Question about Marantz SR-4300 Receiver
How do i use the second optical input? - Marantz SR-4300 Receiver
    Brigadier General:
  • 8,546 Answers
On page 19 of the manual (available at retrevo.com) it explains how you assign each of the 4 assignable digital inputs to a source.
Posted on Dec 29, 2010
How do I change the audio setting to use a digital optical audio cable on model 42LG30
bout 7,180,000 results (0.54 seconds) Search Results
    Xbox Audio Settings ' Connect And Configure Digital Audio ...
    https://support.xbox.com/en-US/xbox.../configure-audio-settings
    XboxConnect your Xbox 360 E console to your HD TV using the HDMI cable. Connect one end of a cable (not included) to the digital audio output port on the television. Connect the other end to the digital audio input port your stereo or home entertainment system.
    PS3™ ' Audio Output Settings
    manuals.playstation.net > Settings > Sound Settings
    These settings are mainly used when the system is connected to audio ... and theaudio device using a digital optical cable and switch to [Optical Digital] under ...
    Enabling the optical digital input for an audio source - Bose
    worldwide.bose.com/.../en_us/...optical.../page.html
    Bose CorporationWhen you use optical cable to connect digital audio from another device to your system, the optical input needs to have the correct source assigned.
    HDMI vs. optical: Which digital-audio connection to use ...
    www.cnet.com > Home Entertainment
    CNETMar 13, 2014 - Both HDMI and optical pass digital audio from one device to another. Both are better ... The cables are cheap, and having just one wire simplifies setup. If you can't, ..... Try changing the decoding on your ps3. You have the ...
    Selecting Audio Settings for a Non-Contour DVR Cable Box
Jan 19, 2016 | LG Televison & Video
Connect Apple tv to Philips LX700
OPTION 1 (using remote):
Press the system key on the remote,
find the digital input option,
choose optical,
finish!
OPTION2: (Using LX700 button)
"program" button on the front panel for 5 seconds,then press LEFT or RIGHT button to choose DIGITAL INPUT,and Press "program" button again,then change coaxial to optical by rotating VOLUMN control on the front panel. then just confirm by pressing the "program" button again and wait for 5 sec to quit menu. Now switch OFF and switch ON receiver again.
Now make sure the source id DISC IN (ie., digital input ).
Your LX700 should be picking up optical signal!!
It worked for me and i hope it works for you to as well.
-SASi (ssasi2000@gmail.com).
Dec 15, 2012 | Philips LX700 System
Hi. I write from spain. I have the blu-ray LG
Have you tried the another optical cable? They don't tolerate dirty connections or small-radius bends in their routing. THAT (and the expense of optical cables) is why I always choose coaxial connections when possible.
Mar 02, 2011 | Yamaha RX-V363 Receiver
Input signals Marantz SR4003
There are four digital connectors on the back of the unit: 2 optical and 2 coaxial. They are marked a s 1 2 3 4. 1 and 2 are optical, 3 and 4 - coaxial. Also you have front optical connector marked as F.
You can connect 5 digital sources to your receiver. For example, connect your DVD to input 2 (optical) by optical cable and connect your DSS to input 3 by coaxial cable. Assign DVD to digital 2 and DSS to digital 3 in input setup menu.
Aug 14, 2009 | Marantz SR5001
Which optical inputs should I use for (1) audio output from hi-def cable box (connected to HDTV with component cables) and (2) audio output from DVD (connected to 3805 with component cables?
Hi, the Optical and Coaxial inputs are assignable to whichever input you need them on. Plug the Optical cables from your DVD and HD cable box into any of the OPTICAL INPUTS (1 and 2 is fine, but write down your connections on paper)
You will then need to go into the setup of the AVR on the screen and assign the OPTICAL connections to the correct inputs (Probably TV/CAB and DVD.
Use the SYSTEM SETUP button on the factory remote, and you should see the on-screen menu appear on your TV. Go to INPUT ASSIGNMENT and choose the input for the DVD and assign OPTICAL 1 or 2...
Reply here if you need more help.
Jul 06, 2009 | Denon AVR-3805 Receiver
Having problems with HDMI connection from COMCAST Motarola HD Dual TUNER DVR HDMI DCH6416 to Panosonic Home Theater system SA-PT660 to AKAI LCD HDTV. There is only one HDMI Output on the COMCAST box; one...
Connect the HDMI outputs on your various components to the HDMI inputs on your receiver. Connect the HDMI output on the receiver to the input on your TV. HDMI incorporates digital audio, so no need to buy optical audio cables. If your receiver does not have HDMI inputs for all your components, you will need to make a choice. HDMI = Best, component video + optical audio = second best, S-video+ optical audio = third best
Jan 01, 2009 | Onkyo TX-SR606 Receiver
Sa-dx1040 dvd optical input works, tv and cd do not.
You have to manually select digital input on the receiver.
Jun 11, 2008 | Technics SA-DX1040 Receiver
Optical inputs
Hi boltbob
Strange one... . The unit has'nt just lost its presets for optical input selection by chance. Most receivers have a volatile memory for user presets that can reset input settings to default when the unit has been unplugged for a period of time. This may mean that your amp is not looking at the optical inputs for that source. If it has correctly selected the optical inputs, then something common to all optical inputs has failed, maybe a a buffer stage between optics, D/A or Source switching stages.
Try disconnecting the unit from the wall socket for 10 mins to do a hard reset and see if that has any resolve to the issue.
Other than that, its out with the multi meter anbd do some DC checks about the optical , buffer and d/a stages. Try the reset and let me know how you go.
regards
robotek
May 05, 2008 | Denon AVR-3805 Receiver
Onkyo TX-DS939 optical selection problem help!
That coaxial, opt-1 and opt-2 are available only if they are not selected to some other channel. So you have to check if opt-2 is selected to Video-1,2,3,4,5,6,7,CD or DAT. Change that to Analog and then opt-2 is free to another device.
Mar 24, 2008 | Onkyo TX-DS939 Receiver
Marantz SR-4300 Receiver Logo
161 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
