Question about Kitchen Ranges
Eurolec techno gas stove Model 3568 0506 s/n 86,06,00 oven lights but will not stay alight Have been advised thermo couple is damaged Part required capiliary tube 1165mm long & 10mm universal nut or 10mm split universal nut with coarse thread to fit over thermo couple Italian thread is different to that available in Austarlia
5 Suggested Answers
SolutionGuy
  • 331 Answers
SOURCE: Tappan Gas stove
The pilot adjustment screw is located on the back side of the oven temperature thermostat. Lift the cook top to access it. Use a flat screwdriver to adjust... counter clockwise= bigger flame.
Posted on Aug 15, 2007
SOURCE: EUROLEC 3572 9506 LPG GAS OVEN
OK sista62, here is your solution. The problem is that the thermocouple that controls the valve supplying gas to the ovenjet is not working. A new thermocouple is available from http://blgas.com.au/online/category4_1.htm and will cost about AUD$40.00.
The control valve is located right behind the knob on the frontpanel (the centre one that controls both the oven and the grill.) You will see two small copper tubes going into the control valve. These are the thermocouple tubes, one comes from the griller and the other from the ovenjet. All the other knobs only have one thermocouple for each of the topplate burners.
If you want to test before you buy, disconnect the thermocouple from from one of the topplate burners and connect it to the one for the oven control valve. Now turn on the topplate burner and keep it going by holding the knob down on the front panel for this burner. Now light the oven burner and it should stay on.
Good luck.
Posted on Feb 01, 2008
SOURCE: oven pilot light won't light
Part of the problem was my own ignorance about this particular Kenmore gas oven. It doesn't even have a pilot light. Instead, there is an electric heating element close to the burner which gets so hot that it ignites the gas. It seems that the heating element also doubles as a temperature sensor, so that it opens the gas valve only when the heating element is hot enough to ignite the gas. This heating element, called the "ignitor", no longer gets hot in my oven even though there is 120VAC applied to it when the oven knob is turned on. Therefore, the ignitor is defective. I ordered a new one on-line from "Appliance Parts of America" for $31.50 plus shipping, and this should fix the problem. If it does NOT, I'll add to this post.
Posted on Apr 21, 2008
aborcass
  • 2651 Answers
SOURCE: premier 30 inch gas stove oven does not light
do you hear any clicking when you try to start the oven portion of the range? if not lets try this, open the lower drawer so you can see the burner bar and mechanism for lighting the bake bar. as your watching the mechanism turn on the oven (nothing should happen as per your issue) while oven is on try lighting one of the top burners, any one will do wanna check if that lites the spark and in turn lites the oven pilot.if that does infact work you have a bad spark switch for the oven control
Posted on Oct 29, 2008
  • 3 Answers
SOURCE: Oven wont light
Mine did that and I found the ignitor for the oven was bad. It was the "glow" type for pilotless ignition and it was burned out. It is supposed to glow bright red and the gas comes on and the oven will light. It was easy to tell that it was bad. But to check it I swapped the broiler ignitor with the oven ignitor and the oven worked.
Posted on Dec 20, 2008
Got new oven but can't get it to stay alight, when u release holding in button it goes out is there a certain way u have to light ie door shut open?
get a gas fitter in to check out the fault for a new stove /oven
could be that the gas solenoid is not connected correctly and only works when you have your finger on the button
it may also be a fault in the light sensor that when you take the finger of the button it looses the power supply and turns off the gas solenoid.
Sep 11, 2015 | Kitchen Ranges
Smeg gas hobs ignite immediately but flame goes out when i let go of the igniter. I have to hold it down for a very long time befor it stays alight. this is time consuming and not right. What is the...
depending on what you mean by " a very long time " -- holding down the gas valve button while the thermo-coupling gets up to the proper temperature is normal. ( normal hold and wait time should be between 10 to 25 seconds, anything longer than that is a sign that the thermo-coupling is bad ).
c...
Jan 02, 2011 | Microwave Ovens
My oven won't heat up properly
wire brush the oven pilot light orifix flame may be lessened due to carbon buildup then when oven lights its convextion pulls the pilot flame away from thermal coupling with shuts off gas (in case wind blows it out, it will STOP the GAS FLOWING. if the pilot full size (near 3/4 inch tall) then just try to position the thermal coupling nearer the flame (not right on it)
Nov 22, 2009 | Ovens
Hi, we have a dcs 366 gas range. the pilot light for the oven went out and we can't seem to locate the pilot to re-light. the manual doesn't really go into detail for the oven...only the stove top. is this...
You don't give the model number of your DCS range, but it probably doesn't have a pilot light.
More likely it uses and electronic igniter. Internet search on "gas oven ignitor". I think this
might help you with your problem.
Mar 15, 2009 | DCS Kitchen Ranges
Oven will not stay alight
You have aproblem with you ffd ( flamme faliure device which is located in the oven.. Or if your oven has a thermocouple that has gone. Yo need to replace either one of them depending which one you have in your oven
Nov 18, 2007 | Ovens
Conversion from Natural Gas to LPG
only source will be stoves or their service agents. if uk, stoves is same group as belling and parent company is morphy richards
Apr 27, 2007 | Stoves 1200DFa Dual Fuel (Electric and...
Kitchen Ranges Logo
777 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
