If new batteries did not fix the problem, then it means the problem is either from the remote or the VCR.
Remote:
Check the remote battery terminal, see if its not rust. Also,
disassemble the remote, can check the connection between the terminal
and the remote board, see if there is no disconnection of any kind.
If
after checking and all seems well, then it means the remote is
defective. To confirm, borrow a remote, test it with the VCR. If it
works, then it means you need to replace your remote. But if the remote
you borrowed does not work, then it means the problem is from the VCR
and not the remote.
VCR: There is a sensor in the VCR that
communicates with the remote. If this sensor is defective, the remote
won't communicate with the VCR.
The VCR sensor might have loosed contact from inside of the VCR or it maybe defective and need to be replaced.
So
do the above troubleshooting and let me know if the problem is from the VCR or remote. If problem is from the remote, you need to do a
replacement. But if otherwise, let me knows as well.
Compliments of the season.
