Control Information • Stereo Information • View all Jeep Vehicles
Dec 18, 2010 | 1996 Jeep Grand Cherokee
I have a fairly old panasonic car stereo/cd changer. i just need the wiring diagram for it. what color equals what? i typed in the model number but nothing turns up. . . i had to replace the old system,...
Here is the Colors of the Cars factory harness
Constant 12V+ Red Switched 12V+ Red/White Ground Black Illumination n/a Dimmer Orange/White Antenna Trigger Yellow Antenna Right Front Front Speakers 3 1/2" Dash Left Front (+) Green Left Front (-) Green/Yellow Right Front (+) Purple Right Front (-) Purple/Yellow Rear Speakers 6" x 9" Rear Deck Left Rear (+) Brown Left Rear (-) Brown/Yellow Right Rear (+) Blue/Red Right Rear (-) Blue/White
And Here is the Chart for the radios wiring
Red 12V+ Switched power
Grey Right front speaker +
Grey with black stripe right front-
White left front +
white with black stripe l/f -
Purple R/R +
Purple with black stripe R/R -
Green l/r +
green with stripe l/r -
Black ground
orange illumination
yellow constant power
Apr 07, 2010 | Car Audio & Video
For the Clarion DXZ945MP CD Player for car audio, I do not know the the wire harness color wire diagram? The wiring harness on my Monte Carlo 2000 reads what color wire goes to what, on the side of the...
3amp yellow battery for deck
15 amp yellow is another battery wire
purple right rear + speaker
purple/black right rear -
green left rear +
green/black left rear -
white fr left +
white/black fr left -
grey fr right +
grey/black fr right -
blue auto antenna
blue/white rem amp
brown phone mute
orange/white illumination
red accessory
hope this helps
pls rate cause people arnt rating
Nov 05, 2009 | Clarion DXZ945MP CD Player
1998 Suburban Fuel Pump wiring harness replacement. On the vehicle are 4 wires in the harness, Black/Gray/Purple/heavier Gauge Black. A mechanic in the past spliced a replacement harness as - heavier Black...
if its the correct harness then yes... i would follow colors.conecting the thinner black to the orange/black.
i have built and repaired wire harness' for four winds rv for 5 yrs now and previously gm cars for 4 yrs
Apr 27, 2009 | 2003 Chevrolet Suburban
Purchased a Thor Alarm with door locks and autostart and trunk release I believe model CF425 and was curious if anyone had a wiring diagram not sure what each wire is. One harness has 12 wires the other...
I have this alarm / remote start / keyless entry system and I have the poorly translated installation manual. Everything in mine installed fine in my 2005 suzuki aerio (except the power locks as the manual is worthless in that area) but I have heard nothing but horror stories from others online since I installed it.
I don't recommend you install it but if you really are determined, here is what the manual says (or tried to say and I spent 4 hrs interpretting / correcting it:
8 wire harness:
-- The 4 wire connector connects to the 4 wires harness part of the 3 relays
-- The yellow connects to the yellow of the breaker relay yellow
-- yellow w/black stripe connects to the oil sensor on the motor (look for single wire connected to sensor and generally a heat shield wrap/weave, mine was blue)
-- orange connects to the brake switch on the brake pedal
-- the blue connects to the door switch /dome light trigger
12 wire harness:
-- 6 central locking wires orange, yellow, and white plus the same 3 with black stripe.. Unfortunately the manual is not clear as to where they connect. The next page of the manual shows diagrams but they mysteriously add a white stripe to all the colors and the white wires apparently become green. I suspect that orange is not likely used in most installations and for positive door lock types (the most popular), yellow goes to unlock and yellow w/ black stripe goes to lock signal and the 2 whites go to 12v+. This is only a guess so don't hold me to it.
-- black is grounded to frame
-- Red is 12v+
-- red w/ black stripe goes to power trunk release (if equipped)
-- The 2 browns go to the left and right turn signals
-- The pink goes to the alarm
Ignition switch connections
The breaker relay:
-- blue goes to the ACC ON wire
-- Cut the ignition wire and connect the 2 greens to each end
-- Yellow connects to the yellow of the 8 wire harness
The 3 relays:
-- 4 wire harness connects to the 4 wire connector of the 8 wire harness
-- the 3 reds connects to the 12v+ red of the ignition switch (or thru the firewall to the battery)
-- black connects to the ignition on the downstream side of the 2 greens of the breaker relay
-- white connects to ACC ON
-- blue connects to the starter
Apr 25, 2009 | Vehicle Parts & Accessories
Audio wiring problem
Constant 12V+ Blue/Yellow
Switched 12V+ Gray
Ground Brown (or your own wire to a metal grounding point)
Illumination Green
Antenna Trigger Black/Red
Front Speakers 4" Dash
Left Front (+) Pink
Left Front (-) Purple
Right Front (+) Green
Right Front (-) Blue
Rear Speakers 5 1/4" Rear Deck
Left Rear (+) Black
Left Rear (-) Yellow
Right Rear (+) Red
Right Rear (-) White
I a '83 camry, there are 2 seperate plugs that go into a factory radio.
One for Power/and front speakers, and the other for rear speakers.
Sounds as if you are missing part of the harness for the rear speakers (or it is shoved in the back of the dash unused by the previous install). If there is not an un-cut plug in the dash - your only course of action would be to run your own set of speaker wire to the rear.
See this picture... these are the plugs that should go into your factory radio....
Metra kit 71-1938 will go from your factory wiring directly into your factory radio.
Thanks for using FixYa - a FixYa rating is appreciated for my effort in answering this Freebie question.
Feb 25, 2009 | 1983 Toyota Camry
Ford focus 1999
Pin --- Color --- Stripe --- Function
Harness 1
1 --- White --- Black --- Left front +
2 --- Gray --- Black --- Left front -
3 --- White --- Purple --- Left rear +
4 --- Gray --- White --- Left rear -
5 --- White --- Red --- Right front +
6 --- Gray --- Red --- Right front -
7 --- White --- (none) --- Right rear +
8 --- Gray --- (none) --- Right rear -
Harness 2
1 --- (not used)
2 --- Black --- Green --- Radio Ground
3 --- (not used)
4 --- Orange (thin) --- Black --- Radio Illumination
5 --- Green --- Yellow --- Radio switch
6 --- Black --- Yellow --- Radio Ground
7 --- Orange (thick) --- Black --- Radio 12V
Harness 3
1 --- White --- Green --- Speed sensor
2 --- (not used)
3 --- (not used)
4 --- (not used)
5 --- (not used)
6 --- (not used)
Dec 22, 2008 | 2003 Ford Focus
Boating Logo
Top Mercury Boating Experts
Colin Stickland
Colin Stickland
Joseph Hoffmann
Steve
Steve
Are you a Mercury Boating Expert? Answer questions, earn points and help others
