Question about Pentax Optio W10 Digital Camera
In certain lighting situations there are spots on the photos. Is there a way to clean the lens to remove these? I think its dirt on the interior lens
  • 747 Answers
No not dirt, what it's called is lens flare. Lens flare is where a sharp/bright point of light enters the lens on an angle and causes the light to refract through the lens elements. This is hard to see happening on a pocket point and shooter and equally hard to prevent. What can be done is you hold your hand above or to the side of the camera out of it's field of view to cast a shadow on the lens and the flare won't happen. However sometimes you get your hand in the pictures. Even on my pro cameras and lens combination this happens even with the use of a lens hood. The good part of this is I can see it happening through the viewfinder. The only other thing I can suggest is to change either the angle of the camera or recompose the scene or subject to the point of light is not causing this flare.
Posted on Dec 28, 2010
Testimonial: "Thanks very much! This was very helpful."
Canon A530 black spot on LCD which is visible in the photos tried to clean the lensa but was in vain canyou help pls?
A blck spot on your pictures, means there is something blocking light on the sensor. Could be dirt, but more lightly is there has formed some mould.
Because you can't open a compact camera to clean the sensor, I think you can't solve this problem. Opening the camera is no option, because without skills, tools and manual, you won't be able to put the camera together. A repair shop most likely won't start the job, because the repair will cost more than a new camera.
Sorry I can't bring a more positive story.
Jan 26, 2014 | Canon PowerShot A530 Digital Camera
Spots on the display screen
Still not clear, what you mean. But take care wham cleaning a lens. Never use a fluid like alcohol. Use a special lens pen or the soft brush on the other side of a lens pen, when you think the lens is dirty. Spots, or disk, also can appear when light is entering the lens from an angle. Even the expensive Fuji X10, had orbs or disks on the pictures in certain situations. Like dark with one or a few sharp lights close bye. Try the camera in different situations, to make sure the phenomena is in the camera or just a strange rare occasion.
When it is caused by a defect in the camera, it should show on every picture.
Dec 26, 2013 | Vtech Kidizoom Digital Camera
Nighttime photos have white haze (like a light reflections and not focused
If you have a scratch on the front lens of your camera, this could cause this. Bad light conditions, won't help a camera to autofocus.
But every light that can enter the front lens from a certain angle, can cause flares. Called lens flares. On DSLRs you often see a lens hood that comes with the lens. It is wrong to think you only need them in bright sun light, and put them the wrong way around on your lens. Every light source can cause a flair. So even shooting in the dark, close to a light source a lens hood can help to avoid flares. If you don't have a lens hood, screen the light with your hand.
On Wikipedia, you can read more about lens flares.
I won't tell what brand and what model, but a expensive system camera got white orbs in the picture when shooting in certain (dark) light conditions. So don't think it is only your camera.
Dec 04, 2013 | Galaxy Cameras
I need cleaning instructions to remove dust from the inside of my Panasonic Lumix DCM-ZS10 Leica lens
You are going down a dark alley here, these lens are specially coated very high quality optics and very easy to damage if not handled properly. You are taking a big risk with a high dollar item. I would think twice.
Jan 23, 2013 | Cameras
My panasonic Lumix DMC-ZX1 shows 3 dark spots and 2 hairs on all pictures. When I zoom-in the dirt is more visible and when I zoom-uit I dont see the hairs any more and the dark spots appear wider and...
Yes, you can clean. Not as complex as I originally thought.
1) Remove all of the silver screws
2) Separate the silver case (should split in 2)
3) Remove the 3 black screws in the middle
4) remove the center square cover that is over the lens
5) Use a duster spray to clean the lense and mirror
6) Reassemble in reverse order
Not knowing what I was going to get in, the entire process only took about 7-10 minutes.
Email me at malhokc1@yahoo.com with any questions.
Feb 09, 2011 | Panasonic Lumix DMC-ZR1 / DMC-ZX1 Digital...
I just bought the canon rebel xs and every picture that I take has a black spot "burned" into the picture. Any suggestions as to what I should do? Or should I just return the camera?
Sounds as if there is a fleck of dirt on the rear lens element. While in the house (to minimize dust and dirt) remove the lens and look at the rear of the lens see if there is dirt there. If so clean it gently with a soft lens cloth not a facial tissue. Reinstall the lens, if the dirt is still in the same spot return the camera because I suspect the dirt is on the sensor and will need to be cleaned.
Dec 27, 2010 | Canon EOS Digital Rebel XS / 1000D IS...
CAMERA IS THREE MONTHS OLD. ON MY LAST OUTING I NOTICED A PERFECT CIRCLE SPOT ONLY IN SHOTS OF THE SKY. THE SPOT IS IN THE IDENTICAL PLACE ON ALL SKY SHOT PHOTOS NO MATTER WHAT FOCAL LENGHT IS USED. THE...
If you have another lens, switch it and take some shots of the sky. If the spot is gone, it probably was the lens that needs cleaning/servicing. However, it's more likely that there's dirt on your CCD. On your camera's menu, select mirror lockup/clean CCD (I can't remember the exact terminology but you get the idea).
After you select that, the mirror will stay up. Remove the lens and you'll see that the CCD is now exposed. Use a blower (don't use your mouth to blow as you will end up with spit in the camera) to clear out any dust/debris on the CCD. Don't touch the CCD.
Turn off the camera and you'll hear the mirror go back down. Re-attach your lens and try some shots.
Apr 13, 2009 | Canon EOS 40D Digital Camera with 28-135mm...
D50 black spot of photos
Ok, step one - find an appropriate cleaning solution - be it an air blower, like a rocket blower, a pads, alcohol and a qtip, etc. Keep in mind that it's not necessarily true more expensive means better cleaning... but I wouldn't go the dirt cheap route of alcohol and a qtip, though many claim they use it. Personally, I use a blower, but I havn't had anything more than dust thus far...
After that, prep a very clean environment, then take off your lens, and clean your mirror!!! Then when you think it's clean, try your camera again... if you still have spots, then you're going to have to clean the sensor... again, I'd use a blower, especially considering that if you ruin the sensor, you've pretty much ruined your entire camera.
If you STILL have spots, check your lens for dust, both front and back lenses. Still spots? Try another lense entirely (might be scratches). STILL on there? Then you probably have a bad sensor... see warranty information and pray :).
If any of this makes you queasy, look in your phonebook for stores that will offer repair, and try to locate the Nikon-qualified if possible.
Oct 05, 2008 | Nikon D50 Digital Camera with 18-55mm Lens
Gray spots on screen on a JVC HDILA model HD 56G 787
The gray spots are caused by dust on your lens, very easy to clean.
Power down the TV.
If you open the right side access panel (right side as you are looking at the front of the TV) you can see it in the middle, it's not very big. Using a scratch/lint free cloth, gently wipe off the lens or use a vacuum to **** up the dust being careful not to actually touch the lens.
Replace the access panel and enjoy your spot free screen.
Sep 29, 2008 | JVC HD-52G786 52" Rear Projection HDTV
Cleaning interior viewfinder lens?
try to use an air spray for dust. get the lens off and clean above the miror. with the air spray the dust will disapear. dont use air pumps becose u mes it up. and dont use compreset air from regular compresor, u will get oil on your lenses.
Nov 18, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Pentax Optio W10 Digital Camera Logo
49 people viewed this question
Top Pentax Cameras Experts
Greg Cann
Greg Cann
Jerry Greenberg
Jerry Greenberg
Are you a Pentax Camera Expert? Answer questions, earn points and help others
