Question about Ricoh Office Equipment & Supplies
I have a Ricoh Aficio 551 copier with the Booklet Finisher. When I send an 11 x 17 job through the copier to be saddle stapled and folded to 8.5 x 11, the machine staples the booklet just starts to fold then stops with the booklet still inside the finisher unit. I am running 2 sheets of 20# 11 x 17 to be stapled together and folded. How do I get the finisher to complete the booklet making process?
  • spicychops Dec 30, 2010
    The machine does not show a jam code, it just tells me to remove misfeed from the finisher. Same thing happens when running 8.5 x 11 to fold to 8.5 x 5.5. There are no nicks or wrinkles to suggest that the paper is being inhibited in any way. The whole process sounds and runs correctly up until the final fold when the booklet exits to the tray below at which point it starts to fold and then shows a misfeed in the finisher. The booklet making feature is used about once a month and last month it worked fine.
  • spicychops Jan 03, 2011
    I've looked at the finisher closely and it is quite clean. Is there a way to get to the folding roller itself? I suspect that the folding roller is losing its grip when attempting to fold. The machine does put a crease in the paper like it is starting to fold it just doesn't finish the folding and stalls.
    Guru:
  • 1,833 Answers
According to your problem.
Don't keep any pin or metallic things inside it.
Adjust your paper size properly.
Don't use wet & damp paper.
keep the paper properly on the paper try.
you can follow the mannual of the printer.
Posted on Jan 05, 2011
  • 335 Answers
Sounds like something may be blocking the paper path. Try separating the finisher from the copier and inspect the papaer path for debris (paper scraps) and blast it out with a compressor or a can of air. Let me know what happens as I may be able to help further.
Hope this helps!
Regards,
Joe
Posted on Jan 03, 2011
  • 903 Answers
Hi, does it show a jam when this happens? Does it happen when you try to make a booklet with 8.5" x 11" paper as well? If it does show a jam, what is the jam code? When you see the paper stuck inside the finisher, does it look crinkled, dog-eared, or torn at all?
The cause could be anything from dirty folder rollers to a bad motor or sensor. Supplying the jam code will help to troubleshoot the cause.
Posted on Dec 30, 2010
  • gggg Dec 31, 2010
    If there are no nicks on the paper and it's not wrinkled or wavy, that likely rules out a bad motor. It's hard to say for sure without seeing the finisher myself, but it sounds like it could be a dirty sensor, either seeing paper when it shouldn't or not seeing paper when it should. However, a sensor could have gone bad, or there might be a pinched harness somewhere in there. Does the finisher run okay in either normal copying mode or stapling mode?
    Since there is no specific jam code, there's nothing exact to point to. I would say your best bet is to have a Ricoh or Lanier service technician take a look at the machine. They should be able to diagnose it pretty quickly, and as long as it's not the actual finisher main board causing the holdup, it shouldn't be very expensive to fix.
  • gggg Jan 04, 2011
    The booklet maker unit can be removed from the finisher as a whole assembly, and then you can take it apart and examine the individual pieces, but in order to do that you've got to pretty much disassemble the finisher. The covers have to come off, the shift tray unit has to be removed, and all of the harnesses have to be disconnected. A Ricoh service technician will be able to do it fairly quickly and figure out what the problem is.
