Question about Onkyo TX-DS595 Receiver
Onkyo Subwoofer. Hi, my Onkyo subwoofer is not working and I think I know the reason. The power rating is 110 volts but I connected it to 220 volts (in India) and probably that's why it's not functioning. Is that a serious problem? Can I fix it without spending much and do you think I can fix it myself? Please let me know. Vish
    Brigadier General:
  • 8,546 Answers
Didn't you smell the smoke? It's dead. But all is not necessarily lost. I have a 'powered' subwoofer in which the amp died but I just went inside it and ran speaker wires directly to the outside from the driver and I run it with an external amp.
Posted on Apr 24, 2009
How do you connect the skw 360 subwoofer to the onkyo tx-sr505 av receiver
Hi Kenny, sorry you can't. The TX=SR505 requires a powered subwoofer. The SKW-360 is passive. Thank you, Onkyo USA
Dec 02, 2016 | Onkyo Audio Players & Recorders
I have 2 onkyo home theater systems, one is an older ht-r8230 with an skw-8230 powered subwoofer & the other system is a ht-r420 with s powered skw-420 sub. all i did was change the rooms the 2 systems...
It's possible that you have accidentally switched off the sub-woofer outputs on the receivers. Onkyo have a speaker set up test. You should run that and see if the speakers are on and that a signal is getting through to them.
May 28, 2017 | Onkyo SKW-110 Subwoofer
My onkyo reciever working very well but last 2 days subwoofer out put off from receiver .... subwoofer is ok
Hi, If you have remote to receiver try hitting the speaker setup selection. I am thinking perhaps a speaker setting was inadvertantly taqmpered with. In speaker settings you will have such things as distance setting-speaker size-delay etc..then you should come to a selection for whether or not a subwoofer is used ie: subwoofer : on, off.. I hope this has been of some use and thank you for choosing FixYa,Good luck, Prodzilla
Apr 13, 2011 | Onkyo Audio Players & Recorders
Onkyo skw 150 powered subwoofer output code
whatisthe codewriten behindtheoutput of the onkyo subwoofer skw 150my ou6666088.jpgt put is bad in sucha way that ican not retrieve the the code
Feb 12, 2010 | Onkyo SKW-200 Subwoofer
Will skw204 power sub work with my txsr605 onkyo
yes here is the manual for it.
http://63.148.251.135/redirect_service.cfm?type=own_manuals&file=SKW204_En.pdf
now you will see this picture on page 5
768816d.jpg now where it says 6 this is your line input. Now you will plug in a subwoofer cable to this and on back of your receiver to the subwoofer output. and you now must enable the subwoofer option in the setup menu of receiver i think it would be under speaker configuration.
Mar 01, 2009 | Onkyo TX-SR605 Receiver
Can't connect subwoofer to onkyo av receiver
you would need a y jack to connect those to the receiver
Feb 16, 2009 | Onkyo HTR500 Receiver
Dont understand
this is retarded comment .... 20 what is 20 ? this is not how we compare receivers.... you ****...
May 09, 2008 | Onkyo TX-SR605 Receiver
No signal on subwoofer out in Onkyo TX-SR703(E) - similar to TX-SR803
Hey Tad, I have the same problem and perhaps a solution. I just moved to the other SW "pre-out" and it seems to be working..the green light is on . Whatever works i guess.
Jan 24, 2008 | Onkyo TX-SR703 Receiver
Onkyo TX-DS595 Receiver Logo
343 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
