Question about Acer AL1912B 19" LCD Monitor
I turn on acer laptop then the power button blinks slowly and there is a black screen last time it happened there were white lines across the screen then i had to turn it off and then I got help and the it said to try taking the battery out and leave it out but plug in the charger then turn on the computer once it turns on put the battery back in and I tried it and it worked the the second time it happened I tried it again and it did not work so can you please help me fix my acer laptop
  • 582 Answers
Try cleaning the heat sink by vacuuming out all the dirt then do battery. I have an acer it worked for me.
Mike
Posted on May 29, 2017
Fix-4U
  • 293 Answers
SOURCE: Acer Screen goes blank when fan comes on...Help!!!
Hi...there,
It's seems your backlight inverter are busted. Need to replaced a new one...
Posted on Nov 28, 2008
  • 111 Answers
SOURCE: ACER AL1715 PowerLed blinking only,no picture,flash about .5secs
This sounds as if you are using the hibernate feature in windows reboot it and reset the power options to hibernate never check the vid connection as well
Posted on Dec 19, 2008
  • 5 Answers
SOURCE: acer aspire 5101 orbicam
If you have a grey rectangle where ur cam should be. Especially after a fresh install plus all the drivers. although Then here's your solution :)
Go into device manager and delete the USB controller. Then reboot. When it says new hardware found let it automatically install it. Et voila, working cam :)
Complements of TruthSeeker 69
Posted on Jan 01, 2009
TIPS72
  • 369 Answers
SOURCE: Monitor goes blank less than a second after turning on.
there is an hardware issue in your lcd it needs to change one of the capaciter please take it to a lcd technician
thanks
Posted on Jan 24, 2009
micromend
  • 748 Answers
SOURCE: Need help for Acer Aspire ONE MODEL # ZG5 screen does not work
If you are sure the computer is running then connect an external monitor to the laptop. You will have to select the external using your Function keys FN + F7 or F8. If you can now see your machine on the external monitor then you know it's the screen portion of your laptop that is faulty. If this does not work then the sounds you are hereing are probably just the fan and the hard drive spinning. These are not an indication that the computer is working. All in all, I would say that the laptop needs to see a pro.
Posted on Mar 26, 2009
Acer aspire 4830t-6841 power button blinks 5 times won’t turn on. Happened during latest windows 10 update.
Buy a new powerbrick, it is probably the battery not charging.
If i let my acer run without powerbrick and its battery is empty, i get 5 flashing lights.
Jan 25, 2018 | Acer Computers & Internet
Black screen no fan sound but apparently getting power
for solve any type of error and issues dial toll free number +1(800)726-0294
and for more visit - 1 800 726 0294 Apple Support Number Mac Technical Support Help
Sep 10, 2017 | Apple PowerBook G4 Mac Notebook
Hello, I have a 42"
Sounds like a backlight is out. If its still under warranty, exchange it. First try unplugging it for two minutes to reset the t.v.
May 15, 2011 | LG 42LG30 42 in. LCD HDTV
Acer Aspire 5720 Laptop problem. When turned on
Upon loading press F2 or del to enter bios setup and change the settings to display the acer welcome screen and the one you said about Microsoft logo and white box with green lines, you cant by pass it because it's windows loading screen
Dec 01, 2009 | Acer Aspire 5720-6661 Notebook PC
Acer extensa will not boot to windows
What is happening when you press the power Button? Do you see any ligths, Any HDD moves? IF DOES.
TURN OFF by pressing and holding your finger on power button.
wait 60 sec. turn on and repeatedly press several times at F8 button.
If page opens on black and white, Use SAFE MODE.
wait til all line down. Then you will see windows opening in safe mode.
WHat ever you install last, remove, scan your computer for virus,spyware. when its finished, check your computer if need defragmentation. by Accessories>System Tools> Defragment.
If message comes such as windows will do this at schedule time or so.
Just turn off your computer using shotdown option (NOT BROWN BUTTON ON START) go to next arrow.
then turn on again see if windows comes back.
Goodluck
JMC
Aug 11, 2009 | Acer Extensa 4220-2148 Notebook
Hello I've got this problem. when my computer running, sometimes my screen go white screen and i can't see at all to the windows, just white screen. but all function is ok so i press power button to...
got this from a friend: Apparently some series of Acer notebook came with BAD_EDID laptop display. The only thing wrong is the checksum which is 9D and should be 1D. Powerstrip 3.76 (registered version) managed automatically to correct EDID.
There is no problem with drivers from 101.x series, but with any newer driver max. resolution is 1024x768 and the picture is in left upper corner of the screen with black bar on the right and smudged taskbar to the bottom of the screen. After installing and restarting resolution is set to 800x600 what results in white screen whit thick black bar slowly appearing on the screen.
Jan 27, 2009 | Acer Aspire 3690-2196 Notebook
Powering up
I think the battery is the problem. But does it power up when connected to the power?
Also please mention the model number.
Do you remember what hapenned the last time it worked ?
Nov 16, 2008 | Acer Computers & Internet
Laptop wont turn on at all!
try sensing if your cpu fan is working, it is under the power switch side, you can see small exhaust slots, put your hand beside it and feel if some air is coming out when you turn on your pc.
When you turn you pc on and only orange light blinks, it means that no power was getting into it, it blinks because no electrical power is coming from your power adapter and the battery is drained. Check your power adapter cable, this is the very cause why your pc is shutting down. usually the wire from the adapter to the pc is faulty.
Nov 01, 2008 | Acer Aspire 3000 Notebook
EMachines E19T5W Flat Panel Monitor - keeps blinking red, green, blue white lines
On the monitor below the screen has these fine pink and green lines blinking across the screen all the time on my laptop. Can you tell me how to fix it or solve this problem?
Aug 12, 2008 | E-Machines 19" Widescreen Flat Panel TFT...
Acer AL1912B 19" LCD Monitor Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