What is the sp mode richo aficeowhat is the sp mode richo aficeo
he following error messages will appear on Gestetner, Lanier, Ricoh and Savin products control panel. There are no codes listed in service for operator/user problems. SC-101 Exposure lamp, lamp stabilizer board, dirty white plate, dirty optics, SBU board, CCD SC-103 Power problem SC-104 Exposure lamp problem, main relay optics board, electrical noises or communication error SC-105 Zero cross, main relay, optics board, FUSE 804 on DCPS or AC drive board on FT series SC-120-123 Scan home problem, sensor, scan motor, (EX-IPU board or fuse FU103 Aficio 400, 401, 500) SC-121 Scan home or fuse FU4 Scan home or fuse FU106 Aficio 550/650 SC-124 Scan motor encoder or scan motor SC-125 Scanning to slow speed SC-126 Scanning too fast speed SC-127 Scan motor or optics board SC-128 Scan start speed wrong; motor, board, drive section SC-129 Scan speed problem; motor or PSU SC-130 SBU error SC-140 / 141 Lens vertical home sensor SC-142 / 143 Lens horizontal home sensor SC-144 /145 3rd scan home sensor problem SC-190 EX-IPU board Aficio 400, 401, 500 Optics thermistor FT 7950, 7960, 7970 series SC-192 Automatic SBU adjust error, SBU, BICU, exposure lamp regulator, exposure lamp, dirty white plate SC-193 APS sensor FT 7950, 7960, 7970 series SC-194 IPU white level detect (too low) same as 192 SC-300-303 Charge corona SC-302 Laser (polygon) motor problem SC-302 Charge roller, HVT, or fuse FU5 (AFICIO 340, 350 series, 355, 450 series, and 455) SC-302-01, 02, 03, 04 Charge corona assembly Aficio 550/650 SC-303 Charge corona wire cleaner, disconnected or time out for printer SC-304 Charge roller problem, ID sensor problem SC-305 Time out error for memory or EX-IPU board or fuse FU103 on Aficio 400, 401, 500 SC-310-314 Potential sensor SC-320 Laser motor problem SC-321 Laser write problem, BCU board, EX-IPU board SC-322 Laser 1 synch. Problem SC-323 Laser drive problem SC-324 Laser drive excess current draw problem SC-326 Laser 2 synchronization error SC-327 Laser 1 home position error SC-328 Laser 2 home position error SC-329 Laser beam pitch error SC-330 Laser diode no initial setting SC-331 Laser diode home error SC-332 Laser diode present position error SC-335-338 Laser motor polygon problem SC-340 TD sensor output error SC-341 Developer motor lockup TD sensor adjust error Aficio 551, 551P, 700, 700P SC-342 TD sensor adjust error SC-345 Toner collect motor lockup Developer bias loss Aficio 551, 551P, 700, 700P SC-346 Toner recycle motor disconnected SC-350-1: thru 5 ID sensor error SC-351 Vsg problem, bad drum, ID sensor SC-352 TD (toner density) sensor problem or bad toner mix SC-353 Vsp problem; image density sensor, drum, HVT, developer bias, needs cleaning SC-354 Vsp problem; image density sensor, drum, HVT, developer bias, needs cleaning SC-355 Toner density sensor or under toned SC-356 Toner density sensor or over toned SC-358 Image density sensor, drum, toner spray SC-360 Hard disk drive error 1 SC-361 Hard disk drive error 2 Incomplete drum potential calibration, check imaging formation assembly FT 7950, 7960, 7970 SC-362 Image compression error Hard disk drive error Aficio 551, 551P, 700, 700P SC-363 Data transmission error SC-364 Data transmission time out error Vd out of specs, drum, drum potential sensor, charge corona FT 7950, 7960, 7970 Hard disk drive error Aficio 551, 551P, 700, 700P SC-365 Image storage error VI out of specs, drum, drum potential sensor, charge corona, dirty optics FT 7950, 7960, 7970 SC-366 CRC error Aficio 550/650Vr out of specs, drum, drum ground FT 7950, 7960, 7970 Hard disk bad sector maximum Aficio 551, 551P, 700, 700P SC-367 Hard disk bad sector maximum Aficio 551, 551P, 700, 700P SC-370-01 thru 07 Drum potential sensor error Aficio 550/650 SC-370-374 IMAC error Aficio 551, 551P, 700, 700P SC-376, 380, 382, 384, 386, 388 Data transmission problem Aficio 551, 551P, 700, 700P SC-390 CRC error Aficio 551, 