Question about Sewing Machines
My thread breaks after I start sewing. what am I doing wrong?
    Genius:
  • 1,788 Answers
Check out your thread, is it old? Same weight as the bobbin thread? How is your tension set? Insert a new needle, (could have a small burr in the eye of it and cutting your thread)Totally rethread and do this test, with the presser foot up, pull top thread, it should move smoothly, now lower the presser foot, pull thread again, now it should barely move. This sometimes seats the thread in the tension discs. Try 3 for you tension setting. and see if that helps. Good luck
Posted on Dec 29, 2010
So when I start sewing it works for a few seconds then my top thread breaks and or wraps its self around the black casing the bobbin sits in. What am I doing wrong?
Be sure to RAISE the presser foot BEFORE threading the upper thread. This releases the tension disk so the thread can seat properly. If upper thread is breaking soon after beginning to sew, it usually is because the upper tension is too tight. Try loosening it and re-testing. The upper and lower threads should meet in the middle of the fabric.
Sep 21, 2015 | Singer Pixie Plus Sewing Machine
Why does the thread break once you start sewing?
The top thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
8. Try a different spool or cone of thread
Bobbin thread breaks
1. There is a right way & wrong way to insert the bobbin in the case --when you insert the bobbin in if it doesn't stitch correctly turn the bobbin over see if that helps or bobbin case is not inserted correctly
2. Lint has collected in the bobbin holder
3. The bobbin is damaged & doesn't turn smoothly
4. Lower thread tension is two tight
Jul 11, 2014 | Husqvarna Sewing Machines
What to do when the thread keeps breaking
Jul 10, 2014 | Singer Sewing Machines
I have a hyundai 8 stitch sewign machine been working brillant but last night it kept missing the tread and the thread breaking or jabbing . today looking at it i see when it jabs the Bobbin Case Inner...
if the sewing machine has a top loading bobbin, you may have to have the sewing machine checked to see if there is something wrong with the bobbin case or the hook and hook race.
I suggest try a new needle--one for the fabric being sewed
also try another bobbin
rethread the sewing machine top and bobbin, using every thread guide.
Aug 21, 2013 | Sewing Machines
Juki DDL 227 top needle keeps breaking
Needle breaks
1.the needle is damaged
2.the needle is not correctly inserted
3.wrong size needle for the fabric
4.the wrong foot is attached
5.the needle clamp screw is loose
6. Top tension is too tight
7. Machine could be out of time
The needle thread breaks
Oct 08, 2012 | Juki Sewing Machines
Thread keeps breaking
Aug 17, 2012 | Singer Confidence 7469 Mechanical Sewing...
Thread breaking
Aug 13, 2012 | Janome Sewing Machines
Upper Thread Breaks!!!
If you have not oiled your machine then it is best you do so, the machine is dry.or make checks on your bobin case it could be bend or needs to be ajdust.or worn out.good luck.
Apr 01, 2007 | Euro-Pro Shark 60 - 384
Sewing Machines Logo
29 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
