Question about HP Pavilion a1640n (RC663AA) PC Desktop
I can't get any sound on this computer. Mute is off, speakers on, plugs in right place I believe...Help.
  • 53 Answers
Check if the sound card driver is installed. Check the device manager and see if there is any item with an exclamation point. You may also want to check if the speaker is working by connecting it to another device.
Posted on Dec 29, 2010
Everything is pluged in correctly. And when i go to the control panel> Sounds, speech, and audio devices> sounds and audio devices> volume, it says that their pluged in and work, but i dont here...
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the volume icon system select adjust volume
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps you
Aug 16, 2011 | Dell A215 Computer Speakers
How do you hook these speakers up
if they have wires or usb plug connections or if wireless might be a usb input device you plug in
you will need to connect your speakers to your computer then you will need to install them to your computer
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any sound settings by right clicking on the speaker icon
then you are ready to position your speakers if you have more than 2 you might need to select stereo
if you need more help with this post a reply
hope this helps
Aug 14, 2011 | GE HO98010 Computer Speakers
I have the MM600DA speakers. they were working fine, and then about 2 nights ago i get no sound. i have XP SP3. i have not changed anything on the computer or system between having sound and not having...
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume adjustment you will need to right click on the volume icon depending on your operating system select adjust volume
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer hope this helps
Jul 20, 2011 | Micro Innovations MM600D Computer Speakers
Volume not working,green light on but very dim and can't mute
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it or select audio from the microphone drop down list make sure you have the right one selected and in the volume box make sure the microphone box has a tick in it or select the voice tab and make sure that you have the right media selected also select volume make sure the box for microphone has a tick in it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall
also
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
hope this helps
Jun 12, 2011 | Bose Companion III Computer Speakers
I lost the sound on my lap-top.I restarted it, there is no sound. I've checked that the speakers are enabled-they are, and it is not on mute...yet, there is no sound! Help!
also
hope this helps
Jun 04, 2011 | Computers & Internet
Where is mute button on model 5189 keyboard. sound does not come on. speakers wires seem to be installed correctly. Trouble shooting guide said mute button may have activated.
also
hope this helps
Apr 24, 2011 | Audio Players & Recorders
In voice chat, i can hear them but they cannot hear my voice
click on the icon of of speaker in the desktop bar. Master vvolume sofware will popup and then click options then properties. Under "show the following volume controls:", sroll down to microphone and check the box beside it. press ok. now you have your mic setting. click the mute box under the mic to disable mute. make sure that noting else is on mute. make sure you plugged the mic at the right place, not sound in or out.
Jan 23, 2010 | Audio Players & Recorders
Install speaker in dell pc mine has no sound Logitech L S 11
make sure the mute box has no check mark in it......make sure your plug (jack) in the rear or front of the computer that goes to the speakers are plugged into the right place.....go into the control panel and go to sound settings make sure the computer is set up for the right kind of equipment you are using.......
Dec 07, 2009 | Dell Computers & Internet
No sound
Play any mp3 or cd with Windows media player and note if the video shows sound playing or not. If yo see the graphics, check the speakers. Many people plug the speakers in to wrong whole. Most pc's are the middle whole. Now check the mute button. On the task bar in the lower right hand corner, single or double click the speaker icon. Clear the mute button. Next, check to see if the driver is in place. If you are using Windows Right click on my computer, choose properties, hardware tab, and then device manager. Look under sound and let me know if the driver is present for sound, video and game controllers. The step will be slightly different is it is not an Xp operating system. If the driver is the problem you need to tell us what operating system, what brand computer, what model number, and depending on the brand, the serial number to locate the correct driver.
Nov 28, 2009 | Intel Premier Resources 4-Channel 32-Bit...
Altec lancing 221 pc speakers are not working.
right click in speakers icon and open volume control----check volume control fader in up position-------check that nothing in mute setting and remove mute where ever you find it.-------confirm that you plug speaker jack in right place(line out).-check your sound driver and confirm it is ok.
Aug 06, 2008 | Audio Players & Recorders
HP Pavilion a1640n (RC663AA) PC Desktop Logo
56 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
