Question about Krups FBC212 1600 Watts Toaster Oven with Convection Cooking
The door on my FBC212 will not stay shut. The hinge mechanism that used to hold it in place is broken. As a result the door only rests in the fully open position. How much will it cost to fix this problem? Where in West Los Angeles should I take the product for repair?
3 Suggested Answers
caroldon
  • 17130 Answers
SOURCE: My KRUPS FBC2 glass door
I assume that the glass hinge has come off or is broken.
For both the cases you can either remove off the old glass door and fix a new one with the therrmal properties.
the next option is to salvage on similar type from a service shop.
The other option is to stick along with a glass fixing adhesive a small rectangular glass to wedge into exactly over the broken glass and have the hinge centralised to make sure the alignment is correct to close the door properly.
If only the hinge has come off then use an extender to hinge to glue on with a glass fixing adhesive.
Posted on Aug 28, 2010
gjgaryjones0
I just fixed the problem with my Krups FBC-212. The door would not stay closed because the spring that keeps it in the closed position was broken. I ordered another from one of the small appliances parts sites (about $7 plus shipping) and that fixed it. I will describe how to do it and how to avoid the mistake that made it much harder and longer than it should have.
Remove the black screws at the back side, the ones holding the external black metal case to the silver chassis. There are 9 of these on my oven.
Also remove the 3 screws holding the left-side foot on.
Now you can probably slide the metal case (previously held on by the 9 screws) out from under the black metal front frame on the left side, thereby exposing the broken spring.
If you cannot get it out from under the lip of the front frame, you can take off the right-hand foot, and if that is not enough, you can remove THREE of the 4 black screws just inside the door holding the front frame to the chassis. Do NOT remove the lower left one next to where the flat door hinge piece goes into oven (which was my mistake) because that screw holds a critical black plastic piece in place.
By now you will be able to slide the black case that covers the sides and top backward and outward enough to expose the broken spring. It will be obvious how to attach the new one.
Posted on Jun 04, 2012
Why are the control buttons operate intermittently?
Sounds like there is a loose wire connection. Have you contacted the manufacturer?
Aug 11, 2014 | Krups FBC212 1600 Watts Toaster Oven with...
Door Replacement
  1. To fix a cocked door, open the door and loosen the screws securing the inner panel. Hold the door at the top and twist it from side to side to seat it securely on its hinges.
  2. Partially tighten the door screws; do not overtighten screws on a porcelain door because the surface may chip.
  3. Test the seal by inserting a piece of paper between the seal and the top corners of the oven. The seal should tightly grip the paper.
  4. To replace cabinet-mounted springs, remove the storage drawer and the oven door. Unhook and replace the springs. Replace both springs even if only one is broken.
Hope that helps..........
Jul 01, 2008 | Krups FBC5 1600 Watts Toaster Oven with...
OLD STURDY ENTRY DOOR, THE HINGES ARE LOOSE BECAUSE THE 2"X3" STUDS THAT WERE USED FOR DOOR JAM OR FRAME ARE ROTTEN, I DO NOT WANT TO REPLACE DOOR JUST THE WOOD THAT HOLDS THE HINDGES, PLEASE HELP ARE
Usually there is a wood trim that is 1/2 inch thick that is put over the STUDS that make up the frame around the doorway. IF you take the door out, then you can take out the trim and see if the studs are ok. OR you can just get really long 2 or 3 inch screws to replace the ones that are holding the hinges to the trim. The long screws will go all the way into the studs.
Mar 13, 2014 | Black & Decker TROS1000 Toaster Oven
The door spring came off of hamilton beach 31100
The door of the Hamilton Beach Model 03008 or similar toaster oven does not stay closed when the door return spring or the hook it connects to breaks. The repair is very simple and takes just a few minutes!
The door spring is about 1 inch long and connects to a small clip on the inside of the left side panel of the unit. To see the small clip and the door spring, you simply remove the left side panel of the toaster oven which is done by removing just one screw.
The mounting clip on the side panel for the door return spring is located about half way up the side panel near its front edge.
The other end of the spring (its bottom end) connects to a metal hook. If the spring is not connected on its bottom end then the wire hook is broken. This is a simple repair that only requires a few inches of metal wire.
The other end of the metal hook (its bottom end) is connected to the bottom of the door hinge where it inserts into a small hole in the left side mounting hinge of the door.
When the steel hook breaks on either end then the spring cannot function, so the door does not stay closed.
To fix this problem, you simply get a piece of steel wire that is about 1/16 inch thick and a few inches long.
Bend the wire to make a hook at one end that the spring will connect to.
Then insert the other end of the wire into the small hole on the left side mounting hinge of the door. Then bend the wire on the inside of the hole to make a U or hook so the wire stays mounted in the hole of the door hinge.
Then adjust the position of the bend on the other end of the metal wire so the spring will have good tension when it is attached to the hook and to the clip on the side panel.
To do this you make the U shaped bend on this end of the wire to be about 1/2 inch from the end of the open end of the spring when the top end of the spring is attached to the mounting clip on the side panel.
