Question about NetGear DG834G Router
I am trying to log into my router to change the NAT type, So i reset the router as the default username and password. Now when I click on the router in the start menu, it switched the router off? I am very confused
  • 4,338 Answers
You do not need the software that comes with any modem:
Reset the router:
To restore the factory default configuration settings without knowing the administration password
or IP address, you must use the reset button on the rear panel of the router.
1. Press and hold the reset button until the Power LED turns red (about 6 seconds).
2. Release the reset button and wait for the router to reboot.
To log in to the modem router:
1. Type http://routerlogin.net or http://192.168.0.1 in the address field of an Internet browser.
Enter admin for the user name and password for the password, both in lower case letters.
NAT automatically assigns private IP addresses (10.1.1.x) to
LAN-connected devices.
? Enable. Usually NAT is enabled.
? Disable. This disables NAT, but leaves the firewall active.
Disable NAT only if you are sure that you do not require it.
When NAT is disabled, only standard routing is performed
by this router. Classical routing lets you directly manage the
IP addresses that the DG834G v4 uses. Classical routing
should be selected only by experienced users*
? Disable Firewall. This disables the firewall in addition to
disabling NAT. With the firewall disabled, the protections
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
Posted on Dec 28, 2010
How do i put a password on my D-Link DIR 600 i want to use it private. pls help me.. tanx
Hello marticarpio
As far as a password i'm going to have to assume you mean to log into the router, past that security goes by pass phrase.
to log into your router open up a web browser(Internet explorer) type 192.168.0.1 At the log on screen type Username: admin Password:(default is blank) if a password other then the default is on the router, and you do not have it. use a paper clip to press in the reset button on the back of the router for 15 seconds. repeat the log in instructions using the default password. Immediately change the default password.
If you wanted to have a secure wireless network, click the wireless settings section. Name your router, and select a type of security. Depending on the type of security you choose follow the onscreen directions(wps may be easier)
Aug 14, 2011 | Computers & Internet
How can I changes my NAT-type from NAT-type strict to NAT-type 2 on Playstation 3? My router is a Gigabyte GN-BR01G
By default the IP address should be set to 192.168.1.254, insert this in the browser. You should see a box prompting you for your username and password. Enter your username and password now. By default both the username and password are admin. Click the Ok button to log in to your router.
Click the Virtual Server link near the left of the page.You should now see a new menu. In this new menu, click PPPoE/DHCP/Static.
PSN requires you to forward the following ports:TCP: 80, 443, 5223
UDP: 5223, 3478, 3479, 3658 Go ahead and enter the settings shown above into thePPPoE/DHCP/Static Configuration menu.enry.png When you're finished, click Submit near the bottom of the screen to save your changes.
And that's it! You're done!
Jul 27, 2011 | Computers & Internet
NAT IS STRICT
STEPS TO CHANGE NAT SETTINGS TO "OPEN":
1- Using your Browser, Log on to your router (by normally typing in the 192.168.1.1 address check your router's manual to see what the default gateway address)
2- If you already know how to log in to your router, then skip this step. If you have never logged on to your router then more than likely you still have the default initial log in credentials (username: admin - Password:1234 ..... Again check your router's manual to be sure). The minute you log in you need to change that password immediately, most network-savvy folks know that 90% of the people out there never reset their router's initial password and they can log on and make any changes to suit their needs, including locking you out of your own router.
3- Once you are logged in, you should be able to find two advance settings (One if for NAT - and the other is for Upnp)
4- Let's start with the NAT setting changes, and we will move on the Upnp at the end. I have personally tried the NAT setting changes and it didn't fix anything, I still had a "Strict" NAT setting on my xbox360, Only when I checked for the Upnp "allow authorized incoming traffic" options when the NAT settings on my XBOX finally came back as "Open" and not "Strict". But I will still explain what I did anyways with the NAT table cause I know it may work for some other routers.
5- So what I did with the NAT setting is this. I located the NAT advanced setting on my router, I click on the NAT (Edit List setting) or whichever link/button you have on your router advanced NAT settings to access the table needed to open certain ports (TCP and UDP - 88 & 3074) .
6- You will need to find out what the static/dynamic (preferably Static) IP address you xbox360 has. To do so, go to the Dashboard, go to the Console settings page, and click on the network settings to see the IP address (should be something like 192.168.1.x). You will need that IP address to enter into your NAT table on your router.
7- Once you got your XBOX's IP address enter it in the NAT Port Forwarding table (From - To - IP address: those are the 3 fields you should have on the table if you are using SUA NAT)
8 - In the first line enter 88 under both "From" and To" fields, then enter the IP address of the xbox in the field where you are to enter an IP address. (this is for UDP port)
9 - Repeat the same step for port TCP (which is 3074)
10- If these changes do not help open your NAT settings, then try the Upnp option. Click on your Upnp Advances settings and click on the "Allow Traffic" option, this is mostly secure because you are only accepting the incoming traffic that matches your outgoing traffic.
Mar 02, 2011 | Belkin Basic Wireless Router
I need to change the nat type to open and and not strict
Fot your to change thesettings of the NAT of your router you need yo access the router page by opening a browser and type 192.168.2.1 on the address bar. It will ask you for a username and password. The default username is admin and the password is 1234. The click on the NAT settings on the left part of the page.
Thanks for using Fixya.
Jan 27, 2011 | Edimax BR-6226n nLite Wireless Broadband...
