Question about Stanley Bostitch N88rh Framing Nailer Driver Piston 158582
Stanley Bostitch N89C-Piston will not retract. Forgot to oil today-used ,yesterday and today, perhaps 200 nails. If I have to disassemble do I open from top or bottom?
    President:
  • Stanley Master
  • 1,388 Answers
Lack of oil usually will not prevent driver from retracting (bent driver /debris / worn piston oring / cracked lower bumper / loose check valve ) . Remove nails and push driver up. It should not require much force to move driver / nor be so easy that driver fall back down under its own weight. If driver feels loose, replace piston oring. If it feels about right, most likely problem is the check valve. Remove head and pull cylinder. Look for band around cylinder covering series of holes. It should fit snuggly. If loose replace with new part or use any rubber available or series or orings to fit space. If check seal looks ok then examine lower bumper for missing pieces or cracked. Lube with silicone paste lube sold at Lowes. Parts are available at www.toolpartsdirect.com . Good holidays
Posted on Dec 29, 2010
My fn1664k does not shoot a 2 inch nail all the way into a 2x4
Check the pressure at the gun to make sure the hose is good. Make sure the gun is oiled. The compressed air forces a piston down to drive the nail. the inside of the cylinder may be corroded causing the piston not to move as fast as it should or with as much force. Most air guns are pretty easy to disassemble to inspect. You should be able to figure this out pretty quickly this way.
Oct 31, 2014 | Stanley Bostitch FN1664K 16 Gauge Finish...
Bostitch n88rh, driver won't retract, does so after disconnecting air, shoots 2-3 nails then same problem, thanks
Have you put oil in the air chuck inlet lately to lubricate? Let me know if this helps or we can investigate further
Jan 20, 2011 | Stanley Bostitch Nail Gun
My Bostitch nail gun just start the end of the gun don't return the start place please help .
remove the piston cover screws and slide the piston out by pushing back the firing pin clean and oil all seals and o rings this area tends to collect dirt and sand and should be cleaned periodicaly
Jan 09, 2011 | Stanley Bostitch Nail Gun
Nailer fires first nail successfully but next nail jams. It appears the part that retracts after each nail is ejected does not retract all the way so the next pack does not load properly. Have cleaned and...
first make sure you are using the right guage nails. then I would look at the condition of the driver to make sure not bent, also look for a broken nail in the magazine area which will also cause this, lastly does the piston/driver "fall" in the cylinder?? there should be some resistance against the o ring, if not then it could also cause your described problem,
Dec 21, 2010 | Stanley Bostitch SB1664FN 16 Gauge...
I have Bostitch RN45 coil nailer. It sometimes does not feed nails. When I open the magazine the driver blade has not retracted. Gun does not leak, o-rings in drive section look to be in good shape and...
Causes of piston not retracting are as follows. Cracked /worn bumper, if cracked air will leak between piston and bumper. Try test, remove nails and dry fire gun against rubber or soft wood; depress trigger push gun against wood/rubber and hold in this position. Piston should stay down and no air should leak past nose. Worn piston oring, piston should not slide down cylinder under its own weight. Loose or missing check seal, remove cylinder and look for black rubber band around series of holes. Band should be in place and fit snuggly. Good luck
Oct 20, 2010 | Stanley Bostitch Rn45b1 Industrial Coil...
Looking operators manual for stanley bostitch rn45b
Look here for manual and parts:http://www.bostitch.com/default.asp?TYPE=STATICLEFT&PAGE=tooldoc_results.htm&Left=left_tooldoc_results.htm&partNum=WM45B&serialNum=
The two lines of address above should be all one line in the address bar. If it does not work, go to www.bostitch.com , service parts and find wm45b. Good luck
Sep 18, 2010 | Stanley Pneu Roof Stapler
I have a Bostitch BT200 that is dry firing. It seems that the "hammer" is not retracting after it fires a nail. I have to push it back manually and even then it seems to dry fire a few times before a nail...
The check seal is what causes the piston to retract. Remove cylinder and examine check seal. It is a small band that covers a series of holes and should fit snuggly around cylinder. Other factors that have effect on piston retraction are, split/cracked cylinder, bent driver and lack of lubrication. This gun is tricky to rebuild. Make shure that all the parts in the head are placed correctly. The kit does contain all the parts that you need. Good luck
Sep 07, 2010 | Stanley Bostitch Bt200 Brad Nailer Rebuild...
Nail driver slide wont retract
You have worn o-rings. You can go to www.bostitch.com and find a breakdown of your nailer. On the left side of the page go to 'Schematics and Parts', find your model number and a parts list will come up. Unfortunately Bostitch doesn't make many repair kits for their guns, you have to order all of the o-rings individually. Replace all of them, if one or two are worn the rest are not far behind. You can order them from Stanley Bostitch or get the part numbers and find another vendor.
Sep 02, 2010 | Stanley Bostitch N88rh Framing Nailer...
N100 framing nailer does not retract piston
Try oiling it. That is the most common problem. Also, make sure you are using the correct nails. If they are not genuine Bostich nails, try them.
Nov 28, 2009 | Stanley Bostitch Coil Framing Nailer
Contact head won't retract...seems to be stuck
Two things come to mind, both require disassembly.
First i would clean the area, and then relube the contact head. While cleaning that area and relubing, check the o-ring and the surrounding seals, they may be not properly alligned or sitting perfect.
Aug 08, 2009 | Stanley Bostitch F21PL Nailer
Stanley Bostitch N88rh Framing Nailer Driver Piston 158582 Logo
254 people viewed this question
Top Stanley Air Tools & Compressors Experts
John Trevino
yoopertech
Joe Garcia
Joe Garcia
Are you a Stanley Air Tool and Compressor Expert? Answer questions, earn points and help others
