Water wont empty from washing machine.their aint no blockage in the pipes
    Scholar:
  • 148 Answers
The pump let go
Posted on Jul 07, 2008
How do i unlock my washer there is no code and the power bottom won't go on plaese tell me what to do?
is the machine full of water if so take the discharge hose out of the stand pipe and empty the water in a bucket low to the ground once the water has empty you should be able to open the door if not tilt the machine back and try then clean the blockage ie pump or filter anymore help let me know
Nov 24, 2011 | Samsung WF203ANW Front Load Washer
Tip
How to check for blockage when washing machine wont pump water out
To determine if your pipes are blocked on your washing machine, when it will not pump out the water you can carry out a simple test. 1st remove the drain hose from your waste pipe or if connected to u bend on sink remove connection. Hold the pipe into a bowl as low to the ground as possible. If water flows from the pipe then your pipes on the machine are not blocked. If your connection is onto a u bend below your sink then before replacing pipe check u benb for blockage.If this fails then your problem is more sinnister and could be a number of reasons as to why your water cannot pump out.
on Feb 13, 2010 | Washing Machines
Indesit wie 147 washing machine wont empty water it dose every think else but it got stuck and had an error of 5 with water stuck in drain some as looking at the preasure pipe blew down the pipe an no...
It really does sound like you have a blockage somewhere even if you cant feel it. You may need to remove the pump and the pipes to be certain. Try laying the drain pipe on floor level. If it drains then there is definately something in there that needs to be removed. Let me know if you need any more help.
Oct 20, 2011 | Indesit W 123 Front Load Washer
Found lots of fluff from a previous wash. Next wash the machine failed to empty. Did persist & a trickle of water arrived, machine is now almost empty of water, least enough open the door. Possible...
To clean pump you will need to unplug machine, at rear using screwdriver remove the panel at bottom of machine. depending on fitting of clip holding pipe onto your pump, use suitable tool to remove the clip. You can now remove the pipe from the pump. check inside the pump also.If you need to remove the tub end of this pipe there is what is like a ping pong ball within the pipe. Make sure you refit this as it acts as a non return for the water.
Mar 15, 2010 | Hotpoint First Edition WMA22 Front Load...
LG washer wont drain or spin
The problem is this, The machine wont spin until it sense that it is empty. So your solution is easy either a faulty pump that wont drain the water from the machine or a blockage in the the filter. There should be a filter at the front behind the kick plate at the bottom of the machine just check to see if you have something stuck in it before you go changing the pump. The easest whether its the pump or a blcokage is to disconnectthe waste pipe and drop it to floor level if the water comes out the machine then its the pump if it does not then its a blockage .
please rate if it helps
Sep 08, 2009 | LG Washing Machines
Machine fills and agitates, but won't drain
Please empty your machine and run the machine empty. If the washer goes through the whole cycle without any clothes. Please let me know
Jan 19, 2009 | Kenmore 24032\24036 Top Load Washer
The wash liquid does not empty after the wash is finished
hi, it sound like your waste outletis obstructed or the pump is not working, to empty the machine pull the easte pipe out of the stand pipe ,get a bowl, keep the pipe above the level of the drum! slowly lower pipe into bowl the water should run from the machine to stop the flow lift the pipe above the drum level, continue until machine empty! if the MACHINE EMPTIES THIS WAY THERE WILL NOT BE A BLOCKAGE AND YOU SHOULD CHANGE THE PUMP, hope this helps you
Nov 11, 2008 | Hotpoint WD62 Front Load Washer / Dryer
Water will not empty
Hello
you either have a blockage in the filter or you pump is not working.
how to check is diconnect the waste pipe and lower it to ground level if the water does not empty then its a blockage. if it empties then its the pump.
other things it can be is a blockage where the waste pipe is connected or a loose wire to the pump..
Dec 13, 2007 | Hotpoint Aquarius WF000 Front Load Washer
Washing machine wont empty
hi there this is a common fault empty the water into a bucket and remove the water pump to check for blockages, the pump is located at the rerar lefthand side of the w/m.
also check your drain hose where it connects under your sink.
hope this helps
Dec 11, 2007 | Washing Machines
Washer-dryer not emptying
Remove the back pannel ( a whole load of screws i must say )
Then you will see at the bottom on the back of the drum where the filters connects... Remove the clip and check and remove any blockage....
Before opening it is possible to check if a blockage exist is to dicconect the waste pipe from the sink and lay it on the floor... Gravity forces the water to flow to the lowest point.. if no water comes out of the pipe then you definately have a blockage...
Nov 12, 2007 | Hotpoint Aquarius WD63 Front Load...
Washing Machines Logo
110 people viewed this question
Top Washing Machines Experts
