Question about 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Had this viper alarm installed on a mustang and the alarm seems to go off every 30 minute
  • 42 Answers
If your alarm is going off every 30 minutes its because a zone is backfeeding after the cars computer shuts down. First you have to find out what is back feeding... I would first disconnect the door trigger wire from the alarm to the car. Test it and if this is the problem then you should go to the latch wires of the car doors and not the interior domelight. If the problem is still there than you should check to see if the trunk trigger is the problem. Most techs pick up the trunk trigger in the trunk at the light. if you find that this is the problem then just remove the trigger from the light and add a pinswitch in the trunk.
Posted on Feb 10, 2011
Ford mustang wont start my 2002 mustang wont start it has a viper alarm system on it.
You need first remove the alarm then check if it start. Or put the ignition on make sure the vehicle is in park if it is a automatic transmission. Or in neutral with emergency brake on hot wire the stater.
Oct 03, 2013 | Viper Vehicle Parts & Accessories
Why does my viper alarm suddenly start chirping?
Mine does that too (chirps 8 times), every 4 to 8 hours or so (seems to be random but persistent). The alarm was installed November 2014 and I just started noticing it in May 2015, possibly because I am now within earshot of where my car is parked?
Apr 28, 2012 | Viper Security and Remote Start System...
Should I intall a Viper 5701 remote start on a manual transmission Mustang?
Honestly, you would be taking a risk. You have to remember that if you do, you will always need to keep the car out of gear in order to start the vehicle. You will also need to install an extra relay in order to bypass the clutch switch. Very unsafe, but good luck.
Feb 19, 2011 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
I have a Viper Alarm 3002 2-way on a 2003 Mustang GT. After removing it, my car no longer starts. Please help
if your car doesnt start, maybe when you pulled out the alarm, you didnt connect the starter wire back together
Aug 19, 2010 | 3002 2 Way LED Car Alarm Keyless Entry...
Viper Two-Way Remote
I had the exact same problem. Disconnect your vehicle battery for 30 minutes. That fixed it for me.
Jan 11, 2010 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Viper alarm keypad will beep for 30 seconds every time I arm or disarm
Change the battery, 2-way remotes require 2 slim batteries on top of one another. Regular remotes only require 1.
May 10, 2009 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Van won't start after thunderstorm set off viper alarm system
Not saying this is your solution. I would do the simple thing first. Disconnect the battery for 5 to 10 minutes and see if it allows the alarm to reset. If not call your local car alarm installer. Maybe Best Buy. These companies will more than likely help you out
Apr 19, 2009 | 1995 Chevrolet G20
Alarm goes off for no reason 20-30 minutes after i lock doors
remove the battery from your remote and see if works
Mar 12, 2009 | 2001 Dodge Viper
Remote start on my viper alarm wont stay running
it is getting a shutdown trigger from somewhere. check manual for rem.st. diagnostic trouble code section to find out where from is step one.
Jan 14, 2009 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Viper 5701 2 way alarm and remote start
Most ford need the door triggers double diode isolated. When the GEM module goes to "sleep" it will set of your alarm . Cut the factory wires where you hooked up the door triggers determine which side goes to the door and which side goes to the GEM module. If it is a negative trigger solder in a 3amp diode with stripe towards the door then solder the door trigger from the alarm to the door side of the diode. Repeat for all door triggers.
Dec 18, 2008 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
5701 VIPER 5701 2-WAY ALARM w/REMOTE START Logo
403 people viewed this question
Top Viper Vehicle Parts & Accessories Experts
Kevin Daniels
Tre Elkins
Shehu Pro
Shehu Pro
Are you a Viper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