To attach the spring to the wire hook, first remove the spring from the mounting clip. Then hook the spring onto the hook (bend) you made at the top end of the wire, then just stretch the spring to connect it to the mounting clip. The door will now stay closed.
Nov 10, 2013 | Hamilton Beach 31197 120 Watts Toaster...
We have a Krups FBC4 1600 Watts Toaster Oven. The door hinge seems to have disconnected from some kind of spring mechanism within the left wall, is there any way to take apart/repair it or have it...
Here is a Krups website address that helps you locate service by state or contact the Krups company.
http://www.krupsusa.com/Consumer+Services/Service+Centers/List/CentersList.htm
Apr 08, 2011 | Krups FBC4 1600 Watts Toaster Oven with...
On off button usually fais to respond to on
It could be a problem with the board as that on/off button is one complete unit with the board, digital display and buttons attached. If you want to fix it yourself get your model number (FBC212) and head over to 1800Parts.com to see if they have the board in stock. You can also call Krups directly and they will tell you a service station in your area. We are one of their national service stations but we are in New York.
Sep 15, 2010 | Krups FBC212 1600 Watts Toaster Oven with...
My KRUPS FBC2 glass door hinge is broken. We use a pan to keep door in place when using it so it doesn't fall down. Any ideas on how to fix it will be appreciated. I'm pretty handy with things but I just...
Aug 28, 2010 | Krups FBC2 1600 Watts Toaster Oven with...
Toaster oven door will not close completely.
This problem is caused by screws being loose or dropping off a limiting bracket on the left side of the oven behind the left outer wall.  This bracket allows the front glass panel to remain OPEN, as required for broiling.
To correct this, first check to see that the two black screws facing forward, behind the left side of the front glass panel are tight.  If not, tighten firmly, but be careful not to overtighten.  If this fails to correct the problem, then follow this procedure.
Purchase 2- #4 x 1/2" SS Phillips Pan Head sheet metal screws at your favorite hardware store.  Cost About $1
  1. Unplug the oven and place on a flat work surface. Place a rubber mat or towel under the oven to prevent scratching.
  2. Remove 2- #4 x 1/4" black phillips flat head screws on the left side of the front glass panel which screw into the black side panel.  These are NOT the screws which hold the bracket, which face forward, but are adjacent to the bracket screws.  Be sure to indentify the proper location of all screws for replacement.
  3. Remove the 4- #4 x 3/8" SS phillips pan head screws at the bottom of the left side of the oven.  Pry the metal tab of the back panel slightly off the bottom of the black side panel.
  4. Remove the 3- #4 x 3/8" SS phillips pan head screws from the back panel which attaches to the left side black panel.
  5. Carefully pry the bottom of the left black side panel up from the bottom of the oven until it is parallel to the top of the oven.  It will seem hard to pry it upward as you are bending two SS tabs holding the black side panel to the SS top.  It will come up easily once you get it started.  When it is parallel to the top, slide the black side panel to the rear to remove it from the two SS tabs.
  6. You should now see the limiting bracket at the front of the oven's left side.  Remove the 2- black Phillips screws holding the bracket.
  7. Slip the limiting bracket from the oven.  Place on a wood block and with a chisel (or large common screw driver) and hammer, strike the screw holes on the bracket firmly once, so as to close the screw holes slightly.
  8. (OPTIONAL)  If available, using a rat tail file (or small flat file), at the crook of the spring lever, carefully increase the indent of the crook ever so slightly.  This will allow the front glass panel to stop more definitely at the open point.
  9. Remount the bracket using the 2- #4 x 1/2" SS Phillips Head sheet metal screws you bought. Tighten firmly, but do not overtighten.  Check the front glass panel movement. It should have a definite stop to allow the panel to stay open approximately 1/2" for broiling and should close fully, easily.
  10. Slide the left black side panel on to the SS tabs.
  11. Pry the left side black panel down until it meet the bottom plate.
  12. Replace the bottom screws.
  13. Replace the 2- #4 x 1/4" black Phillips flat head screws at the left side of the front of the front glass panel which screw into the black side panel.
  14. Replace the back panel screws.
Feb 23, 2009 | Cuisinart TOB-50 Toaster Oven with...
Toaster Oven Repair
Toaster switch does not stay down. I have to hold the switch down to get toast. The heating element works fine as does the oven. Can we fix the switch? Or, do you know someone to whom we can send it for repair? Thanks!
Sheila Newton
Winston-Salem, NC
Aug 16, 2008 | Toaster Ovens
Farberware convection broil oven modle T-4850
I have the same problem. www.repairshack.com has replacement doors but they are out of stock. You may want to check with them to see when it comes back in. Specifically http://www.repairshack.com/detail.aspx?ID=705 or call
1-888-464-0797.
Jul 30, 2008 | Farberware T490C 1500 Watts Toaster Oven...
Krups FBC212 1600 Watts Toaster Oven with Convection Cooking Logo
75 people viewed this question
Top Krups Toaster Ovens Experts
Tom Chichester
Are you a Krups Toaster Oven Expert? Answer questions, earn points and help others
