Question about Kenmore Washing Machines
Kenmore Series 90 intermittent spin. Washer will go through normal wash cycle, but will often not spin during rinse or spin cycles. Upon observation, machine was seen to appear to "lock up" when entering spin phase of rinse cycle. Water will pump out, but basket will not move as it should. Spin would start but abruptly stop within a small arc as if stopped mechanically and not spin at all for the rest of the cycle. During this occurrence, a faint electrical smell was noticed, similar to a motor overloading or being pushed too hard. Interestingly enough, if the timer switch dial is pulled out to stop the cycle and then pushed back in to start it again, the problem disappears and the machine spins as it should. I'm thinking it's a switch problem, perhaps one circuit not breaking before the next is engaged. (Something like a sticking relay, but I didn't see one in the diagrams.) Perhaps the motor switch trying to energize more than one speed setting at a time, or the timer switch not performing the proper sequence.
  • Kenmore Master
  • 3,047 Answers
I used-to-be a big fan of Craftsman & Kenmore
but after intensive abuse I got better)...
Great trouble description...
(& trouble shooting))
has a fairly decent on-line "CHAT"
(and have been trending toward competitive)
To encourage PARTS PURCHASES...
Once they conform my "CONTROL BOARD"
Check prices at :
Search Over 2 1 Million Appliance Parts
repairclinic or
Appliance Parts Lawn Mower Parts Heating Cooling Parts 365 day returns
partssellect... all have do-it-yourself VIDEOS.
PartSelect Appliance Parts and Repair Help
And last (in my opinion certainly least)... SEARS
Water Filters Lawn Garden Appliance Parts
Posted on Mar 06, 2017
  • 878 Answers
SOURCE: "howling" noise during spin cycle (still there after changing burned off belt)
Travioso, there was two service flashes out on this model concerning the seal and bearing which means they had an issue with this washer. The howling noise you are hearing is the bearing and will need the new designed triple seal and bearing kit. This should be covered under your warranty, I believe it is 5 years. The numbers for the service flashes are TDL-0048A-B. Call Maytag and inquire about these service flashes, these should be covered. Catriver.
Posted on Jul 25, 2006
the dr
  • 447 Answers
SOURCE: Intermittent spin cycle on Kenmore 90 Series washer
You may try the speed selection switch.....Ive had problems with these.
Posted on Jan 23, 2008
  • 240 Answers
SOURCE: Kenmore Series 70 won't spin
Sounds like you have got a basket drive and sub-pack issue. These are very hard to change out because it requires you to remove the inner basket, motor, transmission, agitator, pump, etc. The part number for these are:
Clutch Kit (Sub-Pack): 285785
Basket Drive/Spin Tube: 285792
If you think your up to the task, let me know and will send you some general info on getting the stuff in and out. Good Luck!!!!
Posted on Feb 03, 2008
SOURCE: I also need the answer...
where is the lint trap located
Posted on Apr 07, 2008
  • 188 Answers
SOURCE: Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Posted on Mar 03, 2009
Kenmore 90 tub spins excessively clockwise during wash cycle.
there should be 2 or 3 springs that hold it, they mite have broke, take off back panel an check.
Jan 04, 2010 | Kenmore 24032\24036 Top Load Washer
Kenmore 90 series washer will get stuck in between cycles
Sounds like the timer has failed. It's a common problem.
Part number 8545379, $83.69 from
Feb 04, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 90 series loud whirring/howling noise during spin cycle
Sounds like you have a broken motor coupler. They are inexpensive. Can be a little tough to replace but I can walk you through it. You can purchase a coupler here.
Dec 18, 2008 | GE WBSR3140DW Top Load Washer
90 Series Kenmore Washer Not going to spin cycle not draining water
I've had the same can purchase a replacement lid switch at your local appliance parts store for about $35. Fortunatly, the sales person at the appliance store had diagrams and provided instructions to replace the switch. I was able to finish the job and fix the switch in less than 1 hour. Good Luck.
Oct 25, 2008 | Kenmore 15864/15862 Top Load Washer
Shutting down on rinse cycle
Hi this could means that you may need to replace the washing machine bearings. Once the bearings are bad, the motor overheats and it will automatically shut down after the first rinse.
Timonty from
Jul 28, 2008 | Kenmore 44072 Front Load Washer
Jan 23, 2008 | Washing Machines
Squeaking Washer
did you remove the shipping pins pins when you installed it
Jan 04, 2008 | Kenmore 22422 Top Load Washer
Dec 06, 2007 | Washing Machines
Open Questions:
Washing Machines Logo
51 people viewed this question
Sal De
 Brian Main
Brian Main
