Question about HP Photosmart 3310 Printer
My carriage is jammed. I have checked everything. No paper. I also, have turned the printer on and off and unplugged the unit. To no avail. Please advise.
  • 61 Answers
I think you should call hp because you could damage printer. :)
Posted on Dec 28, 2010
How do i clear a paper jam on MX300 printer if the is no paper jam I removed paper, turn the printer upside down to clear any objects, message the same clear paper press ok
This is for other printers, but i guess it can be helpful,
please turn off the unit....
unplug the power cable
now remove the cartridge...manually slide the carriage assembly\ printhead back and forth
also clean the rail against which the assembly slides with a tissue ensuring that there is no ink residue on it
clean the golden contacts of the cartridges and the printhead with a cotton swab dipped in little alcohol
Now check the paper feed tray, roller assembly area and the area where the carriage moved for any stuck obstruction like paper, paper clips, pins etc and if found remove it.
once done turn the unit back on and check
Apr 15, 2018 | The Office Equipment & Supplies
I keep getting the message cartridge jam on my hp psc 2355. A paper jam was pulled out of the front so I know this is the cause but how do I fix it please?
It's not saying carTridge jam, it's saying CARRIAGE jam. Something is stuck under the heads.
unplug the power from the unit, and try to manually move the heads off to the left side, checking for paper under the head as you move it over.
Check the head docking area on the right as well.
Plug the unit back in and everything should be fine once everything is cleaned out.
May 24, 2011 | HP PSC 2355 All-In-One InkJet Printer
"carriage jam. Open door. Clear carriage jam, then press okay" error keeps repeating... tried everything still no change...
If you are getting a 'carriage jam' error as soon as you turn on your printer with no tasks in progress, then check for any piece of paper stuck in the carriage. Remove the paper carefully. If the paper tears, part of it might remain inside the paper path and damage the product.
Follow the steps for fix HP Printer Carriage Jam
  • Turn off the printer and open it to see where the paper is stuck.
  • Manually move the carriage toward the opposite side.
  • Check the paper path and remove any piece of paper or any other object that is stuck in the path.
  • Reconnect the power cord and turn on the printer.
Sep 01, 2010 | HP OfficeJet 6210 All-In-One InkJet...
EPSON Photo 1400 paper feed and ink replacement problem
Asit is only a couple of months old seek a replacement under guarantee/warranty.
Jun 29, 2010 | Epson Stylus 1400 InkJet Photo Printer
Try to print but: get General Printer error 0x61000f6
Hi
This error comes due to carriage jam. Turn off the printer and unplug it from wall socket. Now, remove the cartridges and check for any dried up ink residue on cartridges on inside the carriage. Clean the cartridges contacts and carriage using a Q-tip dipped i alcohol. Let the carriage and cartridges dry before you plug in the printer.
Install the cartridges and check. If it still shows error then unplug the power cord coming to the printer without switching it off. Now, remove the rear door of the printer and check for any paper jams over there, remove if any. Wit for at least 15 seconds and plug in the power cord. Now check whether it is working.
Daniel Scott
Jun 22, 2010 | HP Photosmart C3180 All-In-One InkJet...
Stylus CX9400 Photo Printer: paper jammed inside printer...
If paper is jammed, a Paper jam message will appear on the control panel display.
Follow these steps to clear the jam:
  1. Gently pull any jammed paper out of the output tray or sheet feeder.
  2. If the paper is stuck inside, turn off the Epson Stylus CX.
  3. Open the scanner, remove the jammed paper and torn pieces, close the scanner, and turn the Epson Stylus CX back on.
    alert_note.gif Note: Be sure to check the far left of the carriage area when checking for jammed paper. Paper that is jammed there may be hidden from view.
If paper jams inside the Automatic Document Feeder, clear the jam as follows:
  1. Open the Automatic Document Feeder cover and remove any jammed paper.
  2. If necessary, lift the document cover and remove any paper that has jammed inside.
  3. Press OK to clear any messages on the display screen.
May 18, 2010 | Epson Stylus CX9400 Photo Printer
During startup the drive belt slips and gives an error
Open the printer's door and look for the print carriage. It's the platform that moves back and forth over the paper, probably where you put new cartridges. Unplug the printer, and check this belt and its pulleys to see if it's either broken or possibly covered in ink. The drive belt will be black and have gear teeth on it. If you see a metal or plastic ribbon, that's more likely the encoder that let's the printer's computer read the position of the carriage. See if you can nudge the carriage and make it move a little; it may simply be jammed. Check the carriage's moving path and make sure it's not obstructed. Any other problems would probably best be handled by Epson.
Feb 27, 2010 | Epson Stylus R380 InkJet Photo Printer
Carriage Jam on my HP Officejet 5610v All-in-One printer
If I move the carriages to the center of the bar they slide on (would be the center of the paper) and close everything it seems to re-load, I've had to do this several times over the last few years and so far it always works
Feb 09, 2010 | HP Officejet 5610 All-In-One InkJet...
Epson R320 carriage jammed
The ink cartridge is probably not inserted correctly.  Unplug the printer and manually move the carriage to a location where you can take the ink cartridge out.
Remove it and reinsert it, making sure that it is fully located, before applying the power.
Make sure that there is nothing blocking the carriage movement, such as some remnant of paper.
Oct 21, 2008 | Epson Stylus Photo R220 InkJet Printer
EPSON 9600
try to reset the settings in the printer panel inside the printer setup menu. try to choose the initialize all. then observe your printer operation.
manual for troubleshooting options OR check the manual here :
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&infoType=Doc&oid=14397&prodoid=19302859
Jul 06, 2008 | Epson Stylus Pro 9600 InkJet Printer
HP Photosmart 3310 Printer Logo
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
