Question about Onkyo HT-S780 System
Came home after being out of town for a few days, and suddenly, my A speakers don't work! B speakers are working fine, and I tested the A speakers in the B slot, and it is not the speaker itself, so it is something with the receiver. Any thoughts???
    Brigadier General:
  • 8,546 Answers
How does speaker A work when you run the Test Tone or with a mutichannel input?
There are indicators for speaker A and B in the uper left of the display. If A is not illuminated, press the Speaker A button right below the Standby Button and see if it will illuminate. If not, try the SP A/B button on the remote.
Posted on Dec 28, 2010
The speakers for my Bose 123 suddenly don't work for any source. It had worked well for years. Mute is off. What can I do?
It sounds to me like the Bose 123 is to blame not the speakers. I think you can test the speakers by connecting a 1.5 volt battery for a short while (few seconds) accross any of the speakers terminals. Disconected from the amp. If they are working it will go POP
If it's the Bose itself then the main amp inside has failed.
Jan 25, 2013 | Audio Players & Recorders
Durabrand Home Theater System Model HT-3917. It was playing ok a little crackle from the front side speakers for a couple days now and it just went off. I checked the fuse no,I checked the power strip and...
You (we) still don't know if the speaker or electronics are at fault. Swap the speakers left-to-right. Use test tones to test all channels. Could be a loose speaker wire, too.
Jul 24, 2011 | Durabrand HT-3915 System
I have Harmon Kardon AV140 connected to 6 Klipsch speakers. All of sudden I know longer have any sound coming out of my front speakers. Everything was working fine a few days ago. Did we hit a button in...
Only the front speakers failing? All others ok?
There is NO configuration that would have NO front speakers.
Go back to basics, open the manual and use test tones for speaker verification.
Mar 17, 2011 | Harman Kardon AVR 140 Receiver
Yamaha RX-V365 Receiver, Yamaha NS-AP2600S(BL) Speakers
Make sure the speaker select switch is on "A or B or AB. It's a small button on the front panel of the receiver (pen sized) and will give you visual feedback on the LCD display. If they are on, you need to have the unit bench tested at an audio shop and possibly repaired. Hope this helps
Jun 18, 2010 | Yamaha Rx-v365 A/V Home Theater Receiver
My rear and center speakers suddenly quit working. No sound
try a different source. if there is output on all speakers in test mode, then the amps are good but the source or source switching may have a problem.
Mar 01, 2010 | Audio Players & Recorders
Mine was working fine in my 2002 Chrysler Town and Country and then a postal truck hit the front end of my car and all of a sudden the front blower motor stopped working but the rear is fine.
Hi my name is Allen!
We can work together to fix your problem, even if it takes a few days, we will work on it until it is solve!
Here is what I need you to do first, if you have a test light, you need to check all the fuses.
1st-turn the key on, engine doesn't have to be running. with the test light find a good ground to clip it onto, then with the probe end touch it to one side of the fuse, then to the other side of the same fuse. The fuse should light up on both sides of the fuse, If it doesn't you need to replace that fuse.
NOTE: If you do not have a test light are know how to use one, drive you car to AutoZone or another auto parts store and ask them if they will check your fuses to see if one is blown.
Next; contact me here at FixYa, with what you have found. If all the fuses were good, then we will move on to the next repair procedure.
I'm honored to help, and we will work together until we have solved your problem!
Dec 29, 2008 | 2002 Chrysler Town & Country
NO DISC message
I assume that problem is dirt on laser lenses. If you don’t get any result after this, than you can replace receiver with new one. If you want to use your existing speakers with new receiver with integrated amplifier, you must pay attention on wattage, to be same like old one (i.e. 100W), and also resistance (i.e. 4 ohm). If it’s same like old receiver, you should have no problem. Good luck.
May 06, 2008 | Panasonic sa-ht800V Home Theater Audio...
103 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
