Question about D-Link AirPlus Xtreme G DI-624 Wireless Router (DI624RE)
Hi, I have a d-link DI-624. My laptop recently crashed and i got it fixed. Before it used the d-link to connect to the internet. But now it won't connect. It says its connected but then i click on the internet and its not working. Please help me. Gabrielle
Benimur
  • 6966 Answers
SOURCE: Have D-link 704 router, can I connect the DI-524 to it also to add wireless?
Hi, I have not tried it myself with DLink but with LinkSys, yes it will work. It may take a little configuration tinkering but should work. However a few notes: 1. You should only have 1 DHCP server (both have this feature); 2. You can not have 2 identical IP address; 3. I suggest you make the 524 as the gateway and the 704 as a slave; 4. In effect you will connect 1 of the LAN port of the 524 to the WAN input of the 704; 5. You have to copy the WAN settings of the 704 to the WAN settings of the 524; 6. Or if you want to retain the 704 as the gateway, disable the identical features in the 524. I suggest you treat the 524 as a client of the 704. Hope this gives you some idea and work out for you as it did with my LinkSys. Goodluck and kind regards.
Posted on Aug 17, 2007
Shuttle83
  • 1139 Answers
SOURCE: D-link DI-624 wireless router connectivity problems (DNS suffix)
Might I suggest that you reset the router to its default configuration by pressing and holding the reset button until it reboots. This way you will be dealing with the default configuration. Then try to use it. Remember the default login ID is admin and the password is Password or admin. Lets hope this helps
Posted on Sep 04, 2007
sandrew
  • 2961 Answers
SOURCE: D-Link DI-524 AirPlus G - Laptop Cannot Connect to the Internet
Go to control panel>network connections, right click, then properties, then click the TCP/IP line, properties again and ensure that 'obtain ip address automatically' is ticked, click ok,  then close down the window, right click on the network icon again and then properties, then view wireless connections.
Any that appear in this list including your own if it shows need to be deleted, then when you close the window a pop up should appear in the task bar saying wireless networks detected, click the bubble then highlight your connection, click connect and if security is turned on you will be prompted to enter the passkey.
In the routers settings ensure that DHCP is enabled to allocate ip addresses automatically, then reboot the router if neccasary.
Posted on Oct 22, 2007
  • 239 Answers
SOURCE: D-Link DI-624 wireless router is not working after firmware upgrade try
Try to unplug the router and hold in reset button for 30 seconds see if that works, you probably did that already, But if you can get your computer to respond you should be able to open software Bios. and do your firmware update from there. If not I believe a hard reset is with the router plugged in and holding reset button for 30 seconds, I don't know I sure hope that resets it for you. Thanks take care
Posted on Dec 24, 2007
  • 10 Answers
SOURCE: D-Link DI-624 won't work!
hi thanatos
try resetting the router back to default settings by holding in the reset button for 30 seconds this is found on the back of the router you will need a small pointed pencil or paperclip to do this
Posted on Feb 08, 2008
Seting router d-link airplus g+ tm 624
You can set up for that dlink router.Do this step.
Click start>open internet explorer and the address URL type http://192.168.0.1 press enter.
Username admin
password leave blank
For setting details click this link to download user manual guide http://www.dlink.com/products/?tab=3&pid=DI-624&rev=DI-624
Hope can help you.
Thanks using fixya.
Jul 11, 2011 | D-Link AirPlus Xtreme G DI-624 Wireless...
D Link DI 624 stopped talking to computers
Just a matter of accessing router software and re- typing U/N and P/W
Dec 23, 2009 | D-Link Computers & Internet
What is the latest upgrade Firmware
Hi, You need to make sure you use a hard-wired connection to upgrade your router and the latest firmware can be found at http://support.dlink.com/products/view.asp?productid=DI%2D624%5FrevC#firm (This is for North American users only! If you do not reside in North America - DO NOT USE THIS).
Dec 03, 2008 | D-Link AirPlus Xtreme G DI-624 Wireless...
Can I piggyback a wireless router onto a hard-wired router?
Yes, you can connect the DI-624 to your exitsing EBR-2310, you just need to connect the a cable from port 4 of the EBR-2310 to the internet/wan port of the DI-624, then after that you can already use now the wireless to your laptop and also the wired router to your desktops.
But I may suggest you to just replace the EBR-2310 with the DI-624 so you will only be using 1 router that can cater your laptop and also your desktop, Just connect the cable from your modem that is conencted now to your EBR-2310 to the internet/wan port of the DI-624 then run the setup CD that should be it.
Hope that helps...........
Aug 30, 2008 | D-Link AirPlus Xtreme G DI-624 Wireless...
Communicating my laptop with my Dlink 624 router
first, you need to make access by cable (rj45), may be has the router adreses 192.168.1.254 0r 192.168.1.1, & make configurations for the wi fi from the router
Jul 20, 2008 | D-Link AirPlus Xtreme G DI-624 Wireless...
Dlink solutions
you just cleck dlink, then properties, then cleck advance check the computer internet
Jun 18, 2008 | D-Link AirPlus Xtreme G DI-624 Wireless...
hi thanatos
Feb 08, 2008 | D-Link DI-624 Air Plus XtremeG Wireless...
Internet Connection
try a cross cable between di-624 and westell dsl router.
Jan 12, 2008 | D-Link AirPlus Xtreme G DI-624 Wireless...
DI-624 Stalls
While D-Link is used in various establishments around the globe it is not the best, but you may want to consider resetting your DLink! Does the stalls occur while on a hardline?
Nov 24, 2007 | D-Link DI-624 Air Plus XtremeG Wireless...
D-Link AirPlus Xtreme G DI-624 Wireless Router (DI624RE) Logo
24 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