I need to change my Nat and for that i need to log in, in my zhones IP adrees but i dont know the username and password what can i do?
If you don't know the password, all you need to do is reset your router, then it will be all factory defaults again.
The default user name is Admin and the password is Admin.
Dec 22, 2010 | Zhone (6218-I2-200) Router
Need to fix my nat type
Please find the below steps
1. Your laptop should be connected to the router.
2. try to open the default ip of the router on your internet explorer page
3. Type IN the username and password
4. Once logged IN , you can find the NAT settings will be inside the Firewall settings
Oct 30, 2010 | Belkin Computers & Internet
My NAT setting is strict. ive tried everything i know to change it but cant. i have a silver motorola modem wit a black and blue linksys router but i cant figure out how to change the Nat setting. Im...
Microsoft has a support page to help you with your NAT settings. The prescribed solution is to "open" the following ports on your router:
  • UDP 88
  • UDP 3074
  • TCP 3074
1- Using your Browser, Log on to your router (by normally typing in the192.168.1.1 address check your router's manual to see what the defaultgateway address)
2- If you already know how to log in to your router, then skip thisstep. If you have never logged on to your router then more than likelyyou still have the default initial log in credentials (username: admin- Password:1234 ..... Again check your router's manual to be sure). Theminute you log in you need to change that password immediately, mostnetwork-savvy folks know that 90% of the people out there never resettheir router's initial password and they can log on and make anychanges to suit their needs, including locking you out of your ownrouter.
3- Once you are logged in click on sercruity, scroll tot he bottom and make sure "Filter Internet NAT Redirection" is set to "disabled" ,
4. now click on advanced routing
make sure
Nat is enabled.
5. now click on applications and gaming.
4- Let's start with the NAT setting changes, and we will edit theUpnp settings at the end.
6- You will need to find out what the static/dynamic (preferablyStatic) IP address you xbox360 has. To do so, go to the Dashboard, goto the Console settings page, and click on the network settings to seethe IP address (should be something like 192.168.1.x). You will needthat IP address to enter into your NAT table on your router.
7- Once you got your XBOX's IP address enter it in the NAT PortForwarding table (From - To - IP address:)
8 - In the first line enter 88 under both "From" and To" fields, thenenter the IP address of the xbox in the field where you are to enter anIP address. (this is for UDP port)
10- If these changes do not help open your NAT settings, then try theUpnp option. Click on your Upnp Advances settings enter the same information with the ip, and make sure UDP are enabled and checked for. use the port #s for your info as well in the chart. you can name them what ever u want under the application column.
  • UDP 88
  • UDP 3074
thend o the same for
TCP 3074
just make sure the tcp is checked and not udp.
if that doesnt work we can do a full reset on your router.
Reset for most routers with a reset button on the rear panel
Write down configuration information such as IP addresses, securitykeys, opened ports and services, etc., that you modified. (The defaultusername is admin and the password is either password or 1234. Try these before resetting the router.)
  1. Press the reset button on the back until the test light blinks.This takes about 10 seconds. (To avoid accidental resets, the smallbutton is recessed. Use a pen or paperclip to access it.)
  2. Release the button.
  3. Wait for the router to reboot.
  4. Log in with the default password.If the router configuration was not cleared, try these additional steps AFTER the router has finished rebooting.
  5. Unplug the router's power.
  6. Press and hold the reset button. While the button is held down, reconnect router's power.
  7. Continue to hold the reset button for 20 seconds after reconnecting the power.
  8. Wait for the router to reboot.
  9. Log in with the default password.
please rate me, and mark this fixya if it has helped.
Nov 28, 2009 | Motorola Computers & Internet
I need to change my nat settings
Type into the address bar www.whatismyip.com copy and paste your ip address into the address bar, a username and password will be required to access the page, most default usernames and passwords will be admin and password, for sky users the password may be sky, if these don't work then dont worry there are websites that have a list of all routers default usernames and passwords. once on the router setup go to security setup, and go to where it says WEP, click disable WEP and accept changes. if it is for gaming make sure that the UPnP is clicked on. and there you go, bare in mind that your pc may stuggle to connact to the router at this point because of the change, so just change the settings on your computer to suite the routers settings and there you are an open NAT and internet that still works. hope this works for you!
Apr 10, 2009 | D-Link DI 514 Wireless Router (DI-514)
Ps3 nat type 3
In order to achieve NAT 2, you are going to have to set your PS3 to a static IP address and forward ports on your router.
detailed instructions on how to do this and configure your ps3 can be found here:
http://www.pregamelobby.com/forum/sony-reviews-tips/5618-how-get-type-2-open-nat-your-ps3.html
In order to get into your router settings, go to 192.168.0.1 OR www.routerlogin.net (the router sets up its own DNS) and putting in your username and password. If you have not set up a password, the default username and password for this router is "admin"/"password". Follow the instructions in the page I posted once you are logged into the router's webmin.
Hope this helps!
Jul 15, 2008 | NetGear WGR614 Wireless Router
Change NAT to open
I have this router and have just enabled the NAT settings from Strict to Open:-
1. Log into router's IP address (192.168.1.1) and enter password. Select "Advanced Setup".
2. Click on Advanced on left hand menu and select UPnP
3. Check all three boxes in window and click on Apply
4. Close router configuration window and run XBox test again. Worked for me!
Oct 08, 2007 | Zyxel P660HW-D1 Router
NetGear DG834G Router Logo
1,340 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
