Question about Samsung CLX-3175FN Color Laser All-in-One Printer
I got error outer temp open cycle power what can I do to fix it
  • 4 Answers
Have you had the front door off the machine. It's a bit fiddly, but this error can happen if the cable connector next to the left hand hinge isn't plugged in properly.
Posted on Feb 24, 2011
  • John Shugg
    John Shugg Feb 24, 2011
    Have you had the front door off the machine? This error can happen if the cable connector next to the left hand hinge isn't plugged in properly.
2 Suggested Answers
  • 220 Answers
SOURCE: message
fuser has fried,pls get it replaced
Posted on Jun 26, 2009
Displays CH04 error
Hello
THis is a heatsink Temp sensor open circut error.Try cycling power on and off to unit.If this does not work you will need sevice as this part is part of the control board.
Sep 17, 2011 | LG LSC121PMA Split System Air Conditioner
Half way (circa 1hr) through the baking cycle "error 01" appears on the progress window. Any suggestions as to what's causing the malfunction ?
This is what i have been told i called and also looked up online to find that the error 1 code means
Magnetron (1) Failure:
Test magnetron (1) and Blower fan motor
Magnetron (1), (2) Failure: Test magnetron (1), (2).
Check blower fan motor and ventilation opening.
This is what the man told me to do to check the problems
(He also wanted to make certain i was a repair specialist which i am not) but this is what i got out of him
1. Disconnect the power supply cord, and then remove outer case.
2. Open the door and block it open.
3. Discharge two high voltage capacitors.
4. A continuity check across the temperature fuse terminals should indicate a closed circuit unless the
temperature of the temperature fuse reaches specfied temperature as shown below.
5. Reconnect all leads removed from components during testing.
6. Reinstall the outer case (cabinet).
7. Reconnect the power supply cord after the outer case is installed.
8. Run the oven and check all functions.
Hope this help you out.
Apr 26, 2010 | Microwave Ovens
Maytag FAV6800AWW TL washer is throwing error code uC even when running empty cycle. It sounds like there may be a bearing going bad as it is more noisy than it should be when spinning. It stopped at 12...
Don,
I ask folks to give me some feedback when troubleshooting dC/uC errors with a feel for Wash Basket CCW/Spin direction drive system resistance.
It sounds like the Outer Tub Bearings are going which means you have a Tub Seal Leak that took them out. The Clutch One-Way Roller clutches are probably contaminated. I would bet a bit rusty and are sticking not locking up completely in Spin Cycle causing tumbler movement at the start of Spin Cycle. See my Clutch Fix post I go into a lot of detail for a fix and just what is causing the unbalance errors in Spin Cycle
You could drop the clutch out and see if you can clean up the bearings and relieve the dC/uC unbalance errors for a while longer.
Replacing the bearings is a bit more work see these post for what is involved. If your series is a 12 or above you may have to do as this forum member did.
http://www.fixya.com/support/t3973659-fav6800aw_sn_15_top_loader_r_nunit
Series 10 & 11 from what I have learned use the upper One-Way Roller Clutch bearing ring and not the integrated Lower Outer Tub bearing as in I believe the Series 12 and above do.
Series 10 Outer Tub Bearing work I and another forum member are working on. The links will give you some direction if you DIY. http://www.fixya.com/support/t4028403-just_replaced_new_clutch_fav9800aww
What are the first two digits of your Serial Number? Will be 10 through 17.
Post back if we can help I’m an owner like you not a repair person. I feel the cost to have the Outer Tub Bearing replaced will trigger you to make a replacement decision……Rich
Mar 13, 2010 | Maytag Neptune FAV6800AW Top Load Washer
E000 sYSTEM eRROR
Solution: Unplug unit for 3-5 minutes, then plug the unit back in
Unplug unit for 3-5 minutes, then plug the unit back in.
OR
I hope it helps!!!
Dec 12, 2008 | Canon ImageClass MF5770 Laser Copier...
How do I fix this?
please have the check on fuser for damage. Could be a thermistor, thermo switch, or faulty heaters. To clear error, service morefunction/clear/error/ok/ exit service mode and cycle power.
fuser over temp means the fixing assy has exceeded the manufactures maximum temp limits
Fuser error codes cannot be reset by power cycling the machine eventhough that is what the display tells you to do. In order to reset thefuser error code you must enter the service mode & reset the code.To enter the service mode:
press"Additional Functions" button (looks like a picture of a head with a star inside)
press the #2 and #8 at the same time (simultaneousley)
press "additional functions" again
The display should show a choice of
copier,feeder,sorter,fax,or board service modes
Select copier
select clear
select ERR
press OK
Turn power off & back on.
****IMPORTANT****
Afterclearing error stay at the machine to see if it comes to ready. Thefuser assy can reach 139 degrees C.(Water boils @ 100C) The error canonly be cleared through the service mode because a technician shouldinspect the fuser to verify there is nothing faulty that could possiblystart a fire. If you enter the service mode & clear the error,power cycle the machine & during warm up the machine throws a codeagain- turn it off, unplug it & call a tech for fuser repair.
Good Luck!!
Aug 10, 2008 | Canon LASER SHOT LBP-5200 Printer
Bosch Slimline dishwasher Exxcel. Detergent dispenser does not open during the wash
take door outer panel off and dispenser is exposed. start cycle and with a multimeter, check power comes to the dispensor during the cycle. if you get power, then the dispensor is faulty. if no power, then the module is faulty
Aug 05, 2008 | Dishwashers
Fan Error
Please contact the supplier for support under warranty.
If not under warranty, do check the power for the fan, after opening the outer case
Please disconnect the main power before opening :)
Try to tell me.... whether my suggestion was useful???
Bye
Have a nice day.
Feb 06, 2008 | NEC MultiSync VT540G Multimedia Projector
Samsung CLX-3175FN Color Laser All-in-One Printer Logo
1,286 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
