Question about Euro-Pro S3325 Handheld Steam Vacuum
Shark Steamer model S3325 will not power on; switch appears to be working but will not indicate on and will not heat tank. I can hear it try to start the heating element (secondary clicks) however, does not seem to work.
There's a thermal fuse inside. If it gets too hot, the fuse will blow and the thing won't turn on.
It has a 216 C temp limit. You can find thermal fuses at radio shack for less than 5$. If you're adventurous enough, you can find the fuse in line of a white wire under a fiberglass outer and heat shrink inner shielding screwed against the bottom of the tank.
Posted on Jan 27, 2011
Need to order parts for shark steamer model #s 3325
Have you tried an internet search for the manufacturer's web site? Repair parts lists are on most sites. You'll need the model #, serial #, and year of manufacture.
Dec 26, 2010 | Euro-Pro S3325 Handheld Steam Vacuum
Steamer not working at all. water tank / electrical outlet all check ok/plugged in and not doing anything
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the Shark Manuals that you need.
heatman101
Oct 24, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
My euro pro s3300 shark steam cleaner heats up but doesn't steam when you press the button. It is gray in color and the light turns on and is hot to the feel. What is the problem can it be fixed by me or...
if you use it for more than an hour theres an automatic kill switch located on the inside designed to make you buy another one , but you can take it apart and hardwire it to bypass that kill switch , and your steamer will work once again.
Feb 23, 2010 | Euro-Pro S3325 Handheld Steam Vacuum
Shark Steam Canister S3325 will not turn on when switch pressed
I had a similar problem; disassembed switch and clamped electrical bayonets tighter with a pair of pliers; works good now.
Mar 21, 2009 | Euro-Pro Ultra Steam SharkTM II Hard...
Machine will not work, i plug it in and press the power, but nothing happens.
I have the same problem with my shark. I dismantled it and found that a thermal fuse on the bottom of the tank is blown. I am trying to locate the part now. I will post when found.
Jun 10, 2008 | Euro-Pro S3325 Handheld Steam Vacuum
This is a EURO-PRO X Shark Steamer Model S3325, there doesn't seem to be any power in plugged in, no lights on the handle. Bad switch or is there a fuse?
There is usually a heat sensitive fuse link installed in the handle and is incorporated in the cord connection. If the machine gets too hot or is run while dry, the fuse can blow. You would have to replace the fuse, as they are not resetable.
Mar 28, 2008 | Euro-Pro Shark SC-505 Handheld Steam...
Euro-Pro S3325 Handheld Steam Vacuum Logo
952 people viewed this question
Top Euro-Pro Vacuums Experts
Dennis Key
Dennis Key
Are you an Euro-Pro Vacuum Expert? Answer questions, earn points and help others