551P, 700, 700P SC-390-1 Toner density sensor error SC-390-2 Toner density sensor error SC-391 Developer bias problem or FU103 on Aficio 550/650 Image storage address error Aficio 551, 551P, 700, 700P SC-392 Toner density sensor SC-395 Developer bias problem SC-400, 401 Transfer roller error Aficio 551, 551P, 700, 700P SC-401 Transfer roller positive error problem SC-401-1 Transfer roller/belt short SC-401-2 Transfer roller/belt open or fuses FU104, FU115, FU116 Aficio 550/650 SC-402 Transfer roller negative error problem or open SC-403 Transfer belt position error, electromagnetic clutch release or fuse FU5 SC-405 Transfer belt position error, electromagnetic clutch release or fuse FU5 SC-405 Scanner problem; BCU, EX-IPU board or SCU on Aficio 400, 401, 500 SC-411 Separator bias SC-430 Quenching lamp error SC-440 Main motor locked or drum motor locked SC-441 Developer motor locked SC-490 Exhaust fan problem or ozone fan problem SC-491 Laser cooling fan locked SC-492 Cooling fan problem SC-493 Bridge fan problem Exhaust fan locked Aficio 551, 551P, 700, 700P SC-494 Fuser fan locked SC-495 Toner recycling unit problem SC-496 Toner collector bottle problem SC-497 Toner recycling motor problem SC-500 Main motor locked Bypass motor locked FT 7950, 7960, 7970 SC-501-1 & 2 1st Tray lift problem SC-502-1 & 2 2nd tray lift motor problem SC-503-1 & 2 3rd tray lift motor problem SC-504-1 & 2 4th tray lift problem SC-505 LCT tray SC-506 Optional tray motor locked SC-507 LCT motor locked SC-508 Tandem rear fence motor SC-509 Tandem side fence motor SC-510-1 & 2 LCT lift problem Paper feed motor problem Aficio 551, 551P, 700, 700P SC-511 Tandem side fence motor error LCT motor error Aficio 551, 551P, 700, 700P SC-515 Tandem rear fence motor Aficio 551, 551P, 700, 700P SC-516 Tandem side fence motor Aficio 551, 551P, 700, 700P SC-520 Duplex or fuser drive problem FT 7950, 7960, 7970 SC-521 Duplex side fence drive problem SC-522 & 523 Duplex jogger home position FT 7950, 7960, 7970 SC-524 Duplex end fence drive problem SC-530 Bypass motor locked or fuse FU106 on Aficio 551, 551P, 700, 700P SC-531 Fusing duplex motor locked SC-541 Fuser thermistor open SC-542 Fuser temperature too low or fuse FU107 on Aficio 551, 551P, 700, 700P SC-543 Fuser temperature to high SC-544 Fuser temperature too low SC-545 Fuser temperature to high SC-546 Fuser ready temperature unstable SC-547 Zero cross problem Fuser lamp stays on, AC drive board, optics board FT 7950, 7960, 7970 SC-548 Fuser unit not installed SC-590 Toner collector motor problem Cooling fan Aficio 220/270 series SC-591 1 bin tray motor SC-600 Communication problem between SCU and operation SC-601 Communication problem between BICU and scanner Communication problem between BCU and EX-IPU board Aficio 400, 401, 500 Communication problem between SBU and SBICU Aficio 550/650 Communication problem between MCU and BICU Aficio 551, 551P, 700, 700P SC-602 Communication problem between BICU hard disk drive board Communication problem between BCU and fuser control unit on Aficio 400, 401, 500 Communication problem between Hard disk drive board and SBICU Aficio 550/650 Communication problem between BICU and hard disk drive board Aficio 551, 551P, 700, 700P SC-602-2, 2, -3 Communication problem between BICU and ADF SC-604 Communication problem between BCU and high voltage board SC-605 Communication problem between SCU and BCU SC-610 Communication problem between IOB and duplex unit SC-610, 611, 612 Communication problem between BICU and ADF SC-620 Communication problem between BICU and ADF SC-621 Communication problem between BICU and finisher SC-623 Communication problem between BICU and paper tray unit SC-624 Communication problem between BICU and LCT SC-625/626 GA5 data transfer error; EX-IPU or software Communication problem between BICU and finisher Aficio 551, 551P, 700, 700P Communication problem between BICU and LCT Aficio 1035, 1045 SC-627 Communication problem between BICU and LCT Aficio 1035, 1045 SC-630 Communication problem between line adapter and CSS center (Japan) SC-635-636 Communication problem between BICU and paper feed board Aficio 551, 551P, 700, 700P SC-640 BICU data transfer sum check error SC-641 BICU control data transfer problem SC-650, 653 Key card (Japan) SC-670Engine or BICU error SC-672 Op panel to controller problem SC-690 BICU problem (12C) SC-691 Communication problem between BICU and fax controller BICU problem (12C) Aficio 1035, 1045 SC-692 Communication problem between BICU and print controller board BICU problem (12C) Aficio 1035, 1045 SC-694 Communication problem between BICU and scanner board SC-696 Communication problem between IOB and finisher SC-700 ADF P/U problem SC-701 ADF P/U problem SC-702 ADF feed in motor SC-703 ADF transfer motor SC-704 ADF feed out motor SC-705 ADF bottom plate motor SC-720 Finisher transport drive motor problem SC-721 Finisher tray shift or shift motor problem SC-722 Finisher jogger motor SC-723 Finisher stack feed motor problem SC-724 Finisher stapler hammer motor SC-725 Finisher stack feed out motor SC-726 Finisher shift/lift motor SC-727 Finisher stapler rotation motor SC-729 Finisher punch motor SC-730 Finisher stapler position motor SC-731 Finisher exit guide motor Finisher exit open/close motor problem Aficio 1035, 1045 SC-732 Finisher up tray shift motor problem SC-733 Finisher stack feed out motor Finisher lower tray shift motor problem Aficio 1035, 1045 SC-734 Finisher lift motor Finisher lower tray shift motor problem Aficio 1035, 1045 SC-735 Finisher exit guide motor Finisher pre-stack motor Aficio 551, 551P, 700, 700P SC-736 Finisher exit guide plate motor SC-737 Finisher waste stapler full SC-738 Finisher shift tray lift motor SC-740 1000 sheet finisher error 01: Shutter error 02: Exit error 03: Upper exit plate error 04: Jogger motor 05: Stapler motor 06: Stapler hammer motor 07: Tray lift motor 08: Shift tray height sensor 09: Back up RAM 0A: Communication error SC-741 1000 sheet finisher error in saddle stitch area o 01: Position plate motor o 02: Folder roller motor o 03: Shutter guide motor o 04: Booklet jogger motor o 05: Stapler motor o 06: Folder plate motor o 07: Connector o 08: Switch SC-750 Interchange connection problem SC-751 Bridge connection SC-752 Finisher connection SC-760 ADF gate problem SC-770 Shift tray motor SC-800 Control board bad SC-804 Control board bad SC-819 Software application error SC-820 Control board or software SC-821 Control board SC-822 Bad HD SC-823 Bad control board or NIC SC-824 NVRAM or battery bad SC-826 NVRAM bad SC-827 Memory problem SC-828 Bad control board or firmware SC-829 RAM DIMM or control board bad SC-835 Control board or connector SC-836, 837 Font ROM bad SC-838 Clock generator problem SC-850 NIB or control board bad SC-851 IEEE 1384 interface board or control board bad SC-860, 861 Hard drive problem, connection or cable SC-862, 863 Returned, Bad sector in hard drive SC-864 Abnormal HD data transfer SC-865 Hard drive error SC-900 Electrical copy counter problem reached 10 million or NVRAM problem SC-900-01 Mechanical counter SC-901 Mechanical counter or fuse FU4 SC-921 MSU hardware error Copier feature expander hardware error Aficio 220/270 SC-940 Main switch problem or main board SC-951 Gate signal error SC-953 Scanner image setting error (Software) SC-954 Printer image setting error SC-955 Memory setting error SC-956 Scanner parameter error SC-957, 958 Scan error SC-959 Printer setting ID error SC-960 Printer return ID error SC-961 Printer ready ID error SC-962 Memory setting ID error SC-963 Memory finishing error SC-964 Printer ready error SC-970 Scan error SC-980 Program loading error or hard drive access error SC-981 Hard drive response error SC-982 Hard drive construction error SC-984 Hard drive response error Control board, BICU or connection bad Aficio 1035, 1045 SC-985 Control board, BICU or connection bad Aficio 1035, 1045 SC-986 Software problem SC-990 Communication problem between BICU and input output board or software performance error SC-991 Software problem SC-996 FCU board or firmware problem SC-997, 998 Software or missing RAM or missing DIMM SC-999 Program version error or fuser FU6 Program download problem, BICU, IC, NVRAM bad, power loss, board installed wrong Aficio 1035, 1045 Printer Controller Error Codes 2001 Power on error 2002 FGATE error 0201 On board SDRAM error 0301 SDRAM error 0Fxx Controller -BICU error 1101 Data transmission error 1102 Data loop back 11xx Centronics cable error 1401 Controller NVRAM error 1402 NVRAM check sum error 1403 NVRAM white error 1404 NVRAM read error 1501 RTC error 1601 Font ROM error 1602 Data in font ROM is damage 1Bxx Options bus A error RICOH 3813 Copier U1 Right side open U2 No key counter U4 Sorter not latched or closed U6 Developer unit not in place E11 Exposure lamp problem E12 Exposure lamp problem E13 Zero cross, main board or power supply E-14 Zero cross, main board or power supply E-21 Scan home problem E-22 Scan home problem E-28
May 17, 2014 | Sharp AR-5316 Advanced Digital Imager...
How to use booklet maker
The HP booklet maker/finisher with output accessory bridge provides two 1,000-sheet stacker bins and a booklet bin with stapling, saddlestitching, and v-folding capabilities.
Sep 06, 2012 | HEWLETT-PACKARD Q6999A Finisher, Mailbox...
How do I replace staples in the Konica Minolta Bizhub 600?
The saddle stich or the booklet??? saddle stich is like church program with staples in the middle. Booklet is staples on the left side of the paper or the corner stapler to different staplers and depends on the finisher model?
Aug 08, 2011 | Minolta Office Equipment & Supplies
How to copy a booklet on the canon 3045
To make a stapled or folded booklet on the 3045 will require the "Saddle Finisher option. This is a finisher the attaches to the left side of the copier. It has 2 trays and an additional tray on the very bottom of the finisher. If you do not have this it will be impossible to make a booklet that is two sided with the pages properly sequenced. If you have the saddle finisher attached. On the screen select special features and on the first or second screen you will see a booklet button, press that and follow the prompts. If the booklet button is greyed out you do not have the Saddle Finisher.
May 18, 2010 | Office Equipment & Supplies
Making a booklet out of a multi-page PageMaker file
many questions, the answer should be yes and all is in the driver settings but it all depends on if you have the correct driver installed and configured correctly for your copier and if your finisher is a booklet finisher. if you have every thing laid out in page maker correctly and the driver is setup correctly then it should do just fine.
Apr 14, 2010 | Canon imageRUNNER C3170U Color Copier
I have a Ricoh Aficio 1035 stapler problem.
if you press the finishing button on the display does it so stapler function there ? or try taking the staple cartridge out and then close the door on the finisher and see if it says out of staples. if it does it knows it has a stapler unit.
Jan 20, 2010 | Ricoh Aficio 1035 Copier
Finisher Installation for Ricoh 2051
open the properties of the print driver and click on the accessories tab. from there you can check off the accessories you have. if you are not sure which finisher to check off, print a configuration page from the machine and the kind of finisher will be somewhere on the top of the page
Feb 16, 2009 | Ricoh Aficio SP-C210SF Printer
Finisher keeps acumilating print jobs assuming they are not separte ones.
It is possible that the hard drive in the copier is about to fail. Has it gotten worse??
Mar 15, 2008 | Ricoh Aficio 1035 Copier
Ricoh Aficio 450 copier
Wrench means "call for service" More information may help Ed
Jun 14, 2007 | Ricoh Aficio 450 Copier
209 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
